9071
9071
    KEYSTONE
    BRDSPTSNAPLOCKADHESIVE1/4"
9071 数据手册
INSULATED PC SPACERS/SUPPORTS • Board will be electrically insulated, eliminates need for insulating washers • No tool required for installation • Easy snap-in assembly ADHESIVE LOCK-IN RELEASE SUPPORTS • One end attaches to chassis with self adhesive pads • No drilling to chassis required leaving outside in perfect condition ADHESIVE MOUNT .156 (4.0) ADHESIVE MOUNT SLIMLINE .125 (3.2) FOR .156 [4.0] DIA MOUNTING HOLE .280 [7.1] FOR .125 [3.2] DIA MOUNTING HOLE FOR .062 [1.57] THICK PCB .400 [10.2] .700 [17.8] SQUARE Material: Nylon 6/6, UL Rated 94V-0 .172 [4.4] L .109 [2.8] .500 [12.7] SQUARE ADHESIVE TAPE CAT. NO. 9080 9081 9082 9083 9084 FOR .062 [1.57] THICK PCB .344 [8.8] .109 [2.8] L INSULATED PC SPACERS/SUPPORTS • Other end snap into .062 (1.57) board • Board is easily releasable for repair or upgrade L LENGTH .187 (4.7) .250 (6.4) .375 (9.5) .500 (12.7) .625 (15.9) ADHESIVE TAPE WITH TAB CAT. NO. 9070 9071 9072 9073 9074 Material: Nylon 6/6, UL Rated 94V-0 L LENGTH .187 (4.7) .250 (6.4) .375 (9.5) .500 (12.7) .625 (15.9) PC SPACER SUPPORTS • One end locks into chassis • Other end supports the PC Board • Ideal for mid supports of large boards • Simplifies assembly for multiple support applications • Reduces the amount of holes required in PC board STURDY SUPPORT SLIMLINE SUPPORT • One end permanently attaches to .062 (1.57) chassis • Accommodates varying board thicknesses • Sturdy support due to large contact area • One end permanently attaches to .062 (1.57) chassis • Low protrusion under chassis • Small diameter frees up space on PC board .171 [4.4] .280 [7.1] CAT. NO. 8822 8823 8824 8825 8826 8827 8828 .562 [14.3] L FOR .062 [1.57] CHASSIS .187 (4.8) .218 [5.6] FOR .187 [4.8] DIA. MOUNTING HOLE Material: Nylon 6/6, UL Rated 94V-0 L LENGTH .187 (4.7) .250 (6.4) .375 (9.5) .500 (12.7) .625 (15.9) .750 (19.1) .875 (22.2) L .100 (2.8) FOR .062 [1.57] THICK CHASSIS CAT. NO. 9055 9056 9057 9058 9059 9060 .150 [3.8] FOR .100 [2.6] DIA. MOUNTING HOLE Material: Nylon 6/6, UL Rated 94V-0 L LENGTH .125 (3.2) .187 (4.7) .250 (6.4) .375 (9.5) .500 (12.7) .625 (15.9) REVERSE CHASSIS MOUNT SUPPORTS • Permanently attaches to .059 (1.51) - .065 (1.65) thick case from outside • Provides flat clean cosmetic appearance • Ideal for low clearance applications or for mounting directly to case walls .156 (4.0) .125 (3.2) LOCK-IN RELEASE SLIMLINE LOCK-IN • End locks onto .062 (1.57) PC board • Board is positively locked until manually released • Board is easily releasable for repairs or upgrades FOR .156 [4.0] DIA. MOUNTING HOLE .400 [10.2] • End permanently attaches to .062 (1.57) PC board • Small footprint frees up PC board space .203 [5.2] FOR .125 [3.2] DIA. MOUNTING HOLE FOR .062 [1.57] THICK PCB .187 [4.8] .171 [4.4] FOR .062 [1.57] THICK PCB .500 [12.7] L .213 (5.4) .070 [1.8] FOR .213 [5.4] DIA. MOUNTING HOLE Material: Nylon 6/6, UL Rated 94V-0 82 L .187 (4.8) Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com CAT. NO. 9061 9062 9063 9064 L LENGTH .250 (6.4) .375 (9.5) .500 (12.7) .625 (15.9) .060 [1.5] .375 [9.5] FOR .187 [4.8] DIA. MOUNTING HOLE Material: Nylon 6/6, UL Rated 94V-0 ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED CAT. NO. 9065 9066 9067 9068 www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017 L LENGTH .250 (6.4) .375 (9.5) .500 (12.7) .625 (15.9)
很抱歉,暂时无法提供与“9071”相匹配的价格&库存,您可以联系我们找货
    • 1+12.717021+1.64053
    • 10+9.5586210+1.23309
    • 25+9.5404425+1.23074
    • 1000+5.705451000+0.73602
    • 2500+5.103412500+0.65836
    • 5000+5.050745000+0.65156
    库存:5321
    9071
      • 1+8.496731+1.09610
      • 50+7.6207850+0.98310
      • 100+6.74483100+0.87010
