SFR6-32X5/16-2701
SFR6-32X5/16-2701
    GEEHY(极海半导体)
    MACHINE SCREW FLAT PHILLIPS 6-32
SFR6-32X5/16-2701 数据手册
CATALOG SF500A SELF - SEALING FASTENERS, NUTS & WASHERS US ® C UL Recognized Component Precision O-Ring embedded in asymmetrical groove 360° metal-to-metal surface contact Threadlocking options o vi Wor ld’s M o ng G round s ® The E nv i ro n me nt s Are O ur Ho ile Pr st st WHEN JUST FASTENING ISN’T ENOUGH ® Table of Contents HIGH-PRESSURE REUSABLE SELF-SEALING FASTENERS & WASHERS Introduction. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 SEELSKREWS® . . . . . . . . . . . . . . . . . . . . . . . . . . 4 SEELBOLTS® . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 SEELNUTS® . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 SEELRIVETS® . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 SEELOC® Washers . . . . . . . . . . . . . . . . . . . . . . . 7 THREAD LOCKING ENHANCEMENTS Pellets. . . . . . . . . . . . . . . . . . . . . . . . . . 8 Strips (Bars) . . . . . . . . . . . . . . . . . . . . . 9 Patch . . . . . . . . . . . . . . . . . . . . . . . . . 10 High-Temperature Patch . . . . . . . . . . 11 CUSTOM APPLICATIONS . . . . . . . . . . . . . . . . . . .12 How To Order SCREW & BOLT CATALOG NUMBERING SYSTEM EXAMPLE Imperial/English: Head Code & Drive Style S 8-32 X Thread 1/2 -2701 *O-Ring Length Compound (diameter & pitch) Metric BLKOX Options (see adjacent chart) Options Type Code Black Oxide Finish BLKOX Self-Locking Add-Ons See pages 8, 9, 10 & 11 of catalog Captivating Special Cut-Down Lengths Metric: S M 3 X 12MM -2701 BLKOX Per Customer Specifications Painted Heads *See table 1, page 5 STANDARD BOLT TYPES Code Head/Drive Comments ST Hexagonal Partial/full threaded TAMPER-RESISTANT DRIVE STYLES (SPECIAL ORDER) Consult factory for minimum quantity and delivery information. Diameter Range: #4 thru 1/4" Length Range: 1/4 thru 1" Material: Stainless Steel (18-8) Drive Style STANDARD & TAMPER-RESISTANT SCREW HEAD TYPES Code Head Drive S Pan Head Slotted SL Oversized Pan Head Slotted R Pan Head Recessed Phillips SFR Flat Head (Countersunk) Recessed Phillips Phillips bit one size smaller LB Pan Head 6-Lobe “Torx™” compatible HP Hex w/Pin (tamper-resistant) SS Spanner (tamper-resistant) Spanner OWS One-Way Slot Slotted Type Head Style Number 6 Lobe w/Pin LBP Hex w/Pin HP Spanner SS One-Way Slot OWS Comments Hex w/Pin Tamper-Resistant Other drive styles, materials, and sizes available. Please consult factory. www.apmselfsealingfasteners.com • 800.498.9034 © Copyright 2010 APM HEXSEAL When just fastening ® isn’t enough. Pre-assembled O-Ring Seals in Asymmetrical Groove Visit our website for downloadable CAD drawings: Patent No. 3,175,454 www.apmselfsealingfasteners.com 800.498.9034 RoHS DFARS Compliant Compliant US ® C UL Recognized Component Sealing Performance Under High Pressure APM Hexseal invented and patented pre-assembled self-sealing fasteners designed to provide both fastening and sealing integrity in a single unit. Our design features a resilient O-ring held captive in a precision engineered groove under the fastener head. This combination of precise groove geometry and O-ring characteristics results in an absolute seal regardless of surface finish, while still providing full metal-to-metal contact. Vibration-resistant and re-usable, SEELSKREWS®, SEELBOLTS®, and SEELRIVETS® can withstand internal/external pressures up to 20,000 psig/vacuum at temperatures from -160°F to +500°F (-106°C to +260°C).