Aluminum Beam - 3.85" (pair)
ROB - 12481
images are CC BY-NC-SA 3.0
Description: These aluminum beams are great for making unique links and
connections in your Actobotics project thanks to 11 thru-holes running its length and
are sold in packs of two. Each beam has a length of 3.85", a width of 0.375", a
thickness of 0.25", and utilize the 0.77" hub pattern.
Actobotics is a robotics building system based around extruded aluminum channels,
gears, precision shafts, and ball bearings. Thanks to the two standardized hole
patterns, nearly all Actobotics components can be intuitively connected together. The
wide range of components makes building complex electromechanical prototypes or
finished projects a reality.
Note: The length of these beams is calculated from the center of each thru-hole at
opposite ends, the over-all length is 4.225".
Dimensions:
Length - 3.85"
Width - 0.375"
Thickness - 0.25"
Hub Pattern - 0.77"
https://www.sparkfun.com/products/12481
2/15/2016
很抱歉,暂时无法提供与“ROB-12481”相匹配的价格&库存,您可以联系我们找货
