ROB-12361
ROB-12361
    SPARKFUNELECTRONICS
    CLAMPINGHUB5MMBORE
ROB-12361 数据手册
  Clamping Hub - 5mm Bore ROB - 12361  images are CC BY-NC-SA 3.0 Description: These clamping hubs are a great and cost-effective choice when attaching hub mount gears or wheels to shafts or tubes and can be a better option than set screw hubs if you don’t want to risk damaging whatever you need clamped. These clamping hubs have a 5mm bore, four 6-32 tapped holes, one 6-32 machine screw for tightening, and utilizes the 0.77" hub pattern. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. Dimensions: • Bore - 5mm • Hub Pattern - 0.77" https://www.sparkfun.com/products/12361 2/4/2016
ROB-12361 价格&库存
很抱歉,暂时无法提供与“ROB-12361”相匹配的价格&库存,您可以联系我们找货
