1/10page
Standard name
MW35C
Standard number
CX14010701
Date of publish
01/01/2014
Date of Revision
Approved
Approval
Examination
Issue
Publish
Yonghong WAN Mingsheng LIU
Ping HUANG
2/10page
Revision form
TYPE: MW35C
CODE: CX14010701
DATE
REVISION ITEM
2014.01.01
New publishing
3/10page
1. Scope
This Standard specifies thermal class 200℃MW35C enameled copper wires to be
used in windings and wirings of electric machines and apparatus, electric
communication equipment, electronic equipment and electrical instruments.
2. Classes and Symbols
The wires are classified according to the conductor and thickness of film, and the
classes and symbols is as Table 1.
Table 1
Class
Class Heavy film Polyester over coated with polyamideimide enameled copper wire
Class Single film Polyester over coated with polyamideimide enameled copper wire
Symbol
MW35C HY
MW35C SL
3. Thermal Class
TI:200℃
4. Characteristics
The characteristics of the wires shall comply with Table 2, when tested in accordance
with 6.
4/10page
Table 2
Test Method
Test items
Characteristics
Dimensions
Comply with Attached Table4
Single Class
Pinhole
Flexibility
5Max
Heavy
Test requirements
Clause
Used
6.1
L=5M
6.2
Class
3Max
The coating shall show no crack on
the conductor
AWG
Size
Elongation
Mandrel
Winding
14~20
20%
3d
21~30
15%
1d
20%(Or to
its
breaking
31~44
point,
6.3
3d
whichever
is
less)
Adhesion
No cracks visible in the film such as
to expose the conductor
6.4
Abrasion
6.5
Breakdown Voltage
6.6
Cut through
Not cut through at 300℃, 2min
6.7
5/10page
Continuous Table 2
Test Methods
Test items
Characteristics
Test requirements
AWG Elong-at
Size
ion
14~30
Clause
Used
Mandrel
Winding
20%
3d
20%(Or to
Heat shock resistance
No cracks visible in the film such as to
its
breaking
31~44
point,
3d
6.8
whichever
is less)
The specimen shall be heated
to220±5℃ in 3d for half an hour
Solvent resistance
No bubbles or blisters visible in the film,
with nail or 2H, film shall not be peeled
Pencil method
6.9
off to expose the conductor
Conductor Resistance
6.10
Elongation
6.11
5. Conductor, Insulating Film and Appearance
5.1 Conductor
The conductor for class-2 shall be copper wire specified in JISC 3103-Annealed
Copper Wires for Windings of Electric Machines.
5.2 Insulating Film
The insulating film of the wire shall be made by baking polyurethane and over
coated with polyamide insulating varnish for enameled wires on the conductor
uniformly. The film shall be harmless to the conductor and shall have sufficient
durability.
5.3 Appearance
No scratches, to be smooth surface and uniform luster and hue, not sticky, not to be
readily scratched off by fingernail Testing Methods. The wire shall be wind the
bobbin, no cracks and dirt visible on appearance.
6.Test methods
6/10page
6.1 Dimensions
This shall comply with 3.2.1.1of NEMA.MW-1000
6.2 Pinhole
This shall comply with 6.1 of JISC 3003
6.3 Flexibility
This shall comply with 3.3.1.1of NEMA.MW-1000
6.4 Adhesion
6.5 Resistance to abrasion
This shall comply with 3.59.1.1of NEMA.MW-1000
6.6 Breakdown Voltage
This shall comply with 3.8.1.1.2of NEMA.MW-1000
6.7 Resistance to out through
This shall comply with 3.50.1.1of NEMA.MW-1000
6.8 Heat shock resistance
This shall comply with 3.51.1of NEMA.MW-1000
6.9 Solvent resistance
This shall comply with 3.51.1.1of NEMA.MW1000
6.10 Conductor resistance
This shall comply with NEMA.MW1000
6.11 Elongation
This shall comply with 3.4.1.1of NEMA.MW1000
7. Inspection
Inspection shall be made on the following items by the testing methods of 7
(1) Appearance
(2) Dimensions
(3) Pinhole
(4) Flexibility
(5) Adhesion
(6) Resistance to abrasion
(7) Breakdown voltage
(8) Cut through
(9) Heat shock resistance
(10) Solvent resistance
(11) Conductor resistance
(12) Elongation
7/10page
8. Packing and Net Weight per coil
8.1Packging
The wire shall be wound, without slackness or tangle, on a bobbin of suitable size
according to the conductor diameter (comply with table 3).
8.2 Net Weight per Coil
The net weight per coil shall comply with Table3.
