HNZ256
HNZ256
    B&FFASTENERSUPPLY
    HEXNUT3/16"STEEL2-56
HNZ256 数据手册
Nuts Hex & Square Machine Screw Nuts F H H G G F SQUARE AND HEX MACHINE SCREW NUTS F Nominal Size or Basic Thread Diameter ANSI/ASME B18.6.3 G G1 H Width Across Corners Width Across Flats Square Thickness Hex Basic Max Min Max Min Max Min Max Min 0 0.0600 5/32 0.156 0.150 0.221 0.206 0.180 0.171 0.050 0.043 1 0.0730 5/32 0.156 0.150 0.221 0.206 0.180 0.171 0.050 0.043 2 0.0860 3/16 0.188 0.180 0.265 0.247 0.217 0.205 0.066 0.057 3 0.0990 3/16 0.188 0.180 0.265 0.247 0.217 0.205 0.066 0.057 4 0.1120 1/4 0.250 0.241 0.354 0.331 0.289 0.275 0.098 0.087 5 0.1250 5/16 0.312 0.302 0.442 0.415 0.361 0.344 0.114 0.102 6 0.1380 5/16 0.312 0.302 0.442 0.415 0.361 0.344 0.114 0.102 8 0.1640 11/32 0.344 0.332 0.486 0.456 0.397 0.378 0.130 0.117 10 0.1900 3/8 0.375 0.362 0.530 0.497 0.433 0.413 0.130 0.117 12 0.2160 7/16 0.438 0.423 0.619 0.581 0.505 0.482 0.161 0.148 1/4 0.2500 7/16 0.438 0.423 0.619 0.581 0.505 0.482 0.193 0.178 5/16 0.3125 9/16 0.562 0.545 0.795 0.748 0.650 0.621 0.225 0.208 3/8 0.3750 5/8 0.625 0.607 0.884 0.833 0.722 0.692 0.257 0.239 Description Hex Machine Screw Nut: A six-sided internally threaded fastener with flat tops and chamfered corners. Threads shall be Unified Standard, Class 2B. Square Machine Screw Nut: A four-sided, internally threaded fastener, tops and bottoms flat, without chamfer. Threads shall be Unified coarse thread, Class 2B. Applications/ Advantages Hex Machine Screw Nut: Designed to be used specifically with machine screws. Stainless nuts are used with stainless machine screws where parts are subject to corrosive conditions. Square Machine Screw Nut: Offers a greater bearing surface for wrenching. Material Steel: Any low carbon steel Stainless: 18-8 stainless steel Plating See Appendix-A for plating information. This page prints with a watermark
HNZ256 价格&库存
很抱歉,暂时无法提供与“HNZ256”相匹配的价格&库存,您可以联系我们找货
