910-280
910-280
    BIVAR
    ROUND SPACER 0.091" NYLON 7.11MM
910-280 数据手册
nylon tubular spacers Nylon Spacers for Standard Screw Sizes • Screw Spacers give users an extremely wide selection of tubular spacers for PCB support in almost any elevation • Six basic ID/OD combinations with heights ranging from 1/16" (1.6mm) through 1.0" (25.4mm), are available from factory stock or within two weeks • Such a broad selection permits the user to choose the most suitable sizes for strength, elevation and ease of assembly Material Specifications: Natural Nylon, per ASTM D4066 PA225, UL Rated 94V-2 Oxygen Rating Index: Over 23% Standard Drawing Tolerances: (unless otherwise indicated) O.D. +_ .005 (.13) I.D. +_ .005 (.13) "H" Dim: 1/16-1/2 (1.6-12.7) is +_.005 (.13) "H" Dim: 9/16-1.0 (14.3-25.4) is +_ .010 (.25) 99XX Series Series 9913 9910 9908 Screw Size #2 #2 #4 Color: Natural I.D. .091 (2.3) .091 (2.3) .125 (3.2) O.D. .187 (4.7) .250 (6.4) .187 (4.7) 9911 #4 .125 (3.2) .250 (6.4) 9905 #6 .147 (3.7) .250 (6.4) 9912 #8 .171 (4.3) .250 (6.4) "H" DIM. Dash No. Price Code 1/16 (1.6) -062 1/8 (3.2) -125 U U 3/16 (4.8) -187 U 1/4 (6.4) -250 U 5/16 (7.9) -312 U 3/8 (9.5) -375 V 7/16 (11.1) -437 V 1/2 (12.7) -500 V 9/16 (14.3) -562 V 5/8 (15.9) -625 W 3/4 (19.1) -750 W 13/16 (20.6) -812 X 7/8 (22.2) -875 X 15/16 (23.8) -937 X 1.0 (25.4) -1000 X Examples: 9913-250 is for a #2 Screw, O.D. is .187 (4.7) Length is 1/4 (6.4), price code U. 9910-125 is for a #2 Screw, O.D. is .250 (6.4) Length is 1/8 (3.2), price code U. 65 www.bivar.com cage code (FSCM) 32559 © copyright 2004 Bivar Inc. nylon tubular spacers Nylon Spacers for Standard Screw Sizes • Screw Spacers give users an extremely wide selection of tubular spacers for PCB support in almost any elevation • Six basic ID/OD combinations with heights ranging from 1/16" (1.6mm) through 1.0" (25.4mm), are available from factory stock or within two weeks • Such a broad selection permits the user to choose the most suitable sizes for strength, elevation and ease of assembly Material Specifications: Natural Nylon, per ASTM D4066 PA225, UL Rated 94V-2 Oxygen Rating Index: Over 23% Standard Drawing Tolerances: (unless otherwise indicated) O.D. +_.005 (.13) I.D. +_ .005 (.13) "H" Dim: 1/16-1/2 (1.6-12.7) is +_.005 (.13) "H" Dim: 9/16-1.0 (14.3-25.4) is +_ .010 (.25) mm Chart Series 1mm .039 2mm .079 3mm .118 4mm .158 5mm .197 6mm .236 7mm .276 8mm .315 9mm .354 10mm .394 9905 9905-1mm 9905-2mm 9905-3mm 9905-4mm 9905-5mm 9905-6mm 9905-7mm 9905-8mm 9905-9mm 9905-10mm 9905-11mm 9905-12mm 9908 