* Made in the U.S.A., APM self-sealing & self-locking fasteners are available in standard and metric sizes in a wide choice of head and fastening types including self-tapping, and tamper-resistant. Typically, they are furnished in stainless steel/with different finishes or colors as may be required. All have pre mounted silicone rubber O-rings. Other elastomeric materials are also available to match and handle exposure to various chemicals and solvents (see materials table 1 on page 5). Consult factory for further information and pricing. They represent a superior sealing alternative to sealing compounds, tape, chemical coatings, and deformable washers that attempt to seal the threadform. Self-Locking Add-Ons Features and Benefits Fully compressed metal-to-metal contact • Positive sealing under pressure or vacuum. • Easy-to-install … pre-assembled unit installs like a conventional fastener. • Metal-to-metal contact resists loosening due to vibration, and assures fastening integrity. • Re-usable … repeated installation and removal does not affect sealing effectiveness. • Compatible with all surface finishes. • UL Recognized Component … tested and listed to UL Standard 50, Types 1-13. • Optional O-ring seal materials assure performance with wide variety of gases and liquids. • Uniformity and high strength assure repeatable performance. • No adhesives, coatings or tape required. Typical Applications • • • • • • • • • • Instrument Housings/Panels Pressure Gauges Gear Boxes/Transmissions Valves Motor Housings Fuel Tanks Cylinders Pumps Equipment Housings/Cabinets Air Conditioning Equipment • • • • • • • • Hydraulic Systems Portable Instruments Engines Medical Equipment Military Equipment Portable Communications Equipment Food Processing Systems Or any application where leakage can compromise reliability When vibration is also an issue, APM offers a choice of proven resistant and adjustable Nylon threadlocking devices in the form of thread-embedded pellets, strips, and pre-applied thread-patches. Other materials also available. All of our threadlockers contribute and work in concert and add to the basic high-pressure sealing primary function of our fastener line. *SEELNUTS® rated: 6,000 psi 3 SEELNUTS® High-pressure, self-sealing nuts SEELNUTS® are designed for use on all types of adjusting screws, threaded studs, and machine bolts in applications where leakage (internal/external) may occur due to extreme pressures. Installed like an ordinary nut, SEELNUTS® form a high-pressure seal along the threaded section and contact surface when torque. Their single-piece design eliminates the need for gaskets, sealing compounds and surface preparations. Fully-adjustable and reusable, they resist vibration and seal under vacuum or high pressure. Available in all standard thread sizes, the integral seal can be formulated for compa tibility with most gases or liquids. They can also be supplied with self-locking pellets. THREAD SIZE 6-32 8-32 10-32 10-24 1/4-20 1/4-28 5/16-18 5/16-24 3/8-16 3/8-24 7/16-20 1/2-13 1/2-20 5/8-18 STANDARD SELF-SEALING F H T 5/16 9/64 1/64 3/8 5/32 1/64 3/8 5/32 1/64 3/8 5/32 1/64 7/16 7/32 1/64 7/16 7/32 1/64 1/2 17/64 1/64 1/2 17/64 1/64 9/16 21/64 1/64 9/16 21/64 1/64 11/16 3/8 1/32 3/4 27/64 1/32 3/4 27/64 1/32 15/16 35/64 1/32 JAM NUT F 1/2 1/2 1/2 1/2 5/8 5/8 5/8 5/8 5/8 5/8 N/A 3/4 3/4 N/A H 7/32 7/32 7/32 7/32 7/32 7/32 7/32 7/32 7/32 7/32 N/A 7/32 7/32 N/A Consult factory for additional sizes. STANDARD SELF-FEALING NUT MATERIAL: Steel Zinc Plated JAM-NUT MATERIAL: Nickel-plated brass Can also be made of carbon steel, stainless- steel, aluminum, etc. Standard rubber is silicone rubber, contact factory for other sealing compounds. METRIC THREAD SIZE M3X0.5 M4X0.7 M5X0.8 M6X1 M8X1.25 M10X1.5 M12X1.75 M14X2 F 5.5 7 8 10 13 17 19 22 STANDARD SELF-SEALING H 2.26 3.02 3.81 4.80 6.36 7.86 9.35 10.85 T 0.254 0.330 0.406 0.508 0.630 0.660 0.860 1.010 Consult factory for additional sizes. METRIC NUT MATERIAL: Stainless-Steel Can also be made of carbon steel, nickel-plated brass, aluminum, etc. Standard rubber is silicone rubber, contact factory for