ROB-12245
ROB-12245
    SPARKFUNELECTRONICS
    BALLBEARINGHUB
ROB-12245 数据手册
 Ball Bearing Hub ROB - 12245  images are CC BY-NC-SA 3.0 Description: These ball bearing hubs from Actobotics are great when you need to securely fasten a free-spinning shaft to a stationary channel to drive a pulley, wheel, or other rotating device. Each ball bearing hub has an outer diameter of 1", a bearing bore of 0.25", a thickness of 0.5", and utilizes the 0.77" hub pattern. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. Dimensions: • • • • OD - 1" Bearing Bore - 0.25" Thickness - 0.5" Hub Pattern - 0.77" https://www.sparkfun.com/products/12245 2/4/2016
ROB-12245 价格&库存
很抱歉,暂时无法提供与“ROB-12245”相匹配的价格&库存,您可以联系我们找货
