ROB-12282
ROB-12282
    SPARKFUNELECTRONICS
    BEARINGMNTBLOCKSQR1"BORE
ROB-12282 数据手册
 Bearing Mount - Pillow Block Square (1" Bore) ROB - 12282  images are CC BY-NC-SA 3.0 3D Download: STL, IGES, STEP, Solidworks Description: These square pillow block bearing mounts attach to the inside of a channel and have a ball bearing with a 1” bore for shafts and tubes. These bearing mounts have a width of 1.32”, a thickness of 0.33”, a 1” bore bearing. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. Dimensions: • Width - 1.32” • Thickness - 0.33” • Bore Bearing - 1” https://www.sparkfun.com/products/12282 1/15/2016
ROB-12282 价格&库存
很抱歉,暂时无法提供与“ROB-12282”相匹配的价格&库存,您可以联系我们找货