9908-1mm 9908-2mm 9908-3mm 9908-4mm 9908-5mm 9908-6mm 9908-7mm 9908-8mm 9908-9mm 9908-10mm 9908-11mm 9908-12mm 9910 9910-1mm 9910-2mm 9910-3mm 9910-4mm 9910-5mm 9910-6mm 9910-7mm 9910-8mm 9910-9mm 9910-10mm 9910-11mm 9910-12mm 9911 9911-1mm 9911-2mm 9911-3mm 9911-4mm 9911-5mm 9911-6mm 9911-7mm 9911-8mm 9911-9mm 9911-10mm 9911-11mm 9911-12mm 9912 9912-1mm 9912-2mm 9912-3mm 9912-4mm 9912-5mm 9912-6mm 9912-7mm 9912-8mm 9912-9mm 9912-10mm 9912-11mm 9912-12mm 9913 9913-1mm 9913-2mm 9913-3mm 9913-4mm 9913-5mm 9913-6mm 9913-7mm 9913-8mm 9913-9mm 9913-10mm 9913-11mm 9913-12mm Price Code U U U U U U U V V V Series 13mm .512 14mm .551 15mm .591 16mm .630 17mm .669 18mm .709 9905 9905-13mm 9905-14mm 9905-15mm 9905-16mm 9905-17mm 9905-18mm 9908 9908-13mm 9908-14mm 9908-15mm 9908-16mm 9908-17mm 9908-18mm 9910 9910-13mm 9910-14mm 9910-15mm 9910-16mm 9910-17mm 9910-18mm 9911 9911-13mm 9911-14mm 9911-15mm 9911-16mm 9911-17mm 9911-18mm 9912 9912-13mm 9912-14mm 9912-15mm 9912-16mm 9912-17mm 9912-18mm 9913 9913-13mm 9913-14mm 9913-15mm 9913-16mm 9913-17mm 9913-18mm Price Code V V W W W W Series 19mm .748 20mm .787 21mm .827 22mm .868 23mm .906 24mm .945 9905 9905-19mm 9905-20mm 9905-21mm 9905-22mm 9905-23mm 9905-24mm 9908 9908-19mm 9908-20mm 9908-21mm 9908-22mm 9908-23mm 9908-24mm 9910 9910-19mm 9910-20mm 9910-21mm 9910-22mm 9910-23mm 9910-24mm 9911 9911-19mm 9911-20mm 9911-21mm 9911-22mm 9911-23mm 9911-24mm 9912 9912-19mm 9912-20mm 9912-21mm 9912-22mm 9912-23mm 9912-24mm 9913 9913-19mm 9913-20mm 9913-21mm 9913-22mm 9913-23mm 9913-24mm Price Code W X X X X X cage code (FSCM) 32559 © copyright 2004 Bivar Inc. 11mm .433 V 12mm .472 V www.bivar.com 66 self-retaining pvc screw spacers • Simple Pre-Assembly Convenience Saves Handling • Firm Retention Assured • 5 Standard Sizes in Lengths from .050" - 1.250" (.76 - 31.8) in .005" (.127) Increments Ribbed inner-wall design assures a snug fit onto #4, #6 and #8 screws, or M3 and M4 metric screws enabling the spacers to remain preassembled during handling and assembly. The SRS Series provides a dependable solution for otherwise awkward assembly steps and lost assembly time. Ordering Information: SRS X XXX Material Specifications: Gray Rigid PVC material, UL Rated 94V-0 Oxygen Rating Index: Over 45% Standard Drawing Tolerances: (unless otherwise indicated) O.D. +_ .005 (.13) I.D. +_ .005 (.13) "H" Dim: 1/16-1/2 (1.6-12.7) is +_.005 (.13) "H" Dim: 9/16-1.0 (14.3-25.4) is +_ .010 (.25) SRS Series I.D. "H" DIM. SRS-1 4 .107 (2.7) .142 (3.6) SRS-2 6 (M3.5) .131 (3.3) .174 (4.4) .050-1.250 (1.3-31.8) SRS-3 8 .155 (3.9) .177 (4.5) .050-1.250 (1.3-31.8) SRS-4 M3 .113 (2.9) .144 (3.7) .050-1.250 (1.3-31.8) SRS-5 M4 .149 (3.9) .185 (4.7) .050-1.250 (1.3-31.8) "H" Dimension .050-1.250 (1.3-31.8) Price Code SRS-1 thru SRS-5 .050-.075 (1.3-1.9) W .080-.150 (2.0-3.8) X .155-.230 (4.0-5.8) X .235-.310 (6.0-7.9) Y .315-.380 (8.0-9.7) Z .385-.495 (9.8-12.6) ZZ .500-.750 (12.7-19.1) ZZZ .755-1.250 (19.2-31.8) ZZZZ www.bivar.com Series Color: Gray Part No. Screw Size Minor I.D. 67 Length Expressed in Inches (Must be even multiples of .005") or whole millimeters (example: 2mm) 0.750 = 750 0.050 = 050 1.250 = 1.250 0.100 = 100 Examples: SRS-1-240 is price code Y SRS-5-410 is price code ZZ SRS-3-900 is price code ZZZZ cage code (FSCM) 32559 © copyright 2004 Bivar Inc. self-retaining pvc screw spacers • Simple Pre-Assembly Convenience Saves Handling • Firm Retention Assured • 5 Standard Sizes in Lengths from .050" - 1.250" (.76 - 31.8) in .005" (.127) Increments Material Specifications: Gray Rigid PVC material, UL Rated 94V-0 Oxygen Rating Index: Over 45% Standard Drawing Tolerances: (unless otherwise indicated) O.D. +_ .005 (.13) I.D. +_ .005 (.13) "H" Dim: 1/16-1/2 (1.6-12.7) is +_.005 (.13) "H" Dim: 9/16-1.0 (14.3-25.4) is +_ .010 (.25) mm Chart Screw Size 2mm .079 3mm .118 4mm .158 5mm .197 6mm .236 7mm .276 8mm .315 SRS-1 4 SRS-1-2mm SRS-1-3mm SRS-1-4mm SRS-1-5mm SRS-1-6mm SRS-1-7mm SRS-1-8mm SRS-2 6 (M3.5) SRS-2-2mm SRS-2-3mm SRS-2-4mm SRS-2-5mm SRS-2-6mm SRS-2-7mm SRS-2-8mm SRS-3 8 SRS-3-2mm SRS-3-3mm SRS-3-4mm SRS-3-5mm SRS-3-6mm SRS-3-7mm SRS-3-8mm SRS-4 M3 SRS-4-2mm SRS-4-3mm SRS-4-4mm SRS-4-5mm SRS-4-6mm SRS-4-7mm SRS-4-8mm SRS-5 M4 SRS-5-2mm SRS-5-3mm SRS-5-4mm SRS-5-5mm SRS-5-6mm SRS-5-7mm SRS-5-8mm W W X X Y Y Z Screw Size 9mm .354 10mm .394 11mm .433 12mm .472 13mm .512 14mm .551 15mm .591 SRS-1 4 SRS-1-9mm SRS-1-10mm SRS-1-11mm SRS-2 6 (M3.5) SRS-2-9mm SRS-2-10mm SRS-2-11mm SRS-2-12mm SRS-2-13mm SRS-2-14mm SRS-2-15mm SRS-2-16mm SRS-3 8 SRS-3-9mm SRS-3-10mm SRS-3-11mm SRS-3-12mm SRS-3-13mm SRS-3-14mm SRS-3-15mm SRS-3-16mm SRS-4 M3 SRS-4-9mm SRS-4-10mm SRS-4-11mm SRS-4-12mm SRS-4-13mm SRS-4-14mm SRS-4-15mm SRS-4-16mm SRS-5 M4 SRS-5-9mm SRS-5-10mm SRS-5-11mm SRS-5-12mm SRS-5-13mm SRS-5-14mm SRS-5-15mm SRS-5-16mm Series Price Code Series Price Code 16mm .630 SRS-1-12mm SRS-1-13mm SRS-1-14mm SRS-1-15mm SRS-1-16mm Z ZZ ZZ ZZ ZZZ ZZZ ZZZ ZZZ Screw Size 17mm .669 18mm .709 19mm .748 20mm .787 21mm .827 22mm .868 23mm .906 24mm .945 SRS-1 4 SRS-1-17mm SRS-1-18mm SRS-1-19mm SRS-2 6 (M3.5) SRS-2-17mm SRS-2-18mm