ROB-13064
ROB-13064
    SPARKFUNELECTRONICS
    SLIPRING-6WIRE(2A)
ROB-13064 数据手册
SNM022A-06 – Capsule Slip Rings SNM022A-06 Body Diameter: 22.00mm , Length: 19mm 6 circuits*2A version The SNM012A-06, with 6 wires and compact 22.00mm body diameter, which we call our “medium”,uses SenRing's fiber brush technology which offers several advantages over conventional slip ring contacts including multiple points of contact per brush bundle, low contact force per fiber and low contact wear rates. SNM022A-06 Dimensions Flange mounted: Features • Gold-on-gold contacts • Compatible with data bus protocols • Transfers analog and digital signals,Ethernet,USB,RS,Canbus, Fire wire signal. • Speeds up to 250 rpm continuous • Precision ball bearings meet or exceed life requirements for most commercial applications • Smooth running, Low torque, Compact dimemsions Type Application • CCTV pan / tilt camera mounts • Electrical test equipment | Laboratory equipment • Manufacturing and process | rotary index tables • Medical equipment | Robotics • Miniature cable reels | control equipment Lead Wire Color Code Circuit No. 1 2 3 4 5 5 Color BLK BROWN RED ORG YEL GREEN SenRing Electroncis • www.senring.com Email: sales@senring.com
ROB-13064 价格&库存
很抱歉,暂时无法提供与“ROB-13064”相匹配的价格&库存,您可以联系我们找货
