T15.23/500
T15.23/500
    VECTOR
    EYELET 0.093" COPPER 500PCS/PKG
T15.23/500 数据手册
CATALOG 128_CATALOG 128.qxd 4/25/2014 7:17 AM Page 78 PCB Accessories Tefzel 28 AWG Wire Insulation Properties Property Test Method Thermal Properities Nominal Melting Point ASTM D3159 Flow Rate Upper Service Temperature ASTM D315 UL746 Mechanical Properities Tensile Strength, 23oC (73oF) Specific Gravity Ultimate Elongation, 23oC (73oF) Flexural Modulus, 23oC (73oF) Impact Streength, 23oC (73oF) Hardness, Durometer Compressive Strength Linear Coefficient of Expansion, ASTM D3159 ASTM D792 ASTM D3159 ASTM D790 ASTM D256 ASTM D2240 ASTM D695 ASTM E831 0-100oC (32-212oF) Unit oC (oF) g/10 min oC Tefzel Insulated Silver Plated Wire for use with No. 02 Bit 255-280 (491-536) 20 135 MPa, (psi) % MPa (psi) J/m (ft-lb/in.) Shore D MPa, (psi) mm/mm/oC in./in./oF Electrical Properities kV/mm (V/0.001in.) Dielectric Strength, 0.25mm (0.010in.) ASTM D149 Dielectric Constant, 1MHz,23oC (73oF) ASTM D1531 Dissipation Factor, 1MHz,23oC (73oF) ASTM D1531 Volume Resistivity ASTM D257 ohm.cm Arc Resistance ASTM D49 seconds General Properities Water Absorption, 24 h ASTM D570 Weather and Chemical Resistance Limiting Oxygen Index ASTM D2863 Slit-N-Wrap® Wire Value % Part No. AWG Color Spool Dia. 40, (6,500) 1.71 300 1,200 (170,000) No Break 63 38 (5,500) 12.6x 10-5 (7.0 x 10-5 ) W28-6A W28-6B W28-6D W28-6E W28-6F W28-6H W28-6AU W28-6BU W28-6DU W28-6EU W28-6FU W28-6HU 28 28 28 28 28 28 28 28 28 28 28 28 green red blue white yellow black green red blue white yellow black Feet/Spool Spools/Pkg 50 50 50 50 50 50 150 150 150 150 150 150 2 2 2 2 2 2 1 1 1 1 1 1 1” 1” 1” 1” 1” 1” 1.5” 1.5” 1.5” 1.5” 1.5” 1.5” 70 (1,800) 2.5-2.6 0.00540 3 17 1 x 10 (1 x 10 ) 122 0.007 Excellent 30-32 % Vector 28AWG Tefzel wire is rated 300V at 150 degrees C T120-1 Slip-On Contacts • • • • Reels of slip-on contacts. 5” apart Slips onto .025” square posts 28 gage PVC insulated blue wire Temperature Range: -310 to 221oF (-190 to 105oC) EyeletsT15.23,T123 • 2 versions provide hole size reduction T123 - reduces .055” dia. holes to .042” • T123 eyelets are copper with .0003” to .0005” thick tin plating T15.23 - reduces .062” dia. holes to .042” • Simulates copper thru hole plating • Used to commit power and ground planes ID B .04 + .02 1.0 + 0.5 Contact No Contact Body Detail .060 REF 1.52 C Board Black Shrinkable Tubing Contact T123 Eyelet A T123 Eyelet No Contact End Terminal Only Contact Part No. Description Package Quantity. installed on wire installed on wire Reel of 50 Reel of 250 T120-1/50 T120-1/250 78 www.vectorelect.com Part No. Qty A B C ID T15.23/M T123/500 T123/1000 1000 500 1000 .062” .055” .055” .105” .105” .105” .093” .093” .093” .042” .042” .042” Specification subject to change without notice 800-423-5659
T15.23/500 价格&库存
很抱歉,暂时无法提供与“T15.23/500”相匹配的价格&库存,您可以联系我们找货
