908-125
908-125
    BIVAR
    ROUND SPACER 0.125" NYLON 1/8"
908-125 数据手册
REV. F G H J K DESCRIPTION Updated Material. Added Ordering Information. Removed Part Numbers from Part Offering List. Updated Material Description. Engineering Update w/o Changes. DATE APPROVED 10/28/08 06/06/11 05/06/15 10/09/15 10/22/15 T. Y. T. Y. J. C. J. C. J. C. H I.D. .005 -A- O.D. ORDERING INFORMATION: 9XX-XXX SERIES LENGTH INCHES, MULTIPLES OF .005" .030" = 030 .100" = 100 1.250" = 1.250 WHOLE MILLIMETERS 2mm = 2MM 5mm = 5MM SERIES 901 902 903 904 905 906 907 908 911 912 913 937 938 939 940 "H" DIMENSION .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) .030-1.250 (.76-31.8) I.D. .028 (.71) .032 (.81) .047 (1.2) .063 (1.6) .147 (3.7) .085 (2.2) .105 (2.7) .125 (3.2) .125 (3.2) .171 (4.3) .091 (2.3) .090 (2.3) .032 (.81) .047 (1.2) .063 (1.6) O.D. .085 (2.2) .125 (3.2) .156 (4.0) .187 (4.7) .250 (6.4) .148 (3.8) .167 (4.2) .187 (4.7) .250 (6.4) .250 (6.4) .187 (4.7) .125 (3.2) .085 (2.2) .125 (3.2) .156 (4.0) 3. TOLERANCE "H" DIMENSION: 0.030 - 0.500 (1.0 - 12.7mm)±0.005(0.1mm) 0.505 - 0.750 (12.8 - 19.1mm)±0.008(0.2mm) 0.755 - 1.250 (19.2 - 31.8mm)±0.015(0.4mm) 2. MATERIAL: NYLON 6, ULTRAMID 8270 HS, NATURAL. BIVAR MATERIAL CODE 01-NL-WE. ALLIED CHEMICAL POLYAMID NYLON 6 WITH CLARIANT CNY02655 WHITE NYLON CONCENTRATE. 1. GENERAL SPECIFICATIONS: BIVAR EXTRUDED PRODUCT SPECIFICATION BV00-E103. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: Michael Chen CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: NYLON TUBE SPACERS DATE: 01/13/03 DATE: 01/13/03 PART NO: REVISION: 9XX-XXX CAGE CODE : 32559 K SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
908-125 价格&库存
很抱歉,暂时无法提供与“908-125”相匹配的价格&库存,您可以联系我们找货
