REV.
F
G
H
J
K
DESCRIPTION
Updated Material.
Added Ordering Information.
Removed Part Numbers from Part Offering List.
Updated Material Description.
Engineering Update w/o Changes.
DATE
APPROVED
10/28/08
06/06/11
05/06/15
10/09/15
10/22/15
T. Y.
T. Y.
J. C.
J. C.
J. C.
H
I.D.
.005
-A-
O.D.
ORDERING INFORMATION:
9XX-XXX
SERIES
LENGTH
INCHES, MULTIPLES OF .005"
.030" = 030
.100" = 100
1.250" = 1.250
WHOLE MILLIMETERS
2mm = 2MM
5mm = 5MM
SERIES
901
902
903
904
905
906
907
908
911
912
913
937
938
939
940
"H" DIMENSION
.030-1.250 (.76-31.8)
I.D.
.028 (.71)
.032 (.81)
.047 (1.2)
.063 (1.6)
.147 (3.7)
.085 (2.2)
.105 (2.7)
.125 (3.2)
.125 (3.2)
.171 (4.3)
.091 (2.3)
.090 (2.3)
.032 (.81)
.047 (1.2)
.063 (1.6)
O.D.
.085 (2.2)
.125 (3.2)
.156 (4.0)
.187 (4.7)
.250 (6.4)
.148 (3.8)
.167 (4.2)
.187 (4.7)
.250 (6.4)
.250 (6.4)
.187 (4.7)
.125 (3.2)
.085 (2.2)
.125 (3.2)
.156 (4.0)
3. TOLERANCE "H" DIMENSION:
0.030 - 0.500 (1.0 - 12.7mm)±0.005(0.1mm)
0.505 - 0.750 (12.8 - 19.1mm)±0.008(0.2mm)
0.755 - 1.250 (19.2 - 31.8mm)±0.015(0.4mm)
2. MATERIAL: NYLON 6, ULTRAMID 8270 HS, NATURAL. BIVAR MATERIAL CODE 01-NL-WE.
ALLIED CHEMICAL POLYAMID NYLON 6 WITH CLARIANT CNY02655 WHITE NYLON CONCENTRATE.
1. GENERAL SPECIFICATIONS: BIVAR EXTRUDED PRODUCT SPECIFICATION BV00-E103.
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
Michael Chen
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
NYLON TUBE SPACERS
DATE:
01/13/03
DATE:
01/13/03
PART NO:
REVISION:
9XX-XXX
CAGE CODE : 32559
K
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“901-050”相匹配的价格&库存,您可以联系我们找货
