1000 Eaton Boulevard
Cleveland, OH 44122
United States
200W PowerVerter Ultra-Compact Car Inverter
with 2 Outlets and 2 USB Charging Ports, Cup
Holder Design
MODEL NUMBER: PV200CUSB
Highlights
Charges multiple electronic
devices in your vehicle
Features 2 AC outlets, 2.1A
USB port and 1.0A USB port
Fits snugly into your vehicle’s
cup holder
Plugs into any cigarette lighter
socket
Durable plastic housing
Package Includes
Charge and/or power multiple electronic devices on the go in your car, truck, boat or RV. Compact cupholder design helps prevent the unit from falling or sliding while your vehicle is in motion.
Description
The PV200CUSB 200W PowerVerter® Ultra-Compact Car Inverter provides 200 watts of portable power
for charging and operating multiple devices in your car, truck, boat or RV. It converts 12V DC power into
standard 120V AC power to run a wide variety of electronics, such as smartphones, laptops, tablets, GPS
units, game systems, portable TVs, DVD players and MP3 players, as well as low-power lights, camping
accessories, battery rechargers for small battery-operated power tools and mobile office equipment. And
for extra convenience, it fits snugly into your vehicle's cup holder to help prevent it from tipping over or
sliding around during travel.
The PV200CUSB features 2 AC outlets, a 2.1A USB port and a 1.0A USB port. Just plug the DC input
jack with convenient 3-ft. (0.91 m) cord into the 12V cigarette lighter socket in your vehicle, press the
on/off switch, and the unit is ready to operate. Easy-to-read illuminated switch lets you know the inverter is
receiving power from the battery.
To prevent you from running down your car battery, the PV200CUSB turns off automatically when the
input voltage falls to 10V. Likewise, the unit will also shut down if it gets too hot (for instance, because
your connected devices exceed 200 watts). A built-in ventilation fan keeps the interior cool during
extended use. The durable plastic housing is engineered to withstand the rigors of road trips, campouts,
business trips and family vacations. No maintenance is required.
Features
Powers and Charges Up to 4 Devices
● Converts 12V DC battery power to standard 120V AC power
Runs smartphones, laptops, tablets, GPS units, game systems, portable TVs, DVD players, MP3
players and other electronics
Features 2 AC outlets, 2.1A USB port and 1.0A USB port
Outputs 200 watts (continuous); 400 watts (peak)
Easy to Use
● Fits snugly in your vehicle’s cup holder for stable performance during travel
DC jack plugs into the cigarette lighter socket in your car, truck, boat or RV
1/3
PV200CUSB 200W
Inverter
Warranty information
Owner’s Manual
Cleveland, OH 44122
United States
Lighted on/off switch indicates the unit is receiving power from the battery
Premium Construction
● Durable plastic housing built to withstand rigors of travel
Built-in ventilation fan keeps the interior cool during extended use
Automatic low-voltage shutoff prevents deep vehicle battery discharge at 10V
No maintenance required
Specifications
OVERVIEW
UPC Code
037332187901
INPUT
Input Connection Type
12VDC cigarette lighter input plug connection
Voltage Compatibility (VDC)
12
Input Cord Length (ft.)
3
Input Cord Length (m)
0.91
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(2) 5-15R
Continuous Output Capacity (Watts)
200
Peak Output Capacity (Watts)
400
Output Frequency Regulation
60 Hz (+/- 3 Hz)
Overload Protection
20A fuse
BATTERY
DC System Voltage (VDC)
12
CHARGING
Charging Ports / Amps
(1) 1A; (1) 2.1A
PHYSICAL
Material of Construction
Plastic
Shipping Dimensions (hwd / in.)
7.28 x 3.15 x 5.00
2/3
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / cm)
18.50 x 8.00 x 12.70
Shipping Weight (lbs.)
1.08
Shipping Weight (kg)
0.49
Unit Dimensions (hwd / in.)
6.772 x 3.937 x 2.776
Unit Dimensions (hwd / cm)
17.21 x 10.01 x 7.04
Unit Weight (lbs.)
.878
Unit Weight (kg)
0.40
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PV200CUSB”相匹配的价格&库存,您可以联系我们找货