SRS-2-19mm SRS-2-20mm SRS-2-21mm SRS-2-22mm SRS-2-23mm SRS-2-24mm SRS-3 8 SRS-3-17mm SRS-3-18mm SRS-3-19mm SRS-3-20mm SRS-3-21mm SRS-3-22mm SRS-3-23mm SRS-3-24mm SRS-4 M3 SRS-4-17mm SRS-4-18mm SRS-4-19mm SRS-4-20mm SRS-4-21mm SRS-4-22mm SRS-4-23mm SRS-4-24mm SRS-5 M4 SRS-5-17mm SRS-5-18mm SRS-5-19mm SRS-5-20mm SRS-5-21mm SRS-5-22mm SRS-5-23mm SRS-5-24mm Series Price Code ZZZ ZZZ cage code (FSCM) 32559 © copyright 2004 Bivar Inc. ZZZ SRS-1-20mm SRS-1-21mm SRS-1-22mm SRS-1-23mm SRS-1-24mm ZZZZ ZZZZ ZZZZ ZZZZ ZZZZ www.bivar.com 68 co-extruded self retaining screw spacers • Unique Bi-Material Design, Patented • Tight Fit with Low Insertion Force • Works with #4 - #8 (M3-M4) Screw Sizes CRS-1 #4 Screws CRS-2 #M3 Screws CRS-3 #6 Screws CRS-4 #M4, #8 Screws CRS Spacers provide precise spacing of electro-mechanical assemblies and eliminate shakes and rattles associated with movement in high-vibration PC-board applications, such as large rack-mounted fan cooling trays and multiple trays found in telecommunications, industrial networks, and avionics applications. Designed with Bivar's patent-pending technology, these co-extruded self retaining screw spacers feature a soft pliable inner lining with a hard outer shell composed of UL rated 94V-0 PVC material. This unique design requires only a minimal amount of manual insertion force to cause the spacer's soft inside material to conform to the threads of the screw. The cushioning of the encapsulated screw and self-tapping design structure secures the screw in place, ensuring tight retention. Material Specifications: Natural, Rigid and Semi-Rigid PVC material, UL Rated 94V-0 Oxygen Rating Index: Over 45% Standard Drawing Tolerances: (unless otherwise indicated) O.D. +_ .005 (.13) I.D. +_ .005 (.13) "H" Dim: 1/16-1/2 (1.6-12.7) is +_.005 (.13) "H" Dim: 9/16-1.0 (14.3-25.4) is +_ .010 (.25) "H" Dimension Price Code CRS-1 thru CRS-4 .050-.075 (1.25-1.9) W .080-.150 (2.0-3.8) X .155-.230 (4.0-5.8) X .235-.310 (6.0-7.9) Y .315-.380 (8.0-9.7) Z .385-.495 (9.8-12.6) ZZ .500-.750 (12.7-19.1) ZZZ .755-1.250 (19.2-31.8) ZZZZ Ordering Information: CRS X XXX Length Expressed in Inches (Must be even multiples of .005") or whole millimeters (example: 2mm) 0.750 = 750 0.050 = 050 1.250 = 1.250 0.100 = 100 Series 69 www.bivar.com cage code (FSCM) 32559 © copyright 2004 Bivar Inc. nylon tubular spacers Universal Spacers for Discrete Components • 4,182 Standard Sizes for “just Right” Fit • Makes Solder Filleting and Board Cleaning More Effective Universal Spacers give users an extremely wide