4395
4395
    KEYSTONE
    Hex Standoff Threaded M3x0.5 Brass 0.197" (5.00mm)
4395 数据手册
R TI F I ED SPACERS & STANDOFFS 2 T Y CE 900 ISO Q I UAL ROUND CLEAR SPACERS ALUMINUM ECONOMY SPACERS • PRECISION FORMED• NO BURRS BRASS OR ALUMINUM Made of flat strip aluminum and rolled on precision equipment. Assures maximum bearing surface, square ends. Aluminum: Per 5052-H34 per QQ-A-250/8b Tight Joint on Outside Diameter Description and Tol. SPACER FOR #4 #6 #8 I.D. ±.005 .125 .151 .178 O.D. —±.007 .167 .193 .232 L Length .187 .250 .312 .375 .437 .500 .625 .750 .875 1.000 1.250 1.500 1.750 2.000 #4 Screw CAT. NO. 397 398 399 400 401 402 403 418 419 420 421 422 MATERIALS: Brass: ASTM-B16, Nickel plate (QQ-N-290) Aluminum: Iridite Finish (MIL-C-5541) #6 Screw CAT. NO. #8 Screw CAT. NO. 405 406 407 408 409 410 425 426 427 428 429 430 412 413 414 415 416 417 432 433 434 435 436 437 438 BLIND CAPTIVE NUTS — PRESS FIT MOUNT CHASSIS, PANELS, HEAT SINKS, SOCKETS MATERIAL: Molded Nylon with Brass threaded insert. • EASY ASSEMBLY • DAMPENS VIBRATION • ELIMINATES INSULATING WASHER • HI-DIELCTRIC STRENGTH A unique reusable fastener made of NYLON which contains a threaded brass nut. Finger pressure or light tap seals it in a pre-drilled hole. The nut is drawn up causing a Nylon bulge behind the workpiece. Screw may be removed or replaced. THREAD 4-40 6-32 8-32 CAT. NO. 4341 4342 4343 "H" HOLE SIZE REQ/D. .250 .312 .406 L LENGTH .125 .250 .375 .500 .625 .750 .875 1.000 1.500 2.000 .125 .250 .375 .500 .625 .750 .875 1.000 1.500 2.000 .125 .250 .375 .500 .625 .750 .875 1.000 1.500 2.000 HOLE .120 .120 .120 .120 .120 .120 .120 .120 .120 .120 .140 .140 .140 .140 .140 .140 .140 .140 .140 .140 .171 .171 .171 .171 .171 .171 .171 .171 .171 .171 BRASS ALUMINUM CAT. NO. 1909 1454A 1454B 1454C 1919 1454D 1920 1545E 1924 1925 1934 1457A 1457B 1457C 1935 1957D 1936 1457E 1937 1938 1942 1480 1481 1482 2032 1483 2033 1484 2034 2035 CAT. NO. 2036 3457 3458 3459 2314 3460 3402 3461 3462 3463 3403 3464 3465 3466 3429 3467 3438 3468 3469 3470 4258 3471 3472 3473 4259 3474 4260 3475 3476 3477 CLEARENCE HOLE: • .120 for #4 screw • .140 for #6 screw • .171 for #8 screw ROUND SWAGE CLEAR SPACERS MATERIAL: Brass, ASTM-B16, Nickel plate (QQ-N-290) IDEAL SHEET THICKNESS .047 .078 .093 CLEARENCE HOLE: • .120 for #4 screw • .140 for #6 screw T .030 .030 .030 A .312 .375 .500 METRIC HEX THREADED STANDOFFS A comprehensive range of precision made metric hex spacers. MATERIAL: Brass, ASTM-B16, Nickel plated (QQ-N-290) CAT. NO. 5060-2 5060-3 5061-2 5061-3 5062-2 5062-3 5063-2 5063-3 5064-2 5064-3 5065-2 5065-3 H HEIGHT .250 .250 .375 .375 .500 .500 .250 .250 .375 .375 .500 .500 FOR PANEL THICKNESS 1/16 3/32 1/16 3/32 1/16 3/32 1/16 3/32 1/16 3/32 1/16 3/32 C HOLE .120 .120 .120 .120 .120 .120 .140 .140 .140 .140 .140 .140 L .109 .141 .109 .141 .109 .141 .109 .141 .109 .141 .109 .141 HEX STAINLESS THREADED STANDOFFS MATERIAL: Stainless Steel per ASTM-A581/A582, Class 303 • Corrosion Resistant L Length Inches 5mm HEX* CAT. NO. 4390 4391 4392 4393 4394 46 5.5mm HEX* "L" 5mm 10mm 15mm 20mm 25mm CAT. NO. 4395 4396 4397 4398 4399 "L" 5mm 10mm 15mm 20mm 25mm 1/4 (.250) 3/8(.375) 1/2 (.500) 3/4 (.750) 1 (1.000) 1 1/2 (1.500) 2 (2.000) 4-40 Thread CAT. NO. 6-32 Thread CAT. NO. 8-32 Thread CAT. NO. 1921 1921A 1921B 1921C 1921D 1921E 1921F 1922 1922A 1922B 1922C 1922D 1922E 1922F 1923 1923A 1923B 1923C 1923D 1923E 1923F • 4-40 thread on 1/2" and over tapped 1/4" each end • 6-32 & 8-32 thread on 1" and over tapped 3/8" each end 31-07 20th Road • Astoria, New York 11105-2017 • (718) 956-8900 • FAX (718) 956-9040 e-mail: kec@keyelco.com • WebSite: keyelco.com
很抱歉,暂时无法提供与“4395”相匹配的价格&库存,您可以联系我们找货