other sealing compounds. SEELRIVETS® High-pressure, self-sealing rivets SEELRIVETS® are designed to seal out air, water, lubrications and other liquid or gaseous contaminations. Installed like an ordinary rivet, SEELRIVETS® form a high-pressure seal while permitting metal-to-metal contact. SEELRIVETS® are universal head furnished in aluminum alloy for industrial applications. See below for SEELRIVETS® types. CONTACT FACORTY FOR AVAILABLE SIZES, TYPES, MATERIALS AND O-RING MATERIALS. AIR & LIQUID-TIGHT BONDED SELF-SEALING WASHERS TYPICAL APPLICATIONS • Electrical Enclosures meeting NEMA Standards • Laboratory Equipment & Scientific Instruments • Manufacturing & Process Equipment i.e., Food, Chemical, Pharmaceuticals, etc. • Material Handling & Packaging Equipment • Motion & Control Equipment • Networking & Communications Equipment • Test & Measurement Equipment • Contract Manufacturing & Fabrication • Boat & any Marine-related Equipment • Construction & Off-Road Equipment • Industrial & any Specialized Application Equipment • Powder & Liquid Handling Equipment • Filtration & Separation Equipment • Monitoring & Control Equipment • Military & Security Equipment • Custom & Metal Fabricators Plus anything that is exposed to a spray or wash downs SEELOC® High-Pressure Washers—Reusable & Vibration-Resistant ® SEELOC washers consist of silicone rubber bonded to formed stainless steel washers, and are designed for a variety of electrical and mechanical applications. SEELOC® washers are used with conventional screws, bolts or studs to complete the sealing and locking action. *UL Recognized (UL Type 4X/6 enclosures) and IP66/68 water ® ® *Inch Seeloc Washer Range Metric Seeloc Washer Range ingress rated, SEELOC® is an ideal sealing solution in a wide For Max. ThruFor Max. ThruAPM Thread Washer Hole Size APM Thread Washer Hole Size variety of mechanical, electrical and electronics applications Part No. Size O.D. (inch/mm) Part No. Size O.D. (mm) that require high-performance, air/liquid-tight sealing. Upon 1/2" 1/4/ 6.35 12.7 mm 6.35 75601 #6 75031 M3 compression, the bonded, dish shaped silicone rubber 1/2" 1/4/ 6.35 12.7 mm 6.35 75801 #8 75041 M4 sealing disc makes full 360° horizontal surface contact from 1/2" 1/4/ 6.35 12.7 mm 6.35 75101 #10 75051 M5 1” 3/8 / 9.53 25.4 mm 9.53 75602 #6 75032 M3 the hub to the mounting hole (see A).The silicone rubber also 1” 5/8 / 15.87 25.4 mm 15.87 75802 #8 75042 M4 makes full vertical contact with the screw/bolt shank/threads 1” 5/8 / 15.87 25.4 mm 15.87 75102 #10 75052 M5 – thus completing the high-pressure seal. This would be a 1” 5/8 / 15.87 25.4 mm 15.87 75082 1/4 75062 M6 difficult feat for an ordinary O-Ring, or any sealing washer 1” 5/8 / 15.87 25.4 mm 15.87 75107 5/16 75312 M8 that does not fully make fastener contact. The SEELOC® 1” 5/8 / 15.87 25.4 mm 15.87 75122 3/8 75392 M10 75472 M12 25.4 mm 15.87 1” 5/8 / 15.87 75142 7/16 silicone contact surface landscape features a continuous Consult factory for additional sizes. 1” 5/8 / 15.87 75162 1/2 ridge (see B), creating a contoured sealing barrier, as well as Optional black oxide finish available. 1 1/2" 1/2/ 12.7 75603 #6 a periphery locking joint, when used for mounting on a 1 1/2" 1 / 25.4 75803 #8 protruding round extended surface (see C). Extra large size 1 1/2" 1 / 25.4 75103 #10 holes or odd shaped adjustment-slots, in addition to 1 1/2" 1 / 25.4 75083 1/4 1 1/2" 1 / 25.4 75108 5/16 conventional mounting holes, also benefit from these ® 1 1/2" 1 / 25.4 75123 3/8 precision, reusable sealing washers. SEELOC washer 1 1/2" 1 / 25.4 75143 7/16 technology is perfect for any securing application where 1 1/2" 1 / 25.4 75163 1/2 spray, vapors or wash-down is present, and where future Consult factory for additional sizes. Optional black oxide finish available. maintenance may be of concern due to contaminant exposure from salt spray, ozone, UV, lubricants, cleaning SEELOC® SPECIFICATIONS solvents, etc. ® Material: Standard Seeloc washer 300 Series is stainless steel, but can be made in carbon steel, nickel-plated brass, aluminum, etc. Silicone rubber is standard.