Table 3
Conductor diameter
Bobbin type
(mm)
0.160~0.051
PT-4
(34#~44#)
0.361~0.180
PT-10
(27#~33#)
0.511~0.404
PT-15
(24#~26#)
1.628~0.574
PT-25
(14#~23#)
Net weight
Per coil (kg)
4+2.0
-3.0
10+2.0
-4.8
15+6.0
-5.0
25+8
-3
9. Designation of Product
The product shall be designated by the class and conductor diameter, or by the symbol
and conductor diameter.
Example: Class Heavy MW35C enameled copper wire 0.160(AWG34#) mm color
of nature
or MW35C HY AWG34#
10. Marking
The bobbin or container shall be marked at a suitable place with the following items:
(1) Class or symbol
(2) Conductor diameter (3)
Manufacturing Number (4)
Net weight
(5) SHING SHUN MAGNET WIRE CO., LTD
(6) Year and month of manufacturing
8/10page
11.Magnet Wire Test Report
Test report is must when make lot.
12.Keep method and valid time
12.1 Keep method
(1) Pulling down is not allowed
(2)Beware of collision and fall
(3)Put the goods in dry environment, wet degree: 40%~75%
12.2 Valid time
Valid for two years
13.Factory
for CnC TECH, LLC
9/10page
Table4
MW35C
Minimum
AW
G
Diameter
(mm)
Conductor
Film
Tolerance
thickness
(mm)
Size
(mm)
HY
Minimum
Maximu
m
Overall
Diam.
Dielectric
Minimum
Breakdown
Elongation
Voltage
Maximum
Conductor
in meters
Resistance
20ºC (Ω
(v)
Unit weight
(m/kg)
/KM)
10#
11#
2.588
2.304
+0.021/-0.025
+0.018/-0.023
0.086
0.084
(mm)
2.703
2.418
12#
2.052
+0.017/-0.020
0.081
2.163
5760
34
5.316
34.0
13#
1.829
+0.014/-0.018
0.081
1.934
5760
34
6.693
42.8
14#
1.628
+0.015/-0.015
0.081
1.732
5690
33
8.437
54.0
15#
1.450
+0.016/-0.015
0.076
1.547
5550
33
10.66
68.1
16#
1.290
+0.013/-0.012
0.074
1.384
5400
33
13.44
86.1
17#
1.151
+0.012/-0.013
0.071
1.240
5260
32
16.95
108.1
18#
1.024
+0.010/-0.011
0.066
1.110
5130
32
21.39
136.6
19#
0.912
+0.010/-0.010
0.064
0.993
4990
31
26.98
172.2
20#
0.813
+0.007/-0.008
0.058
0.892
4870
30
33.88
216.7
21#
0.724
+0.008/-0.008
0.056
0.798
4740
30
42.82
273.2
22#
23#
24#
0.643
0.574
0.511
+0.007/-0.008
+0.005/-0.005
+0.005/-0.006
0.053
0.051
0.048
0.714
0.642
0.577
4620
4500
4380
29
29
28
54.44
67.80
86.08
346.4
25#
0.455
+0.005/-0.005
0.046
0.516
4270
28
108.4
691.8
26#
0.404
+0.005/-0.005
0.043
0.462
4160
27
137.9
877.5
27#
0.361
+0.002/-0.003
0.041
0.417
4050
27
171.3
28#
0.320
+0.003/-0.002
0.041
0.373
3950
26
217.1
1099.0
1398.6
29#
30#
0.287
0.254
+0.003/-0.003
+0.003/-0.003
0.038
0.036
0.338
0.302
3840
3800
26
25
272.2
348.5
1738.8
31#
32#
0.226
0.203
+0.003/-0.002
+0.003/-0.002
0.033
0.031
0.274
0.249
3510
3210
24
24
437.5
543.4
2804.1
33#
0.180
+0.003/-0.002
0.028
0.224
2920
23
693.0
4420.4
34#
0.160
+0.003/-0.003
0.025
0.198
2630
22
890.6
5594.6
35#
0.142
+0.003/-0.002
0.023
0.178
2630
21
1120
7102.8
36#
0.127
+0.003/-0.003
0.020
0.160
2340
8879.8
37#
0.114
+0.003/-0.002
0.020
0.145
2050
11020.4
38#
0.102
+0.002/-0.003
0.018
0.130
850
19
2240
13766.0
39#
0.089
+0.002/-0.003
0.015
0.114
800
18
2968
18081.2
40#
0.079
+0.002/-0.003
0.015
0.102
750
17
3801
22948.5
41#
0.071
+0.003/-0.002
0.013
0.091
650
17
4611
28411.3
42#
0.064
+0.002/-0.003
0.010
0.081
650
16
5900
34966.2
43#
0.056
+0.002/-0.003
0.010
0.074
600
15
7815
45670.1
44#
0.051
+0.002/-0.003
0.010
0.069
550
14
9529
55064.0
45#
0.0447
+0.003/-0.003
0.0100
0.0610
500
11
11495
71679.2
46#
0.0399
+0.003/-0.003
0.0076
0.0533
425
10
16122
89962.7
6120
5940
35
35
3.342
4.219
21.4
27.0
434.7
548.5
2219.9
3475.5
10/10page
Continuous
Minimum
AW
G
Diameter
(mm)
Conductor
Tolerance
(mm)
Size
Film
thickness
(mm)
Table4
MW35C SL
Minimum
Maximum
Overall
Diam.
