MicroRax - Elbow Hinge
PRT-11 292
images are CC BY-NC-SA 3.0
Description: MicroRAX is a miniature light-weight T-Slot style building system.
Suitable for use on your desktop or bench top to build science, engineering, or
advanced hobby and DIY projects.
The elbow hinge allows beams to pivot on the edge of the profile with about 180
degrees of rotation. In other words, at fully-closed the two beams will be parallel to
each other. The bushing that connects the joint works with a 3mm OD shaft if you
want to run a shaft through several joints.
We are selling these as single joints so you’ll need two of these to make a full elbow
(one per side).
Features:
• 180 degrees of rotation
• Bushing works with 3mm OD shafting
• Need 2 to build a complete elbow
https://www.sparkfun.com/products/11292
2/3/2016
很抱歉,暂时无法提供与“PRT-11292”相匹配的价格&库存,您可以联系我们找货