* Temp. Range: -160°F to +500°F (-106°C to +260°C) Pressure Range: 0 to 100 psig internal and external. Shelf Life: in excess of 25 years. Resistant to: salt water, acids, weather, sunlight, ozone, etc. Installation: Seeloc® washers are installed on bolts, screws or studs in the same manner as regular washers. The rubber section should always face the panel. Rating: *IP66/68. UL Recognized for Type 4X & Type 6 enclosure protection. Bottom ViewFacing Contact Surface *Consult materials chart for alternatives. 44 Honeck Street Englewood, NJ 07631 Tel: 201-569-5700 Fax: 201-569-4106 www.apmhexseal.com ADJUSTABLE LOCKING PELLETS FOR SEELSKREW®, SEELBOLT® & SEELNUT® SELF-SEALING FASTENERS FULLY ADJUSTABLE & REUSABLE PER IFI 124, IFI 524 & MIL-DTL-18240F, NASM25027 When assembled with a mating part the resilient engineered polymer pellet (normally Nylon) is compressed, and a locking action is established. APM Pellet Locking action takes place inside the threads due to its vibration dampening characteristics, as opposed to at the bearing surface. The resilience of the pellet holds the fastener in place without adhesives or thread distortion. The pellet’s resiliency also contributes to its superior degree of adjustability and repeated reusability. See pages 4, 5 & 6 of this catalog for complete list of fastener sizes to apply. Self-Sealing screws, bolts and nuts that have pellets installed can operate and deliver outstanding performance in both high and low temperature extremes without degradation. Under most operating conditions, these pellets are unaffected by vibration of reversal of stress. Installed in a drilled hole (just below the depth of the thread), APM pellets are typically positioned one to three threads back from the end of the fastener to assure ease of starting. Hole positioning can be modified to meet specific applications – contact Technical Sales for assistance. FEATURES HOW TO ORDER • Resistant to vibration and reversal of stress, APM pellets lock whether fasteners are seated or unseated. Specify the head type, thread size, length, followed by the Ordering Code. Example: To order a slotted pan head SEELSKREW, with a 8-32 thread, 1 inch long, with standard silicone o-ring, black oxide finish and Nylon pellet order... S8-32X1-2701-BLKOX-NY • Saves money by eliminating the need for costly lock washers, cotter pins or castellated nuts. You get a close fit without expensive close tolerances. APM pellets are less expensive than applying bottled thread locking compounds at the point of assembly. • APM pellets are virtually impervious to a wide range of chemicals, water and motor fluids. They won’t dry, shrink or lose resiliency when exposed to commercial solvents, alcohol, gasoline, oil, caustic soda, and many other chemicals. See inside front cover How To Order information for additional assistance. SPECIFICATIONS Material Reusability Effective Temperature Range Ordering Code Nylon Up to 15 on/off cycles -65°F to +250°F (-54°C to +121°C) NY -320°F to +390°F (-196°C to +198°C) NB -450°F to +500°F (-268°C to +260°C) NBR KEL-F* Vespel** 0 (one installation and one removal) Up to 5 on/off cycles * KEL-F is a registered trademark of Minnesota Mining and Manufacturing Co. ** Vespel and Teflon are registered trademarks of EI. Dupont De Nemours & Co. 800.498.9034 www.apmselfsealingfasteners.com 8 LOCKING STRIP (BAR) FOR SEELSKREW® & SEELBOLT® SELF-SEALING FASTENERS REUSABLE TO +550°F (288°C) PER IFI 124, IFI 524 & MIL-DTL-18240, VARIOUS