9908-11MM
9908-11MM
    BIVAR
    ROUND SPACER #4 NYLON 11MM
9908-11MM 数据手册
REV. DESCRIPTION A Engineering Update w/o Changes B Typo Correction C Remove 9910 P/N, Ref. EOL NOTICE 031215 D Engineering Update w/o Changes DATE APPROVED 02/24/04 10/28/08 06/15/15 10/22/15 M. C. T. Y. J. C. J. C. H I.D. O.D. SERIES 9913 9908 9911 9905 9912 SCREW SIZE #2 #4 #4 #6 #8 I.D. .091(2.3mm) .125(3.2mm) .125(3.2mm) .147(3.7mm) .171(4.3mm) O.D. .187(4.7mm) .187(4.7mm) .250(6.4mm) .250(6.4mm) .250(6.4mm) - XXX H -062 1/16 (1.6mm) -125 1/8 (3.2mm) -187 3/16 (4.8mm) -250 1/4 (6.4mm) -312 5/16 (7.9mm) -375 3/8 (9.5mm) -437 7/16 (11.1mm) -500 1/2 (12.7mm) -562 9/16 (14.3mm) -625 5/8 (15.9mm) -750 3/4 (19.1mm) -812 13/16 (20.6mm) -875 7/8 (22.2mm) -937 15/16 (23.8mm) -1000 1.0 (25.4mm) STANDARD TOLERANCE 3. TOLERANCE "H" DIMENSION: H ≤ 0.500 (12.7mm)±0.005(0.1mm) H > 0.500 (12.7mm)±0.010(0.3mm) ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX 2. MATERIAL: NYLON 6, ULTRAMID 8270 HS, NATURAL. BIVAR MATERIAL CODE 01-NL-WE. DESIGNED: ALLIED CHEMICAL POLYAMID NYLON 6 WITH CLARIANT CNY02655 WHITE NYLON CONCENTRATE.. Ty Yin CHECKED: 1. GENERAL SPECIFICATIONS: BIVAR EXTRUDED PRODUCT SPECIFICATION BV00-E103. ± .1 ± .01 ± .005 D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: NYLON TUBE SPACERS DATE: 02/24/04 DATE: 02/24/04 PART NO: REVISION: 99XX-XXX CAGE CODE : 32559 D SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
9908-11MM 价格&库存
很抱歉,暂时无法提供与“9908-11MM”相匹配的价格&库存,您可以联系我们找货
9908-11MM
    • 1000+0.436811000+0.05473
    • 3000+0.425303000+0.05328
    • 5000+0.419985000+0.05262
    • 20000+0.4066920000+0.05095
    • 30000+0.3969430000+0.04973
