NYHN832
NYHN832
    B&FFASTENERSUPPLY
    HEXNUT11/32"NYLON8-32
NYHN832 数据手册
Nylon Fasteners Standard Sizes Hex Nuts F H NYLON HEX NUTS Diameter & Thread Pitch F H Width Across Flats Nut Thickness Max Min Max Min 2-56 0.190 0.170 0.080 0.060 3-48 0.190 0.170 0.080 0.060 4-40 0.260 0.240 0.110 0.090 6-32 0.315 0.295 0.130 0.110 6-40 0.315 0.295 0.130 0.110 8-32 0.345 0.325 0.140 0.120 10-24 0.375 0.355 0.145 0.125 10-32 0.375 0.355 0.145 0.125 12-24 0.435 0.415 0.217 0.197 1/4-20 0.435 0.415 0.245 0.225 1/4-28 0.435 0.415 0.245 0.225 Description A six-sided internally threaded fastener which has chamfered corners on one side only, and a washer face on the opposite side. Applications/ Advantages For use with externally threaded nylon fasteners. Nylon's advantages include: resistance to greases and oils; a low coefficient of friction; ability to maintain its strength when exposed to heat. Material Nylon 6/6 Hardness Rockwell M80 Tensile Strength 12,000 psi. Shear Strength 9,500 psi. Thermal Properties Melting Point: 500° F Continuous Use Temperature: 185° F 186 This page prints with a watermark
NYHN832 价格&库存
很抱歉,暂时无法提供与“NYHN832”相匹配的价格&库存,您可以联系我们找货
