Gear - Pinion Gear (32T; 0.25" Bore)
ROB - 12476
images are CC BY-NC-SA 3.0
Description: These pinion gears attach to a ¼” D-shaft or gear motor using a
setscrew. They have 32 teeth with a gear pitch of 32P, an outer diameter of 1.063”,
and a bore of 0.25”.
Actobotics is a robotics building system based around extruded aluminum channels,
gears, precision shafts, and ball bearings. Thanks to the two standardized hole
patterns, nearly all Actobotics components can be intuitively connected together. The
wide range of components makes building complex electromechanical prototypes or
finished projects a reality.
Dimensions:
• Teeth - 32T at 32P
• OD - 1.063”
• Bore - 0.25”
https://www.sparkfun.com/products/12476
1/18/2016
很抱歉,暂时无法提供与“ROB-12476”相匹配的价格&库存,您可以联系我们找货
