3450
3450
    KEYSTONE
    RIVET SNAP 0.390" NYLON BLACK
3450 数据手册
WIDE ROLL EYELETS A choice of the most popular sizes in use for PC board and electronic assembly applications. C B A MATERIAL: Brass, Bright Electro EYELETS & RIVETS Tin, MIL-T-10727. Other platings can be furnished. CAT. NO. 22 23 24 25 26 27 33 34 35 36 37 43 44 45 46 47 48 14 15 16 17 A OUTSIDE DIAMETER BARREL .059 (1.49) O.D. .045 (1.14) I.D. .089 (2.26) O.D. .070 (1.78) I.D. .121 (3.07) O.D. .102 (2.59) I.D. .152 (3.86) O.D. .132 (3.35) I.D. B LENGTH UNDER FLANGE .062 (1.57) .093 (2.36) .125 (3.18) .156 (3.96) .187 (4.75) .219 (5.56) .093 (2.36) .125 (3.18) .156 (3.96) .187 (4.75) .219 (5.56) .093 (2.36) .125 (3.18) .156 (3.96) .187 (4.75) .219 (5.56) .250 (6.35) .125 (3.18) .156 (3.96) .187 (4.75) .219 (5.56) C FLANGE DIAMETER MTG. HOLE SIZE STAKING TOOL CAT. NO. STAKING TOOLS .105 (2.7) .062 (1.57) USE DRILL #51 3075 .150 (3.8) .093 (2.36) USE DRILL #42 3076 Set consisting of top and bottom tool. Made from Tool Steel and highly polished. .312 [7.9] O.D. TOP TOOL .125 (3.18) USE DRILL #30 .200 (5.1) 3077 .312 [7.9] O.D. BOTTOM TOOL .156 (3.96) USE DRILL 5/32” .245 (6.2) 3079 SEMI-TUBULAR RIVETS These standardized brass rivets typify the scope and variety of popular rivets that will provide faster and stronger assemblies at lower cost. We suggest you rivet and test a sample before purchasing large quantities for your application. B CAT. NO. LENGTH UNDER HEAD 3381 3382 3383 3384 3385 3386 3387 3388 3389 3390 3391 H B MATERIAL: Brass, Nickel Plate A A SHANK DIAMETER H HEAD DIAMETER MTG. HOLE SIZE .060 (1.55) .109 (2.8) .067(1.70) Dia. USE DRILL #51 .087 (2.21) .147 (3.7) .093 (2.36) Dia. USE DRILL #42 .120 (3.06) .218 (5.5) .128 (3.25) Dia. USE DRILL #30 .125 (3.2) .156 (3.9) .187 (4.8) .156 (3.9) .187 (4.8) .218 (5.5) .250 (6.4) .156 (3.9) .187 (4.8) .218 (5.5) .250 (6.4) SNAP RIVETS DWG. 1 T DWG. 2 A A B B As Installed L L D Attach panels and mounting hardware without any tooling. Leaves a clean cosmetic look once installed. Can be installed without access to underside. Removable so assembly can be easily repaired or upgraded. MATERIAL: Nylon 6/6, UL Rated 94V-2, Black 138 CAT. NO. 3440 3441 3442 3443 3444 3445 3446 3447 3448 3449 3450 Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com DWG. 1 1 1 2 2 2 2 2 2 2 2 T PANEL THICKNESS .051/.079 (1.3/2.0) .083/.110 (2.1/2.8) .114/.142 (2.9/3.6) .118/.157 (3.0/4.0) .146/.181 (3.7/4.6) .177/.217 (4.5/5.5) .217/.256 (5.5/6.5) .177/.217 (4.5/5.5) .217/.256 (5.5/6.5) .256/.295 (6.5/7.5) .295/.335 (7.5/8.5) D L D A B MTG. RIVET LENGTH RIVET DIAMETER HEAD DIAMETER HEAD HEIGHT HOLE SIZE .130 (3.3) .160 (4.0) .076 (1.9) .165 (4.2) .047 (1.2) .083/.087 (2.1/2.2) .190 (4.8) .220 (5.6) .240 (6.1) .138 (3.5) .252 (6.4) .063 (1.6) .142/.146 (3.6/3.7) .280 (7.1) .310 (7.9) .280 (7.1) .310 (7.9) .158 (4.0) .315 (8.0) .071 (1.8) .161/.165 (4.1/4.2) .350 (9.0) .390 (10.0) ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017
很抱歉,暂时无法提供与“3450”相匹配的价格&库存,您可以联系我们找货
  • 10+1.92029
  • 50+1.71513
  • 100+1.48535
库存:2390
