ROB-12111
ROB-12111
    SPARKFUNELECTRONICS
    GEARPINIONGEAR20T6MMBORE
ROB-12111 数据手册
 Gear - Pinion Gear (20T; 6mm Bore) ROB - 12111  images are CC BY-NC-SA 3.0 Description: These pinion gears attach to a 6mm D-shaft or gear motor using a setscrew. These gears have 20 teeth with a gear pitch of 32P, an outer diameter of 0.688”, and a bore of 6mm. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. Dimensions: • Teeth - 20T at 32P • OD - 0.688” • Bore - 6mm https://www.sparkfun.com/products/12111 1/15/2016
ROB-12111 价格&库存
很抱歉,暂时无法提供与“ROB-12111”相匹配的价格&库存,您可以联系我们找货