(mm)
Dielectric
Breakdown
Voltage
Minimu
m
Conductor
Elongatio
Resistance
n
(v)
3
10#
2.588
+0.021/-0.025
0.043
2.660
11#
2.304
+0.018/-0.023
0.043
2.373
12#
2.052
+0.017/-0.020
0.041
2.117
13#
1.829
+0.014/-0.018
0.041
1.892
14#
1.628
+0.015/-0.015
0.041
1.692
3170
15#
1.450
+0.016/-0.015
0.038
1.509
3090
16#
1.290
+0.013/-0.012
0.036
1.349
3010
17#
1.151
+0.012/-0.013
0.036
1.203
2930
18#
1.024
+0.010/-0.011
0.033
1.077
2850
19#
0.912
+0.010/-0.010
0.030
0.963
2780
20#
0.813
+0.007/-0.008
0.030
0.861
2710
21#
0.724
+0.008/-0.008
0.028
0.770
2640
22#
23#
24#
25#
26#
27#
28#
29#
30#
31#
32#
0.643
0.574
0.511
0.455
0.404
0.361
0.320
0.287
0.254
0.226
0.203
+0.007/-0.008
+0.005/-0.005
+0.005/-0.006
+0.005/-0.005
+0.005/-0.005
+0.002/-0.003
+0.003/-0.002
+0.003/-0.003
+0.003/-0.003
+0.003/-0.002
+0.003/-0.002
0.028
0.025
0.025
0.023
0.023
0.020
0.020
0.018
0.018
0.015
0.013
0.686
0.617
0.551
0.493
0.439
0.396
0.356
0.320
0.285
0.254
0.231
2570
33#
34#
35#
36#
37#
38#
39#
40#
0.180
0.160
0.142
0.127
0.114
0.102
0.089
0.079
+0.003/-0.002
+0.003/-0.003
+0.003/-0.002
+0.003/-0.003
+0.003/-0.002
+0.002/-0.003
+0.002/-0.003
+0.002/-0.003
0.013
0.013
0.010
0.010
0.008
0.008
0.005
0.005
0.206
0.183
0.163
0.147
0.132
0.119
0.104
0.094
1530
41#
42#
0.071
0.064
+0.003/-0.002
+0.002/-0.003
0.005
0.005
0.084
0.076
375
350
43#
44#
45#
0.056
0.051
0.0447
+0.002/-0.003
+0.002/-0.003
+0.003/-0.003
0.005
0.005
0.0051
0.066
0.061
0.0559
300
275
250
46#
0.0399
+0.003/-0.003
0.0051
0.0508
225
2500
2440
2370
2310
2250
2200
2140
2140
1840
1840
1530
1220
1220
1220
450
450
375
Maximum
5
3
5
3
4
3
4
3
33
20ºC (Ω
Unit weight
in meters
(m/kg)
/KM)
3.342
21.4
4.219
27.0
5.316
34.0
6.693
42.8
8.437
54.0
10.66
68.1
33
33
13.44
86.1
16.95
108.1
31
32
21.39
136.6
26.98
172.2
31
29
33.88
216.7
42.82
273.2
346.4
434.7
548.5
28
28
27
27
26
26
25
24
24
23
22
21
19
18
7
1
17
16
15
41
11
67.80
86.08
108.4
137.9
171.3
217.1
272.2
348.5
437.5
543.4
693.0
890.6
1120
1428
1750
2240
2968
3801
691.8
877.5
1099.0
1398.6
1738.8
2219.9
2804.1
3475.5
4420.4
5594.6
7102.8
8879.8
11020.4
13766.0
18081.2
22948.5
4611
5900
28411.3
34966.2
7815
9529
11495
45670.1
55064.0
71679.2
16122
89962.7
很抱歉,暂时无法提供与“600214-15”相匹配的价格&库存,您可以联系我们找货
