CFNT-EGS15MM
CFNT-EGS15MM
    AEARO
    CONFORCFNT-EGS15MMTX5"X7"
CFNT-EGS15MM 数据手册
P r o d u c t B u l l e t CONFOR™ CFNT-EGS Foam i n 169 CONFOR CFNT-EGS foam is a shock and sound absorbing, slow-recovery foam. Easily conformable to intricate 3D shapes, it exerts a low, uniform force from 10-60% compression. It is an excellent choice for applications requiring comfort, sound and energy absorption. Typical Properties CFNT-EGS Density Nominal kg/m3 (lb/ft3) ASTM D3574 Flammability UL94 Compression Set % ASTM D3574 22hr @ 22C Compressed 50% 22hr @ 70C Compressed 50% Indention Force Deflection ASTM D3574 Test B1 Modified 25% Deflection for 12”x12”x2” Sample 22C (72F) @ 50% Relative Humidity Tensile Strength kPa (psi) ASTM D3574 5.1mm/min(20in/min) Tear Strength kNm (lbf/in) ASTM D3574 5.1mm/min(20in/min) @ 22C (72F) Peak Tan Delta C (F) ASTM D-4065, Shear Mode, 10 µm/ 5 N Halogen Free BS EN 14582:2007 Cl or Br < 900 ppm Cl+Br < 1500 ppm RoHS Compliant 83 (5.18) Meets HBF
CFNT-EGS15MM 价格&库存
很抱歉,暂时无法提供与“CFNT-EGS15MM”相匹配的价格&库存,您可以联系我们找货
