PV700HF
PV700HF
    TRIPPLITE
    INVERTER 700W 3-OUTLET
PV700HF 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 700W PowerVerter Ultra-Compact Inverter with 3 Outlets MODEL NUMBER: PV700HF Highlights ● 700W continuous output; 1400W peak output (instantaneous) ● Converts 12V DC (battery) power into 110-120V AC (household) power; 3 AC outlets ● Installs in minutes (integrated mounting feet included) ● Provides a quiet alternative to generator noise and fumes ● Includes "battery saver" low voltage alarm/shutdown Package Includes Description Utilize your vehicle's battery to efficiently power appliances, small electronics and office equipment on the road. Continuously supplies up to 700W of 120V AC power to 3 AC outlets from any 12V battery. Featuring an ultra-compact, lightweight design with metal housing, the PV700HF is the most rugged inverter available. NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at 125a should be positioned no more than 18" from the PV700HF's battery in the positive line. Features ● Provides 120V AC power for a variety of mobile applications ● 700W continuous output power; 1400W peak output power (instantaneous) ● 3 AC outlets ● Ultra-compact extruded aluminum housing stands up to the toughest environments ● Cooling fan lengthens inverter service life & maintains cool operation ● Integrated mounting feet assure safe fixed installation ● Low battery alarm/shutdown detects low battery voltage and shuts down inverter ● Overload alarm/shutdown detects wattage overload on inverter outlets and shuts down inverter as a protective measure ● DC input terminals provide a solid connection to battery with user-supplied cables ● Lighted on/off switch shows inverter operations in cramped or dark environments ● Grooved surface for more efficient cooling Specifications OVERVIEW UPC Code 037332137999 1/3 ● PV700HF Ultra-Compact DC-toAC Inverter ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Maximum Input Amps / Watts Full continuous load - 80A at 12V DC, No load - 0.95A at 12V DC, Shutdown - 150 micro amps Recommended Electrical Service Requires 12V DC input source capable of delivering 80A for the required duration (when used at full capacity). For automotive applications, hardwire installation with 125A battery system fusing is recommended Input Connection Type Set of 2 DC bolt-down wiring terminals Input Cord Length Details User supplies cabling. Minimum gauges for full load operation: 6 gauge or larger (see instruction manual) Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (3) 5-15R Continuous Output Capacity (Watts) 700 Peak Output Capacity (Watts) 1400 Output Voltage Regulation Maintains PWM sine wave output voltage of 115 VAC (+/- 8 V AC) Output Frequency Regulation 60 Hz (+/- 3 Hz) BATTERY DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Switches Lighted on/off power switch Audible Alarm Dual-function alarm indicates overload conditions or low DC input voltage of 10.5V or less PHYSICAL Material of Construction Aluminum, Steel Cooling Method Fan Shipping Dimensions (hwd / in.) 3.70 x 10.10 x 6.30 Shipping Dimensions (hwd / cm) 9.40 x 25.65 x 16.00 Shipping Weight (lbs.) 3.50 Shipping Weight (kg) 1.59 Unit Dimensions (hwd / in.) 2.760 x 8.170 x 4.960 Unit Dimensions (hwd / cm) 7 x 20.75 x 12.6 Unit Weight (lbs.) 2.8 Unit Weight (kg) 1.27 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing FEATURES & SPECIFICATIONS TVSS Grounding Main grounding screw for connecting inverter to earth, vehicle, or boat grounding systems WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV700HF 价格&库存
很抱歉,暂时无法提供与“PV700HF”相匹配的价格&库存,您可以联系我们找货