selection of tubular spacers for mounting PCB discrete devices in any lead pattern and elevation. Seventeen basic I.D./O.D. combinations with heights ranging from .030" (.76) through 1.250" (31.8), in .005" (.13) increments are available from factory stock or within two weeks. Such a broad selection permits the user to choose the most suitable sizes for strength, elevation and ease of assembly, as well as providing for proper filleting and cleaning. Ordering Information: 9XX XXX Length Expressed in Inches (Must be even multiples of .005") or whole millimeters (example: 2mm) 0.030 = 030 0.750 = 750 0.100 = 100 1.250 = 1.250 Series 900 Series Series 901 Color: Natural "H" DIM. I.D. O.D. A55485/06 M38527/06 .030-1.250 (.76-31.8) .028 (.71) .085 (2.2) -029N "H" Dimension Price Code for 901, 902, 937, 938, 939 Price Code for 903, 904, 905, 906, 907, 908 910, 911, 912, 913, 940, 941 902 .030-1.250 (.76-31.8) .032 (.81) .125 (3.2) -031N .030-.075 (.76-1.9) U W 903 .030-1.250 (.76-31.8) .047 (1.2) .156 (4.0) -034N .080-.150 (2.0-3.8) V W 904 .030-1.250 (.76-31.8) .063 (1.6) .187 (4.7) -036N .155-.230 (4.0-5.8) W X 905 .030-1.250 (.76-31.8) .147 (3.7) .250 (6.4) -041N .235-.310 (6.0-7.9) X Y 906 .030-1.250 (.76-31.8) .085 (2.2) .148 (3.8) -033N .315-.380 (8.0-9.7) Y Z 907 .030-1.250 (.76-31.8) .105 (2.7) .167 (4.2) -035N .385-.495 (9.8-12.6) Z ZZ 908 .030-1.250 (.76-31.8) .125 (3.2) .187 (4.7) -038N .500-.750 (12.7-19.1) ZZ ZZZ 910 .030-1.250 (.76-31.8) .091 (2.3) .250 (6.4) -039N .755-1.250 (19.2-31.8) ZZZZ ZZZZ 911 .030-1.250 (.76-31.8) .125 (3.2) .250 (6.4) - 912 .030-1.250 (.76-31.8) .171 (4.3) .250 (6.4) -042N 913 .030-1.250 (.76-31.8) .091 (2.3) .187 (4.7) -037N 937 .030-1.250 (.76-31.8) .090 (2.3) .125 (3.2) - 938 .030-1.250 (.76-31.8) .032 (.81) .085 (2.2) -030N Examples: 901-050 is price code U 903-120 is price code W 902-100 is price code V 901-250 is price code X 939 .030-1.250 (.76-31.8) .047 (1.2) .125 (3.2) -032N 940 .030-1.250 (.76-31.8) .063 (1.6) .156 (4.0) - 941 .030-1.250 (.76-31.8) .135 (3.4) .230 (5.8) - cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 70 nylon tubular spacers Universal Spacers for Discrete Components • 4,182 Standard Sizes for “just Right” Fit • Makes Solder Filleting and Board Cleaning More Effective Material Specifications: Natural Nylon, per ASTM D4066 PA225 UL Rated 94V-2 Oxygen Rating Index: Over 23% Standard Drawing Tolerances: O.D. +_ .005 (.13) I.D. +_ .005 (.13) "H" Dim: .030 - .500 (.76 - 12.7) is +_ .005 (.13) "H" Dim: .505 - .750 (12.8 - 19.1) is +_ .008 (.20) "H" Dim: .755 - 1.250 (19.2 - 31.8) is +_ .015 (.38) mm Chart 1mm .039 2mm .079 3mm .118 4mm .158 5mm .197 6mm .236 7mm .276 8mm .315 9mm .354 10mm .394 11mm .433 12mm .472 901 901-1mm 901-2mm 901-3mm 901-4mm 901-5mm 901-6mm 901-7mm 901-8mm 901-9mm 901-10mm 901-11mm 901-12mm 902 902-1mm 902-2mm 902-3mm 902-4mm 902-5mm 902-6mm 902-7mm 902-8mm 902-9mm 902-10mm 902-11mm 902-12mm 937 937-1mm 937-2mm 937-3mm 937-4mm 937-5mm 937-6mm 937-7mm 937-8mm 937-9mm 937-10mm 937-11mm 937-12mm 938 938-1mm 938-2mm 938-3mm 938-4mm 938-5mm 938-6mm 938-7mm 938-8mm 938-9mm 938-10mm 938-11mm 938-12mm 939 939-1mm 939-2mm 939-3mm 939-4mm 939-5mm 939-6mm 939-7mm 939-8mm 939-9mm 939-10mm 939-11mm 939-12mm U V V W W X X Y Y Z Z Z 1mm .039 2mm .079 3mm .118 4mm .158 5mm .197 6mm .236 7mm .276 8mm .315 9mm .354 10mm .394 11mm .433 12mm .472 903 903-1mm 903-2mm 903-3mm 903-4mm 903-5mm 903-6mm 903-7mm 903-8mm 903-9mm 903-10mm 903-11mm 903-12mm 904 904-1mm 904-2mm 904-3mm 904-4mm 904-5mm 904-6mm 904-7mm 904-8mm 904-9mm 904-10mm 904-11mm 904-12mm 905 905-1mm 905-2mm 905-3mm 905-4mm 905-5mm 905-6mm 905-7mm 905-8mm 905-9mm 905-10mm 905-11mm 905-12mm 906 906-1mm 906-2mm 906-3mm 906-4mm 906-5mm 906-6mm 906-7mm 906-8mm 906-9mm 906-10mm 906-11mm 906-12mm 907 907-1mm 907-2mm 907-3mm 907-4mm 907-5mm 907-6mm 907-7mm 907-8mm 907-9mm 907-10mm 907-11mm 907-12mm 908 908-1mm 908-2mm 908-3mm 908-4mm 908-5mm 908-6mm 908-7mm 908-8mm 908-9mm 908-10mm 908-11mm 908-12mm 910 910-1mm 910-2mm 910-3mm 910-4mm 910-5mm 910-6mm 910-7mm 910-8mm 910-9mm 910-10mm 910-11mm 910-12mm 911 911-1mm 911-2mm 911-3mm 911-4mm 911-5mm 911-6mm 911-7mm 911-8mm 911-9mm 911-10mm 911-11mm 911-12mm 912 912-1mm 912-2mm 912-3mm 912-4mm 912-5mm 912-6mm 912-7mm 912-8mm 912-9mm 912-10mm 912-11mm 912-12mm 913 913-1mm 913-2mm 913-3mm 913-4mm 913-5mm 913-6mm 913-7mm 913-8mm 913-9mm 913-10mm 913-11mm 913-12mm 940 940-1mm 940-2mm 940-3mm 940-4mm 940-5mm 940-6mm 940-7mm 940-8mm 940-9mm 940-10mm 940-11mm 940-12mm 941 941-1mm 941-2mm 941-3mm 941-4mm 941-5mm 941-6mm 941-7mm 941-8mm 941-9mm 941-10mm 941-11mm 941-12mm W W W X X Y Y Z Z ZZ ZZ ZZ Series Price Code Series Price Code 71 1mm thru 12mm www.bivar.com cage code (FSCM) 32559 © copyright 2004 Bivar Inc. nylon tubular spacers Universal Spacers for Discrete Components • 4,182 Standard Sizes for “just Right” Fit • Makes Solder Filleting and Board Cleaning More Effective Material Specifications: Natural Nylon, per ASTM D4066 PA225 UL Rated 94V-2 Oxygen Rating Index: Over 23% Standard Drawing Tolerances: O.D. +_ .005 (.13) I.D. +_ .005 (.13) "H" Dim: .030 - .500 (.76 - 12.7) is +_ .005 (.13) "H" Dim: .505 - .750 (12.8 - 19.1) is +_ .008 (.20) "H" Dim: .755 - 1.250 (19.2 - 31.8) is +_.015 (.38) mm Chart 13mm thru 24mm 13mm .512 14mm .551 15mm .591 16mm .630 17mm .669 18mm .709 19mm .748 20mm .787 21mm .827 22mm .866 23mm .906 24mm .945 901 901-13mm 901-14mm 901-15mm 901-16mm 901-17mm 901-18mm 901-19mm 901-20mm 901-21mm 901-22mm 901-23mm 901-24mm 902 902-13mm 902-14mm 902-15mm 902-16mm 902-17mm 902-18mm 902-19mm 902-20mm 902-21mm 902-22mm 902-23mm 902-24mm 937 937-13mm 937-14mm 937-15mm 937-16mm 937-17mm 937-18mm 937-19mm 937-20mm 937-21mm 937-22mm 937-23mm 937-24mm 938 938-13mm 938-14mm 938-15mm 938-16mm 938-17mm 938-18mm 938-19mm 938-20mm 938-21mm 938-22mm 938-23mm 938-24mm 939 939-13mm 939-14mm 939-15mm 939-16mm 939-17mm 939-18mm 939-19mm 939-20mm 939-21mm 939-22mm 939-23mm 939-24mm ZZ ZZ ZZ ZZ ZZ ZZ ZZ ZZZZ ZZZZ ZZZZ ZZZZ ZZZZ 13mm .512 14mm .551 15mm .591 16mm .630 17mm .669 18mm .709 19mm .748 20mm .787 21mm .827 22mm .866 23mm .906 24mm .945 903 903-13mm 903-14mm 903-15mm 903-16mm 903-17mm 903-18mm 903-19mm 903-20mm 903-21mm 903-22mm 903-23mm 903-24mm 904 904-13mm 904-14mm 904-15mm 904-16mm 904-17mm 904-18mm 904-19mm 904-20mm 904-21mm 904-22mm 904-23mm 904-24mm 905 905-13mm 905-14mm 905-15mm 905-16mm 905-17mm 905-18mm 905-19mm 905-20mm 905-21mm 905-22mm 905-23mm 905-24mm 906 906-13mm 906-14mm 906-15mm 906-16mm 906-17mm 906-18mm 906-19mm 906-20mm 906-21mm 906-22mm 906-23mm 906-24mm 907 907-13mm 907-14mm 907-15mm 907-16mm 907-17mm 907-18mm 907-19mm 907-20mm 907-21mm 907-22mm 907-23mm 907-24mm 908 908-13mm 908-14mm 908-15mm 908-16mm 908-17mm 908-18mm 908-19mm 908-20mm 908-21mm 908-22mm 908-23mm 908-24mm 910 910-13mm 910-14mm 910-15mm 910-16mm 910-17mm 910-18mm 910-19mm 910-20mm 910-21mm 910-22mm 910-23mm 910-24mm 911 911-13mm 911-14mm 911-15mm 911-16mm 911-17mm 911-18mm 911-19mm 911-20mm 911-21mm 911-22mm 911-23mm 911-24mm 912 912-13mm 912-14mm 912-15mm 912-16mm 912-17mm 912-18mm 912-19mm 912-20mm 912-21mm 912-22mm 912-23mm 912-24mm 913 913-13mm 913-14mm 913-15mm 913-16mm 913-17mm 913-18mm 913-19mm 913-20mm 913-21mm 913-22mm 913-23mm 913-24mm 940 940-13mm 940-14mm 940-15mm 940-16mm 940-17mm 940-18mm 940-19mm 940-20mm 940-21mm 940-22mm 940-23mm 940-24mm 941 941-13mm 941-14mm 941-15mm 941-16mm 941-17mm 941-18mm 941-19mm 941-20mm 941-21mm 941-22mm 941-23mm 941-24mm ZZZ ZZZ ZZZ ZZZ ZZZ ZZZ ZZZ ZZZZ ZZZZ ZZZZ ZZZZ ZZZZ Series Price Code Series Price Code cage code (FSCM) 32559 © copyright 2004 Bivar Inc. www.bivar.com 72
910-280 价格&库存
很抱歉,暂时无法提供与“910-280”相匹配的价格&库存,您可以联系我们找货