NAS, AN, & MS CALLOUTS A resilient engineered polymer bar (strip) is inserted into a precise slot that has been milled into the threads making the fastener selflocking as well as self-sealing, while remaining fully adjustable. The APM Strip delivers outstanding performance in both high and low temperature extremes. When assembled with a mating part the resilient APM Strip (usually Nylon) is compressed which provides a locking action in the thread instead of at the bearing surface due to vibration dampening characteristics. The fastener is held in place without the use of adhesives or thread distortion. The result is a self-sealing reusable fastener that is both locking and repeatedly adjustable. APM Strips are typically positioned one to three threads back from the end of the fastener to assure ease of starting. Special strip positioning can be tailored to fit your needs – contact Technical Sales for assistance. FEATURES HOW TO ORDER • Under most conditions, our self-sealing fasteners with Strips are unaffected by vibration or reversal of stress. APM Strips lock whether the fastener is seated or unseated. • APM Strip fasteners require no costly lock-washers, cotter pins, or castellated nuts. APM Strips provide close fits without the expense involved in attaining close tolerances, and are less expensive than applying bottled thread locking compounds at the point of assembly. Specify the head type, thread size, length, followed by the Ordering Code. Example: To order a slotted pan head SEELSKREW, with a 8-32 thread, 1 inch long, with a standard silicone o-ring, black oxide finish and a KEL-F strip order... S8-32X1-2701-BLKOX-LB See inside front cover How To Order information for additional assistance. • APM Strips will not dry, shrink, or lose resiliency when exposed to commercial solvents, alcohol, gasoline, oil, caustic soda, etc. SPECIFICATIONS Material Reusability Effective Temperature Range Ordering Code Nylon 6/6 Up to 15 on/off cycles -65°F to +250°F (-54°C to +121°C) LY -320°F to +390°F (-196°C to +198°C) LB KEL-F* 0 (one installation and one removal) Vespel** Up to 5 on/off cycles -450°F to +500°F (-268°C to +260°C) LBR Teflon** Up to 5 on/off cycles -450°F to +550°F (-268°C to +288°C) LW Copper Up to 5 on/off cycles -400°F to +400°F (-240°C to +204°C) LC -400°F to +1200°F (-240°C to +649°C) LS Stainless Steel 0 (one installation and one removal) * KEL-F is a registered trademark of Minnesota Mining and Manufacturing Co. ** Vespel and Teflon are registered trademarks of EI. Dupont De Nemours & Co. 800.498.9034 www.apmselfsealingfasteners.com 9 PATCH FOR LOCKING & SEALING – PRE- APPLIED TO SEELSKREW® & SEELBOLT® SELF-SEALING FASTENERS VIBRATION-DAMPENING ACTION ON THE THREAD SURFACE is achieved while still allowing repeated adjustment & reuse. The APM Patch dry coating process is fused to the thread surface and delivered ready to be installed without the need for curing or any other special preparation. When assembled with a mating part the resilient engineered polymer (normally Nylon) Patch is compressed providing a locking action in the thread instead of at the bearing surface due to its vibration dampening characteristics. The resilience of the APM Patch holds the fastener in place without adhesives or thread distortion. Generally the Patch coating is applied 120° to 4-6 threads, starting 1-3 threads back form the end. Modified Patch location and coating length can be specified for specific applications. FEATURES SPECIFICATIONS • Patch provides excellent locking performance as well as increased sealing ability by completely filling the thread root with an elastic nylon dam. Primary Useage: Lock and Seal Reusability: Up to 15 on-off cycles Material: Nylon 11 Color: Yellow (other colors available upon request*) Hardness: Shore D (ASTM D2240) 