ROB-13065
ROB-13065
    SPARKFUNELECTRONICS
    SLIPRING-12WIRE(2A)
ROB-13065 数据手册
SNM022A-12 – Capsule Slip Rings SNM022A-12 Body Diameter: 22.00mm , Length: 26mm 12 circuits * 2A version The SNM022A-12, with 12 wires and compact 22.00mm body diameter, which we call our “medium”,uses SenRing's fiber brush technology which offers several advantages over conventional slip ring contacts including multiple points of contact per brush bundle, low contact force per fiber and low contact wear rates. SNM022A-12 Dimensions Flange mounted: Features • Gold-on-gold contacts • Compatible with data bus protocols • Transfers analog and digital signals,Ethernet,USB,RS,Canbus, Fire wire signal. • Speeds up to 250 rpm continuous • Precision ball bearings meet or exceed life requirements for most commercial applications • Smooth running, Low torque, Compact dimemsions Type Application • CCTV pan / tilt camera mounts • Electrical test equipment | Laboratory equipment • Manufacturing and process | rotary index tables • Medical equipment | Robotics • | control equipment Miniature cable reels Lead Wire Color Code Circuit No. 1 2 3 4 5 5 Color BLACK BROWN RED ORANGE YELLOW GREEN Circuit No. 7 8 9 10 11 12 Color BLUE PURPLE GREY WHITE PINK LIGHT BLUE SenRing Electroncis • www.senring.com Email: sales@senring.com
ROB-13065 价格&库存
很抱歉,暂时无法提供与“ROB-13065”相匹配的价格&库存,您可以联系我们找货
