9920
9920
    KEYSTONE
    MACH SCREW PAN PHILLIPS 6-32
9920 数据手册
SEMS SCREW TERMINALS 15 AMP SPECIFICATIONS Terminal: .032 (.81) Brass, Matte Tin Plate 6-32 SEMS Screw & Washer: Steel, Nickel Plate 6-32 SEMS SCREW SCREW .440 [11.2] .440 [11.2] .197 [5.0] .187 [4.8] .276 [7.0] SNAP-IN PC MOUNT .197 [5.0] .276 [7.0] .060 [1.52] (4) PLS .060 [1.52] (4) PLS .197 [5.0] PC MOUNT CAT. NO. 7691-SEMS (Screw Supplied Unassembled) CAT. NO. 8191-SEMS (Screw Supplied Unassembled) CAT. NO. 7693-SEMS (Screw Installed & Captivated) CAT. NO. 7701-SEMS (Screw Installed & Captivated) SPECIFICATIONS 6-32 SEMS SCREW SEMS SCREW TERMINALS .280 [7.1] SNAP-IN PC MOUNT Terminal: .032 (.81) Brass, Matte Tin Plate Screw & Washer: Steel, Nickel Plate .452 [11.5] 6-32 SEMS SCREW .452 [11.5] .312 [7.9] .512 [13.0] .312 [7.9] .512 [13.0] .060 [1.52] (4) PLS .308 [7.8] .060 [1.52] .138 [3.5] .295 [7.5] PC MOUNT .197 [5.0] .197 [5.00] CAT. NO. 7690-SEMS (Screw Supplied Unassembled) CAT. NO. 8190-SEMS (Screw Supplied Unassembled) CAT. NO. 7692-SEMS (Screw Installed & Captivated) CAT. NO. 7700-SEMS (Screw Installed & Captivated) SPECIFICATIONS Terminal: .032 (.81) Brass, Matte Tin Plate Screw & Washer: Steel, Nickel Plate 6-32 SEMS SCREW 6-32 SEMS SCREW .250 [6.4] .134 [3.4] .331 [8.4] SNAP-IN PC MOUNT .276 [7.01] .232 [5.9] .059 [1.50] (4) PLS .312 [7.9] .437 [11.1] PC MOUNT .055 [1.40] (2) PLS CAT. NO. 8195-SEMS (Screw Supplied Unassembled) CAT. NO. 8198-SEMS (Screw Supplied Unassembled) CAT. NO. 7775-SEMS (Screw Installed & Captivated) CAT. NO. 7778-SEMS (Screw Installed & Captivated) SPECIFICATIONS Terminal: .032 (.81) Brass, Matte Tin Plate Screw & Washer: Steel, Nickel Plate 6-32 SEMS SCREW .450 [11.43] 45° 6-32 SEMS SCREW .718 [18.3] REF. .947 [24.1] .412 [10.5] .555 [14.1] PC MOUNT PC MOUNT .197 [5.0] .295 [7.49] .276 [7.01] CAT. NO. 7697-SEMS (Screw Supplied Unassembled) .197 [5.0] .200 [5.1] .060 [1.52] (4) PLS .060 [1.52] (4) PLS CAT. NO. 8189-SEMS (Screw Supplied Unassembled) CAT. NO. 7699-SEMS (Screw Installed & Captivated) CAT. NO. 7702-SEMS (Screw Installed & Captivated) 30 AMP SEMS Screw Terminals provide quick and secure attachment of wire leads. SEMS screw has captivated, free spining lock washer, eliminated twisting of wire when tightening lead to terminal. Washer will rise with head of screw when unscrewed. .507 [12.9] 6-32 SEMS SCREW .266 [6.8] DIA. .310 [7.9] SQUARE .460 [11.7] SNAP-IN PC MOUNT SPECIFICATIONS .276 [7.0] Terminal: .032 (.81) Brass, Matte Tin Plate Screw & Washer: Steel, Nickel Plate 68 .060 [1.52] (6) PLS .197 [5.0] .250 [6.4] .394 [10.0] 6-32 THREAD CAT. NO. 8197-SEMS (Screw Supplied Unassembled) SPECIFICATIONS CAT. NO. 8199-SEMS (Screw Installed & Captivated) Screw & Washer: Steel, Nickel Plate Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED CAT. NO. 9920 (SEMS Screw Only) www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017
很抱歉,暂时无法提供与“9920”相匹配的价格&库存,您可以联系我们找货
    • 2500+1.14069
    • 1+1.787491+0.23003
