ALL DIMENSIONS IN MILLIMETERS
THREAD SIZE C max D max
M 2x0.4
M 2.5x0.45
M 3x0.5
M 3.5x0.6
M 4x0.7
M 5x0.8
M 6x1
4.830
5.460
6.700
8.100
8.690
9.900
12.580
1.600
2.100
2.400
2.600
3.050
3.700
4.600
Head Driver
Size
#1
#1
#2
#2
#2
#2
#3
RECOM. CLEAR. HOLE
MIN.
2.310
2.670
3.550
3.890
4.390
5.560
6.730
MAX.
2.410
2.840
3.650
3.990
4.540
5.660
6.830
LENGTH
TYPICAL CLEARANCE HOLE DETAIL
4 to 12 mm
4 to 12 mm
4 to 40 mm
4 to 40 mm
4 to 40 mm
6 to 40 mm
6 to 50 mm
STANDARD SPECIFICATIONS & COMMON OPTIONS (HOW TO ORDER)
STD. SCREW MATERIAL: TYPE 18/8 STAINLESS STEEL PER DFARS (OTHER MATERIALS AVAILABLE)
STD. SCREW FINISH: NATURAL (PASSIVATED PER MIL-STD-171 UNLESS OTHERWISE SPECIFIED)
STD. O-RING MATERIAL: SILICONE RUBBER (SEE TABLE FOR O-RING OPTIONS)
SAMPLE CATALOG
NO.
SCREW TYPE
RM
THREAD
3
X
LENGTH
12
O-RING SUFFIX -2701
OPTIONS
-BLKOX
PAN HEAD WITH
CROSS RECESS
ENTER BASIC
THREAD SIZE
ENTER LENGTH
ENTER FROM TABLE
ENTER FROM TABLE
AVAILABLE O-RING MATERIALS
Service
Compound
Material
Temp.
Suffix
Silicone
-150°F to 500°F
-2701
Rubber
-101°C to 260°C
Fluoro-78°F to 450°F
-2615
Silicone
-61°C to 232°C
Rubber
-20°F to 400°F
-5701
Viton A
-29°C to 204°C
Buna N
-65°F to 250°F
-4601
(NBR)
-54°C to 121°C
Neoprene -65°F to 300°F
-3701
(EPR)
-54°C to 149°C
Ethylene
Propylene -65°F to 300°F
-7601
-54°C to 149°C
(EPDM)
CHANGED HEAD DIA. and HEAD HEIGHT of ALL THREAD
MAT'L: AS NOTED
FINISH: AS NOTED
DESCRIPTION
SEELSKREW
METRIC PAN HEAD
APM-HEXSEAL CORPORATION
ENG.
DWN.
CHKD.
-BLKOX
-NY
-LY
-TP
-HTP
BLACK OXIDE PER
MIL-C-13924A,
CLASS 2
LOCKING NYLON
PELLET
LOCKING NYLON
STRIP
LOCKING NYLON
STD. PATCH
HIGH TEMP.
LOCKING NYLON
PATCH
SCALE
09.09.10
07.02.09
01.21.09
12.12.08
DATE
J. PAULUMBO 12.16.58
DWG. NO.
MAXIMUM AND MINIMUM MEASUREMENTS ARE STATED DIRECTLY ON
EACH DIMENSION.
COMMON OPTIONS
SUFFIX
DESCRIPTION
S. GOK
S. GOK
S. GOK
S. GOK
CHANGED Cmax of M2 from 4.240 to 4.830
ADDED "PER DFARS" FOR THE SCREW MATERIAL
NEW DRAWING FORMAT
TITLE:
K
J
I
H
REV.
RM3X12-2701-BLKOX
RM-0000-00-00
THIS DRAWING COVERS PROPRIETARY ITEM AND IS THE PROPERTY OF THE APM-HEXSEAL CORPORATION.
THIS DRAWING IS NOT TO BE COPIED OR USED WITHOUT THE WRITTEN APPROVAL OF AN OFFICER OF THE APM-HEXSEAL CORPORATION.
很抱歉,暂时无法提供与“RM2X8MM2701”相匹配的价格&库存,您可以联系我们找货
