1594TS100
1594TS100
    HAMMONDMANUFACTURING
    SHT MTL SCW FLAT PHIL #4 100/PK
1594TS100 数据手册
1594 Heavy Duty (Thick Wall) Accessories Key Features • Rugged electronic instrument enclosures, ideally suited for mounting printed circuit boards. • Heavy duty, thick wall design with an average wall thickness of .13” (3.3 mm). • Standard versions from flame retardant ABS plastic (carries a UL flammability rating of 94V0). • On standard versions, countersunk lid is secured with four M3 x 0.5 - 0.71” (18 mm) long, Philips machine screws threaded into integral brass bushings. Perfect for applications with repetitive assembly and disassembly are required. • Economy version is molded in general purpose ABS plastic. • Economy version utilizes self tapping screws into plastic posts (no brass inserts). • Designed to meet IP54 (see gasket kit accessory below to meet IP66). • Stocked in black and grey with matte textured finish. Machine Screws (100-pack) 1594MS100 Self Tapping Screws for Economy Versions (100-pack) 1594TS100 Water-Tight Screws with O-Rings (100-pack) 1594WMS100 Gasket Kits (see table) • For water-tight versions, try “1594W” on page 42. • For EMI/ RFI shielded versions, try “1594RFI” on page 46 or “1594R” on page 53 www.hammondmfg.com USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 20 1594 Heavy Duty (Thick Wall) Standard version features machine screws into brass busings. Thick walls Lid shown with gasket accessory kit Economy versions feature self-tapping screws into plastic posts Standard Version Economy Version Color Units Length Width Depth (less lid) Gasket Kit (sold as pair) Inches mm 2.2 56 2.2 56 1.1 28 1594AGASKET Inches mm 3.2 81 2.2 56 1.1 28 1594BGASKET Inches mm 4.1 105 2.6 66 1.3 33 1594CGASKET Inches mm 5.2 131 2.6 66 1.7 43 1594DGASKET Inches mm 6.6 167 4.2 107 2.1 53 1594EGASKET USA Canada Quebec Europe (UK) Australia (716) 630-7030 (519) 822-2960 (450) 975-1884 01256 812812 +61-8-8240-2244 1594ABK 1594ASBK Black  1594AGY 1594ASGY Grey 1594BBK 1594BSBK Black  1594BGY 1594BSGY Grey 1594CBK 1594CSBK Black  1594CGY 1594CSGY Grey 1594DBK 1594DSBK Black  1594DGY 1594DSGY Grey 1594EBK 1594ESBK Black  1594EGY 1594ESGY Grey www.hammondmfg.com 21
1594TS100
物料型号:1594系列
器件简介:这些外壳设计用于安装印刷电路板,具有重型厚壁设计,平均壁厚为0.13英寸(3.3毫米)。
引脚分配:标准版本使用M3 x 0.5 - 0.71英寸(18毫米)长的Phillips机器螺丝,螺纹进入整体黄铜衬套。
参数特性: - 标准版本由阻燃ABS塑料制成(具有UL阻燃等级94V0)。 - 经济版本采用通用ABS塑料注塑成型。 - 设计满足IP54防护等级(见下文的垫圈套件配件以满足IP66)。
功能详解:标准版本使用机器螺丝固定到黄铜螺柱上,而经济版本则使用自攻螺丝固定到塑料柱上(无黄铜衬套)。
应用信息:这些外壳适用于需要重复组装和拆卸的应用。
封装信息:外壳有黑色和灰色,具有磨砂质感的表面处理。标准和经济版本都有提供,尺寸和深度(不含盖子)在表格中有详细列出。
1594TS100 价格&库存
很抱歉,暂时无法提供与“1594TS100”相匹配的价格&库存,您可以联系我们找货
1594TS100
    库存:19
