Nuts
Hex &
Square
Machine Screw Nuts
F
H
H
G
G
F
SQUARE
AND
HEX MACHINE SCREW NUTS
F
Nominal Size or Basic
Thread Diameter
ANSI/ASME B18.6.3
G
G1
H
Width Across Corners
Width Across Flats
Square
Thickness
Hex
Basic
Max
Min
Max
Min
Max
Min
Max
Min
5/32
0.156
0.150
0.221
0.206
0.180
0.171
0.050
0.043
1
0.0730
5/32
0.156
0.150
0.221
0.206
0.180
0.171
0.050
0.043
2
0.0860
3/16
0.188
0.180
0.265
0.247
0.217
0.205
0.066
0.057
3
0.0990
3/16
0.188
0.180
0.265
0.247
0.217
0.205
0.066
0.057
4
0.1120
1/4
0.250
0.241
0.354
0.331
0.289
0.275
0.098
0.087
5
0.1250
5/16
0.312
0.302
0.442
0.415
0.361
0.344
0.114
0.102
6
0.1380
5/16
0.312
0.302
0.442
0.415
0.361
0.344
0.114
0.102
8
0.1640
11/32
0.344
0.332
0.486
0.456
0.397
0.378
0.130
0.117
10
0.1900
3/8
0.375
0.362
0.530
0.497
0.433
0.413
0.130
0.117
12
0.2160
7/16
0.438
0.423
0.619
0.581
0.505
0.482
0.161
0.148
1/4
0.2500
7/16
0.438
0.423
0.619
0.581
0.505
0.482
0.193
0.178
5/16
0.3125
9/16
0.562
0.545
0.795
0.748
0.650
0.621
0.225
0.208
3/8
0.3750
5/8
0.625
0.607
0.884
0.833
0.722
0.692
0.257
0.239
Description
Hex Machine Screw Nut: A six-sided internally threaded fastener with flat tops and chamfered corners. Threads shall be
Unified Standard, Class 2B.
Square Machine Screw Nut: A four-sided, internally threaded fastener, tops and bottoms flat, without chamfer. Threads shall
be Unified coarse thread, Class 2B.
Applications/
Advantages
Hex Machine Screw Nut: Designed to be used specifically with machine screws. Stainless nuts are used with stainless
machine screws where parts are subject to corrosive conditions.
Square Machine Screw Nut: Offers a greater bearing surface for wrenching.
Material
Steel: Any low carbon steel
Stainless: 18-8 stainless steel
Plating
See Appendix-A for plating information.
This page prints with a watermark
很抱歉,暂时无法提供与“HNSS440”相匹配的价格&库存,您可以联系我们找货
