NYPMS1020100PH
NYPMS1020100PH
    B&FFASTENERSUPPLY
    MACHINESCREWPANPHILLIPS10-32
NYPMS1020100PH 数据手册
Nylon Fasteners Slotted Pan Head Machine Screws NYLON PAN HEAD MACHINE SCREWS Nominal Size A H J T Head Diameter Height of Head Width of Slot Depth of Slot Max Min Max Min Max Min Max Min 1 .142 .130 .046 .038 .026 .019 .027 .018 2 .167 .155 .053 .045 .031 .023 .031 .022 4 .219 .205 .068 .058 .039 .031 .040 .030 6 .270 .256 .082 .072 .048 .039 .050 .037 8 .322 .306 .096 .085 .054 .045 .058 .045 10 .373 ,357 .110 .099 .060 .050 .068 .053 1/4 .492 .473 .144 .130 .075 .064 .087 .070 Tolerance on Length Nominal Screw Length Nominal Screw Size Up to 1/2 in., incl. Over 1/2 to 1 in., incl. Over 1 to 2 in., incl. Over 2 in. 1 thru 10 -0.02 -0.03 -0.06 -0.09 1/4 -0.03 -0.03 -0.06 -0.09 Description An externally threaded fastener with a head that has slightly rounded sides, a flat top and a flat underside. Applications/ Advantages To be used with internally threaded nylon fasteners in applications that require corrosion resistance or electrical insulation. Nylon's other advantages include: resistance to greases and oils; a low coefficient of friction; ability to maintain its torque strength when exposed to a wide range of temperatures. Material Nylon 6/6 Hardness Rockwell M80 Tensile, shear and torque data is offered for informational purposes only. This data should not be used to set lspecification imits. It is always wise to test parts in the actual application. Tensile Test (Break Pounds) 2-56: 19 lbs.; 4-40: 41 lbs.; 6-32: 69 lbs.; 8-32: 108 lbs.; 10-24: 149 lbs.; 10-32: 165 lbs.; 1/4-20: 312 lbs. Double Shear (Break Pounds) 2-56: (No test); 4-40: 50 lbs.; 6-32: 97 lbs.; 8-32: 164 lbs.; 10-24: 257 lbs.; 10-32: 241 lbs.; 1/4-20: 432 lbs. Maximum Torque 2-56: (No test); 4-40: 12-16 in. oz.; 6-32: 18-20 in. oz.; 8-32: 2-3 in. lbs.; 10-24: 2-4 in. lbs.; 10-32: 3-4 in. lbs.; 1/4-20: 9-10 in. lbs. (before deformation) Thermal Properties Melting Point: 500° F Continuous Use Temperature: 185° F This page prints with a watermark
NYPMS1020100PH 价格&库存
很抱歉,暂时无法提供与“NYPMS1020100PH”相匹配的价格&库存,您可以联系我们找货
