WIDE ROLL EYELETS
A choice of the most
popular sizes in use for
PC board and electronic
assembly applications.
C
B
A
MATERIAL: Brass, Bright Electro
EYELETS & RIVETS
Tin, MIL-T-10727. Other platings
can be furnished.
CAT.
NO.
22
23
24
25
26
27
33
34
35
36
37
43
44
45
46
47
48
14
15
16
17
A
OUTSIDE
DIAMETER
BARREL
.059 (1.49) O.D.
.045 (1.14) I.D.
.089 (2.26) O.D.
.070 (1.78) I.D.
.121 (3.07) O.D.
.102 (2.59) I.D.
.152 (3.86) O.D.
.132 (3.35) I.D.
B
LENGTH
UNDER
FLANGE
.062 (1.57)
.093 (2.36)
.125 (3.18)
.156 (3.96)
.187 (4.75)
.219 (5.56)
.093 (2.36)
.125 (3.18)
.156 (3.96)
.187 (4.75)
.219 (5.56)
.093 (2.36)
.125 (3.18)
.156 (3.96)
.187 (4.75)
.219 (5.56)
.250 (6.35)
.125 (3.18)
.156 (3.96)
.187 (4.75)
.219 (5.56)
C
FLANGE
DIAMETER
MTG.
HOLE
SIZE
STAKING
TOOL
CAT.
NO.
STAKING TOOLS
.105 (2.7)
.062 (1.57)
USE DRILL
#51
3075
.150 (3.8)
.093 (2.36)
USE DRILL
#42
3076
Set consisting of top and bottom tool.
Made from Tool Steel and highly polished.
.312 [7.9]
O.D.
TOP TOOL
.125 (3.18)
USE DRILL
#30
.200 (5.1)
3077
.312 [7.9]
O.D.
BOTTOM TOOL
.156 (3.96)
USE DRILL
5/32”
.245 (6.2)
3079
SEMI-TUBULAR RIVETS
These standardized brass rivets typify the
scope and variety of popular rivets that will
provide faster and stronger assemblies at
lower cost. We suggest you rivet and test a
sample before purchasing large quantities for
your application.
B
CAT. NO. LENGTH UNDER HEAD
3381
3382
3383
3384
3385
3386
3387
3388
3389
3390
3391
H
B
MATERIAL: Brass, Nickel Plate
A
A
SHANK DIAMETER
H
HEAD DIAMETER
MTG.
HOLE SIZE
.060 (1.55)
.109 (2.8)
.067(1.70) Dia.
USE DRILL #51
.087 (2.21)
.147 (3.7)
.093 (2.36) Dia.
USE DRILL #42
.120 (3.06)
.218 (5.5)
.128 (3.25) Dia.
USE DRILL #30
.125 (3.2)
.156 (3.9)
.187 (4.8)
.156 (3.9)
.187 (4.8)
.218 (5.5)
.250 (6.4)
.156 (3.9)
.187 (4.8)
.218 (5.5)
.250 (6.4)
SNAP RIVETS
DWG. 1
T
DWG. 2
A
A
B
B
As Installed
L
L
D
Attach panels and mounting hardware without
any tooling. Leaves a clean cosmetic look once
installed. Can be installed without access to
underside. Removable so assembly can be
easily repaired or upgraded.
MATERIAL: Nylon 6/6, UL Rated 94V-2, Black
138
CAT.
NO.
3440
3441
3442
3443
3444
3445
3446
3447
3448
3449
3450
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
DWG.
1
1
1
2
2
2
2
2
2
2
2
T
PANEL THICKNESS
.051/.079 (1.3/2.0)
.083/.110 (2.1/2.8)
.114/.142 (2.9/3.6)
.118/.157 (3.0/4.0)
.146/.181 (3.7/4.6)
.177/.217 (4.5/5.5)
.217/.256 (5.5/6.5)
.177/.217 (4.5/5.5)
.217/.256 (5.5/6.5)
.256/.295 (6.5/7.5)
.295/.335 (7.5/8.5)
D
L
D
A
B
MTG.
RIVET LENGTH RIVET DIAMETER HEAD DIAMETER HEAD HEIGHT
HOLE SIZE
.130 (3.3)
.160 (4.0)
.076 (1.9)
.165 (4.2)
.047 (1.2) .083/.087 (2.1/2.2)
.190 (4.8)
.220 (5.6)
.240 (6.1)
.138 (3.5)
.252 (6.4)
.063 (1.6) .142/.146 (3.6/3.7)
.280 (7.1)
.310 (7.9)
.280 (7.1)
.310 (7.9)
.158 (4.0)
.315 (8.0)
.071 (1.8) .161/.165 (4.1/4.2)
.350 (9.0)
.390 (10.0)
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
很抱歉,暂时无法提供与“3443”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+1.8307410+0.23617
- 50+1.5854850+0.20453
- 500+1.41029500+0.18193
