Nylon Fasteners
Slotted Pan
Head
Machine Screws
NYLON PAN HEAD MACHINE SCREWS
Nominal Size
A
H
J
T
Head Diameter
Height of Head
Width of Slot
Depth of Slot
Max
Min
Max
Min
Max
Min
Max
Min
1
.142
.130
.046
.038
.026
.019
.027
.018
2
.167
.155
.053
.045
.031
.023
.031
.022
4
.219
.205
.068
.058
.039
.031
.040
.030
6
.270
.256
.082
.072
.048
.039
.050
.037
8
.322
.306
.096
.085
.054
.045
.058
.045
10
.373
,357
.110
.099
.060
.050
.068
.053
1/4
.492
.473
.144
.130
.075
.064
.087
.070
Tolerance on
Length
Nominal Screw Length
Nominal
Screw Size
Up to 1/2 in., incl.
Over 1/2 to 1 in., incl.
Over 1 to 2 in., incl.
Over 2 in.
1 thru 10
-0.02
-0.03
-0.06
-0.09
1/4
-0.03
-0.03
-0.06
-0.09
Description
An externally threaded fastener with a head that has slightly rounded sides, a flat top and a flat underside.
Applications/
Advantages
To be used with internally threaded nylon fasteners in applications that require corrosion resistance or electrical insulation. Nylon's other
advantages include: resistance to greases and oils; a low coefficient of friction; ability to maintain its torque strength when exposed to a
wide range of temperatures.
Material
Nylon 6/6
Hardness
Rockwell M80
Tensile, shear and torque data is offered for informational purposes only. This data should not be used to set lspecification imits. It is always
wise to test parts in the actual application.
Tensile Test
(Break Pounds)
2-56: 19 lbs.; 4-40: 41 lbs.; 6-32: 69 lbs.; 8-32: 108 lbs.; 10-24: 149 lbs.; 10-32: 165 lbs.; 1/4-20: 312 lbs.
Double Shear
(Break Pounds)
2-56: (No test); 4-40: 50 lbs.; 6-32: 97 lbs.; 8-32: 164 lbs.; 10-24: 257 lbs.; 10-32: 241 lbs.; 1/4-20: 432 lbs.
Maximum Torque
2-56: (No test); 4-40: 12-16 in. oz.; 6-32: 18-20 in. oz.; 8-32: 2-3 in. lbs.; 10-24: 2-4 in. lbs.; 10-32: 3-4 in. lbs.; 1/4-20: 9-10 in. lbs.
(before
deformation)
Thermal
Properties
Melting Point: 500° F
Continuous Use Temperature: 185° F
This page prints with a watermark
很抱歉,暂时无法提供与“NYPMS8320038PH”相匹配的价格&库存,您可以联系我们找货
