MACHINE SCREWS
Choice of: Steel, Zinc Plate • Nylon: 6/6, UL Rated 94V-2
THREAD
2-56
4-40
L
L
L
THREAD
THREAD
THREAD
Binding Head
Flat Head
Pan Head
6-32
8-32
10-32
FLAT HEAD
STEEL
NYLON
CAT. NO. CAT. NO.
9555
9556
9557
9500
9527
9501
9528
9502
9529
9503
9530
9504
9531
9505
9532
9506
9533
9507
9534
9508
9535
9509
9536
9510
9537
9511
9538
9512
9539
9513
9540
9514
9541
9516
9543
9517
9544
9518
9545
9519
9546
9520
9547
9521
9548
9522
9549
9523
9550
9524
9551
9525
9552
9526
9553
STAINLESS STEEL PAN HEAD SCREWS
SELF TAPPING SCREWS
Phillips drive pan head machine screws.
Highly versatile screw, used in wood, fiberglass and
metal where machine thread inserts are not furnished.
• Slotted drive, hex head
L
THREAD
MATERIAL: Steel, Zinc Plate (Non-RoHS Compliant)
Note: RoHS Compliant finishes available on special order
THREAD LENGTH CAT. NO.
No. 4 .375 (9.5) 9575
No. 6 .375 (9.5) 9576
.500 (12.7) 9577
No. 8 .375 (9.5) 9578
.500 (12.7) 9579
No. 10 .375 (9.5) 9580
.500 (12.7) 9581
HEX
MATERIAL: Stainless Steel
L
THREAD
STEEL
CAT. NO.
4694
9600
4701
9602
9603
9604
4705
4713
4716
IMPERIAL
NYLON
CAT. NO.
HEX
THREAD
187 (4.7)
4-40
9605 .250 (6.4)
.250 (6.4)
6-32
9606 .312 (7.9)
.250 (6.4)
8-32
9607
312 (7.9)
9608
.375 (9.5)
10-32
.430 (10.9) .250-28
.500 (12.7) .312-24
L
LENGTH THREAD
.250 (6.4)
.375 (9.5)
4-40
.500 (12.7)
.250 (6.4)
.375 (9.5)
6-32
.500 (12.7)
.375 (9.5)
.500 (12.7)
8-32
.750 (19.1)
.375 (9.5)
.500 (12.7) 10-32
.750 (19.1)
STEEL
CAT. NO.
4707
4708
4709
METRIC
NYLON
CAT. NO.
HEX
4687
5.00 mm
4688
5.50 mm
4689
7.00 mm
Ideal for quick identification of screw terminal. Reduces errors in wiring of cables.
See pages 62-65 for screw terminals with colored screws installed. Only head is
painted, provides reliable electrical contact to terminal.
THREAD
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
CAT.
NO.
9900
9901
9902
9903
9904
9905
9906
9907
9908
9909
9910
9911
BINDING HEAD SCREWS – COLORED HEAD
HEX MACHINE NUTS
MATERIAL: Nylon 6/6 UL Rated 94V-2
Steel, Zinc Plate
PAN HEAD
STEEL
NYLON
CAT. NO. CAT. NO.
9355
9356
9357
9300
9327
9301
9328
9302
9329
9303
9330
9304
9331
9305
9332
9306
9333
9307
9334
9308
9335
9309
9336
9310
9337
9311
9338
9312
9339
9313
9340
9314
9341
9316
9343
9317
9344
9318
9345
9319
9346
9320
9347
9321
9348
9322
9349
9323
9350
9324
9351
9325
9352
9326
9353
MACHINE SCREWS
PAN HEAD METRIC
STEEL
NYLON 6/6
CAT. NO. L
CAT. NO.
M2.5 THREAD
29300 4.00
29330
29301 6.00
29331
29304 12.00
29334
29306 16.00
29336
M3 THREAD
29311 6.00
29341
29314 12.00
29344
29316 16.00
29346
29318 25.00
29348
M4 THREAD
29321 6.00
29351
29324 12.00
29354
29326 16.00
29356
29328 25.00
29358
LENGTH
.250 (6.4)
.500 (12.7)
.750 (19.1)
.250 (6.4)
.375 (9.5)
.500 (12.7)
.625 (15.9)
.750 (19.1)
1.000 (25.4)
.187 (4.7)
.250 (6.4)
.375 (9.5)
.500 (12.7)
.625 (15.9)
.750 (19.1)
1.000 (25.4)
1.250 (31.8)
2.000 (50.8)
.250 (6.4)
.375 (9.5)
.500 (12.7)
.625 (15.9)
.750 (19.1)
1.000 (25.4)
1.250 (31.8)
.500 (12.7)
.750 (19.1)
1.000 (25.4)
1.500 (38.1)
BINDING HEAD
STEEL
NYLON
CAT. NO. CAT. NO.
9455
9456
9457
9400
9427
9401
9428
9402
9429
9403
9430
9404
9431
9405
9432
9406
9433
9407
9434
9408
9435
9409
9436
9410
9437
9411
9438
9412
9439
9413
9440
9414
9441
9416
9443
9417
9444
9418
9445
9419
9446
9420
9447
9421
9448
9422
9449
9423
9450
9424
9451
9425
9452
9426
9453
THREAD
THREAD
M2.5
M3
M4
MATERIAL: Brass, Nickel Plate
with Painted Color Head
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
M4 ×
6.3mm L
M3 ×
6mm L
CAT. NO.
7799-1
9192-2
9192-3
9192-4
9192-5
9192-6
9192-7
CAT. NO.
7689-1
9191-2
9191-3
9191-4
9191-5
9191-6
9191-7
6-32 ×
.250 (6.3) L
HEAD COLOR
NICKEL
RED
BLACK
WHITE
BLUE
GREEN
YELLOW
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
CAT. NO.
8190-1
9190-2
9190-3
9190-4
9190-5
9190-6
9190-7
135
很抱歉,暂时无法提供与“7799-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.057051+0.52640
- 10+3.0678110+0.39805
- 25+2.7396325+0.35547
- 100+2.32093100+0.30114
- 500+1.92405500+0.24965
- 1000+1.778851000+0.23081
- 2500+1.607322500+0.20855
- 5000+1.491405000+0.19351
