REV.
DESCRIPTION
A Engineering Update w/o Changes
B Typo Correction
C Remove 9910 P/N, Ref. EOL NOTICE 031215
D Engineering Update w/o Changes
DATE
APPROVED
02/24/04
10/28/08
06/15/15
10/22/15
M. C.
T. Y.
J. C.
J. C.
H
I.D.
O.D.
SERIES
9913
9908
9911
9905
9912
SCREW SIZE
#2
#4
#4
#6
#8
I.D.
.091(2.3mm)
.125(3.2mm)
.125(3.2mm)
.147(3.7mm)
.171(4.3mm)
O.D.
.187(4.7mm)
.187(4.7mm)
.250(6.4mm)
.250(6.4mm)
.250(6.4mm)
- XXX
H
-062
1/16 (1.6mm)
-125
1/8 (3.2mm)
-187
3/16 (4.8mm)
-250
1/4 (6.4mm)
-312
5/16 (7.9mm)
-375
3/8 (9.5mm)
-437
7/16 (11.1mm)
-500
1/2 (12.7mm)
-562
9/16 (14.3mm)
-625
5/8 (15.9mm)
-750
3/4 (19.1mm)
-812
13/16 (20.6mm)
-875
7/8 (22.2mm)
-937
15/16 (23.8mm)
-1000
1.0 (25.4mm)
STANDARD TOLERANCE
3. TOLERANCE "H" DIMENSION:
H ≤ 0.500 (12.7mm)±0.005(0.1mm)
H > 0.500 (12.7mm)±0.010(0.3mm)
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
2. MATERIAL: NYLON 6, ULTRAMID 8270 HS, NATURAL. BIVAR MATERIAL CODE 01-NL-WE.
DESIGNED:
ALLIED CHEMICAL POLYAMID NYLON 6 WITH CLARIANT CNY02655 WHITE NYLON CONCENTRATE.. Ty Yin
CHECKED:
1. GENERAL SPECIFICATIONS: BIVAR EXTRUDED PRODUCT SPECIFICATION BV00-E103.
± .1
± .01
± .005
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
NYLON TUBE SPACERS
DATE:
02/24/04
DATE:
02/24/04
PART NO:
REVISION:
99XX-XXX
CAGE CODE : 32559
D
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“9911-4MM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.003931+0.12997
- 5+0.662175+0.08573
- 10+0.6119710+0.07923
- 25+0.5536625+0.07168
- 50+0.5113650+0.06620
- 100+0.47633100+0.06167
- 250+0.43404250+0.05619
- 500+0.40657500+0.05264
- 1000+0.381791000+0.04943
