PV150USB
PV150USB
    TRIPPLITE
    INVERTER12VDC150W1OUT
PV150USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 150W PowerVerter Ultra-Compact Car Inverter with AC Outlet and 2 USB Charging Ports MODEL NUMBER: PV150USB Highlights ● Features NEMA 5-15R outlet and 2.1A and 1.0A USB charging ports ● Converts car battery power into standard AC household power ● Plugs into your vehicle’s 12V DC cigarette lighter outlet ● Built-in fan keeps interior cool during extended use ● Tough metal housing designed to last a long time Package Includes Charge and/or power multiple electronic devices—including smartphones, laptops, tablets, GPS units, DVD players, MP3 players, camping equipment and mobile office equipment—on the go in your car, truck, boat or RV. Description The PV150USB PowerVerter® Ultra-Compact Car Inverter provides 150 watts of portable power for charging and operating multiple devices in your vehicle. It converts 12V DC power into standard household 110V AC power to run a wide variety of electronics, such as smartphones, laptops, tablets, GPS units, game systems, portable TVs, DVD players and MP3 players, as well as low-power lights, camping accessories, battery rechargers for small battery-operated power tools, and mobile office equipment. This power inverter features a NEMA 5-15R outlet, a 2.1A USB charging port and a 1.0A USB charging port. Just plug the 12V DC input jack with convenient three-foot cord into the 12V outlet in your vehicle, and the PV150USB is ready to operate. To prevent you from running down your battery, the PV150USB turns off automatically when the input voltage falls to 10V. Likewise, the unit will also shut down if it gets too hot (for instance, because the connected devices exceed 150 watts). A built-in ventilation fan keeps the interior cool during extended use. The durable metal housing is engineered to withstand the rigors of road trips, campouts, business trips and family vacations. No maintenance is required. Features Powers and Charges Up to 3 Devices ● Converts 12V DC battery power to standard 110V AC power ● Runs smartphones, laptops, tablets, GPS units, game systems, portable TVs, DVD players, MP3 players and other electronics ● Features NEMA 5-15R outlet and 2.1A and 1.0A USB charging ports ● Outputs 150 watts (continuous); 300 watts (peak) Easy to Use ● DC jack plugs into 12V DC cigarette lighter accessory outlet in your car, truck, boat or RV ● Flexible 3 ft. cord allows devices to run in the back seat 1/3 ● PV150USB 150W PowerVerter Ultra-Compact Car Inverter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Premium Construction ● Durable metal housing built to withstand rigors of travel ● Built-in ventilation fan keeps the interior cool during extended use ● Automatic low-voltage shutoff prevents deep vehicle battery discharge at 10V ● No maintenance required Specifications OVERVIEW UPC Code 037332199850 INPUT Input Connection Type 12VDC cigarette lighter input plug connection, SPT-2 16AWG Voltage Compatibility (VDC) 12 Input Cord Length (ft.) 3 Input Cord Length (m) 0.91 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (1) 5-15R Continuous Output Capacity (Watts) 150 Peak Output Capacity (Watts) 300 Output Frequency Regulation 60 Hz (+/- 3 Hz) Overload Protection 20A fuse BATTERY DC System Voltage (VDC) 12 CHARGING Charging Ports / Amps (1) 1A; (1) 2.1A PHYSICAL Material of Construction Metal Shipping Dimensions (hwd / in.) 5.70 x 7.30 x 2.90 Shipping Dimensions (hwd / cm) 14.48 x 18.54 x 7.37 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 1.60 Shipping Weight (kg) 0.73 Unit Dimensions (hwd / in.) 5.820 x 2.480 x 4.250 Unit Dimensions (hwd / cm) 14.78 x 6.30 x 10.80 Unit Weight (lbs.) 0.54 Unit Weight (kg) 0.24 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV150USB 价格&库存
很抱歉,暂时无法提供与“PV150USB”相匹配的价格&库存,您可以联系我们找货
