Shaft Coupler - 3/8" to 3/8"
ROB - 12457
images are CC BY-NC-SA 3.0
Description: These stainless steel shaft couplers allow you to couple two size shafts
together. They can be used for connecting motor shafts to drive shafts, or two
different-sized shafts. These shaft couplers have a length of 0.75”, a outer diameter of
0.60”, and couple 3/8” to 3/8" shafts.
Actobotics is a robotics building system based around extruded aluminum channels,
gears, precision shafts, and ball bearings. Thanks to the two standardized hole
patterns, nearly all Actobotics components can be intuitively connected together. The
wide range of components makes building complex electromechanical prototypes or
finished projects a reality.
Dimensions:
Length - 0.75”
Diameter - 0.60”
Bore A ID - 3/8”
Bore B ID - 3/8"
https://www.sparkfun.com/products/12457
1/15/2016
很抱歉,暂时无法提供与“ROB-12457”相匹配的价格&库存,您可以联系我们找货