70-80 Durometer Salt Spray Resistance: (ASTM B117) 1000+ hours (X scribe) Taber Abrasion: (ASTM D4060) 10-18 mg loss CS-10 wheel, 1000 g load, 1000 cycles (varies with color) Dielectric Strength: (ASTM D149) 800-1200 volts/mil @10.0 mils (varies with color) Direct Impact resistance: (MPTM 0002) 160 in. lbs. (@10.0 mils) Shelf Life: The on part shelf life is at least one year under ideal storage conditions (+4°C to +32°C, or +40°F to +90°F). • APM Patch process involves no drilling or milling, so there is no loss of the fastener’s strength or hardness and no troublesome burrs or chips. • Saves money by eliminating the need for costly lock washers, cotter pins, or castellated nuts. You get a close fit without the costs involved in obtaining close tolerances. And, applying the Patch is less expensive than applying bottled threadlocking compounds at the point of assembly. • Resists heat and cold, and meets or exceeds IFI Specifications 124 & 524, as well as Military Specification MIL-DTL-18240F, Type P, for temperatures up to +250°F (up to +121°C). • APM Patch will not dry, shrink, or lose resiliency when exposed to commercial solvents, alcohol, gasoline, oil, caustic soda, jet fuel, etc. • The addition of the Patch greatly reduces the need for retightening. It can be reused repeatedly without damage to threads, and is particularly resistant to deformation. *QPL-18240 & MIL-DTL-18240F require yellow Nylon HOW TO ORDER Ordering Code: TP Example: To order a slotted pan head SEELCKREW, with a 8-32 thread, 1 inch long, with a silicone o-ring, black oxide finish, and with a Nylon patch order... S8-32X1-2701-BLKOX-TP See inside front cover How To Order information for additional assistance. 800.498.9034 www.apmselfsealingfasteners.com 10 HIGH-TEMPERATURE PATCH FOR LOCKING & SEALING – PRE- APPLIED TO SEELSKREW®, SEELBOLT® & SEALNUT® SELF-SEALING FASTENERS HIGH-TEMPERATURE PERFORMANCE – Maintains torque values through temperatures from -70°F (-57°C) to +500°F (+260°C) A specially formulated Nylon high-temperature Patch is generally applied to a minimum of 2-3 threads from the fastener end with 4-6 threads of coverage to assure ease of starting the nut/bolt assembly. When the mating threads are engaged, the patch is compressed creating a dam-like action on the opposite side of the coating resulting in very strong metal-to-metal contact. When the hightemperature patch is fully seated, it forms a positive lock that will not loosen, even under extreme vibration. This dam-like action adds to the high-pressure sealing characteristics of the O-ring & groove sealing design of our self-sealing fasteners. FEATURES SPECIFICATIONS • Retains Full Strength: APM Hi-Temperature Patch process involves no drilling or milling, so there is no loss of the fastener’s strength or hardness and no troublesome burrs or chips. Primary Useage: Lock and Seal Reusability: Up to 5 on-off cycles Material: Reinforced Nylon Color: Orange and Gray* Hardness: Shore D (ASTM D2240) 70-80 Durometer Salt Spray resistance: (ASTM B117) 1000+ hours (X scribe) Taber Abrasion: (ASTM D4060) 10-18 mg loss CS-10 wheel, 1000 g load, 1000 cycles Dielectric Strength: (ASTM D149) 800-1200 volts/mil @10.0 mils Direct Impact resistance: (MPTM 0002) 160 in. lbs. (@10.0 mils) • Saves Money & Time: APM Hi-Temperature Patch eliminates the need for expensive lock washers, cotter pins, or castellated nuts, and bottled thread locking compounds at the point of assembly. The Patch remains secure; fasteners coated with APM patch can be automatically fed through standard bowl feeders without fear of material falling off. • Chemical resistance: APM HI-Temperature Patch will not dry, shrink or otherwise be affected when exposed to commercial solvents, alcohol, gasoline, oil, caustic soda, jet fuel, etc. *QPL-18240 & MIL-DTL-18240F requires gray nylon. • Reusable: APM fasteners coated with the HiTemperature Patch can be reused repeatedly with out damage to the threads. The patch is particularly resistant to deformation which makes it ideal for repeated use. HOW TO ORDER Ordering Code: HTP Example: To order a slotted pan head SEELCKREW, with a 8-32 thread, 1 inch long, with a silicone o-ring, black oxide finish, and with a high temperature Nylon patch order... S8-32X1-2701-BLKOX-HTP • Eliminates Secondary Sorting: During the patch application process, camera systems are used to verify the parts are precisely coated – thus eliminating the need for customer secondary sorting. See inside front cover How To Order information for additional assistance. 800.498.9034 www.apmselfsealingfasteners.com 11 CUSTOM & NOT-SO-CUSTOM This catalog lists our standard types and sizes most frequently requested which are stocked for prompt delivery by us and our network of authorized distributors. We are pleased to honor any requests for other fastener types and heads Silicone (including venting), not shown in boot this catalog, or special machining, drilling, or finishes. We also welcome requests for assemblies that go beyond the basic fastening challenge. APM also offers complete elastomeric custom molding and bonding capabilities. For example, incorporating our SEELSKREW®s, APM provides integrated elastomeric-silicone molded seals with/without metal flanges (see photo below). We can custom design or manufacture to your prints or supplied samples. That’s because APM is a fully integrated manufacturer with a world-wide reputation as a developer and manufacturer of complete custom static and dynamic sealing solutions. We’re a lot more ® than just fasteners. Please visit our SEELSKREW s other web site for more capability Metal flange detail: www.apmhexseal.com Example: Panel mounted circuit breaker environmental sealing housing SELF-SEALING FASTENERS — ONE OF THE MANY SEALING SOLUTIONS OFFERED BY APM, FROM HEAVY-DUTY INDUSTRIAL TO ELECTRONICS Beyond offering industry the broadest line of self-sealing fastening hardware, APM, for more than half a century, has been the prime developer of elastomeric sealing boot enclosures. They are designed to increase reliability and prolong the life of switches, circuit breakers, potentiometers and encoders in hostile environments. Rated to IP68, the UL Recognized Component boots are used extensively by the U.S. military, medical, marine, electricalelectronics & communications, plant-process, construction, outdoor recreation in a wide variety of industries worldwide. www.apmhexseal.com HEXSEAL® Switch, Potentiometer, Encoder Sealing Boots onments nvir E Ar le ® W d’s Most Hos orl ti roving G ur P rou eO The APM is always pleased to provide free samples*, quotations and engineering assistance. Because of our vast experience in self-sealing and self-locking fastener technology, there’s a good chance we have dealt with a same or similar application and would be pleased to share our knowledge. For local service, please visit our web site for names of local APM HEXSEAL Manufacturers’ Representatives and local and national Authorized Distributors. s nd FREE SAMPLES & SUPPORT HEXSEAL® Circuit Breaker Sealing Boots For more than half a century, APM has been the single source for more than just basic fastening. *Visit our website and print out our Request For Samples form. WHEN JUST FASTENING ISN’T ENOUGH® 44 Honeck Street • Englewood NJ 07631 • Toll Free: (800) 498-9034 • Fax: (201) 569-4106 • www.apmselfsealingfasteners.com HEXSEAL®, SEELSKREWS®, SEELBOLTS®, SEELRIVETS®, SEELOC® & KAPTO-SKREWS® are U.S. Registered Trademarks of APM HEXSEAL CORPORATION. Printed in USA APM 2010-7.5
SFR6-32X5/16-2701 价格&库存
很抱歉,暂时无法提供与“SFR6-32X5/16-2701”相匹配的价格&库存,您可以联系我们找货
