PV2000FC
PV2000FC
    TRIPPLITE
    INVERTER 2000W 12VDC 2OUTLET
PV2000FC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2000W PowerVerter Plus Industrial-Strength Inverter with 2 Outlets MODEL NUMBER: PV2000FC Highlights ● Designed for heavy duty and motor loads ● 12V DC input; 120V AC output; 2 outlets ● 2000W continuous output ● Peak surge output: OverPower (up to 1 hour)—3000W, DoubleBoost (up to 10 seconds)—4000W ● High-efficiency power conversion ● Automatic overload protection Package Includes Need heavy-duty power on the go? No problem. The PV2000FC Industrial-Strength Inverter offers 2 outlets and up to 2000W of continuous output from a vehicle’s battery or a 12V external battery bank, making it perfect for a work truck with industrial equipment (e.g. power tools, electric motors). Its highly efficient operation can handle peak load requirements for equipment with high-current startup needs—up to 200% of its rated capacity. Description Utilize your vehicle's battery to efficiently power office equipment on the road or power tools at a work site. Continuously supplies up to 2000W of 120V AC power to 2 AC outlets from any 12V battery or automotive DC source. Frequency control locks AC output at 60Hz for operating stability of motor loads. Includes a set of high-current DC input terminals for simple, permanent installation. Highly reliable large transformer design specializes in powering motors and other inductive loads with high-current startup needs. Built-in RJ45 port allows connection of APS/PowerVerter Remote Switch (APSRM4) OPTIONAL FEATURES: Optional load sense function enables automatic inverter shutoff and startup as connected equipment is powered off and on. Front panel load sense potentiometer can be set to shut off or turn on inverter power in response to loads of any level. Ignition Switch Control Jack connects inverter to vehicle ignition system to automatically control inverter. Inverter ON/OFF Relay Jack connects to a user-supplied on/off indicator for remote visual status of the operation of the inverter. NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at 400a should be positioned no more than 18" from the PV2000FC's battery in the positive line. Features ● Allows users to run large, motorized AC appliances from any 12V battery or automotive DC system ● Converts 12V DC battery power to 120V AC power ● 2000W continuous output power ● Peak surge output: OverPower (up to 1 hour) 3000W, Double-Boost (up to 10 seconds) 4000W ● 2 x NEMA 5-15/20R outlets; DC input terminals for 12V battery connection ● Frequency control for operating stability ● High-efficiency operation conserves batteries to prolong runtime ● Diagnostic LEDs indicate load level (high, medium, and low) and battery charge (high, medium, and low) ● DC fusing protects inverter against overload ● High-impact polycarbonate housing 1/3 ● PV2000FC Inverter ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● RJ45 port allows connection of APS/PowerVerter Remote Switch (APSRM4) ● Grounding lug properly connects the inverter system to earth ground or vehicle grounding system ● Load sense function enables automatic inverter shutoff and startup as connected equipment is powered off and on. Specifications OVERVIEW UPC Code 037332042194 INPUT Maximum Input Amps / Watts Full continuous load - 200A at 12V DC, No load - 2.2A at 12V DC Recommended Electrical Service Requires 12V DC input source capable of delivering 200A for the required duration (when used at full capacity). For automotive applications, professional hardwire installation with 400A battery system fusing is recommended Input Connection Type Set of 2 DC bolt-down wiring terminals Input Cord Length Details User supplies cabling; 2/0 gauge or larger recommended Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (2) 5-15R Continuous Output Capacity (Watts) 2000 Peak Output Capacity (Watts) 4000 Output Voltage Regulation Maintains PWM sine wave output voltage of 120 V AC (+/-5%) Output Frequency Regulation 60 Hz (+/- 0.3 Hz) Overload Protection Circuit breaker BATTERY DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Set of 6 LEDs offers continuous status information on load percentage (6 levels reported) and battery charge level (7 levels reported). See manual for sequences Switches 3-position on/off/remote switch enables simple on/off power control plus "remote" setting that enables distant on/off control of the inverter system when used in conjunction with optional  APSRM4  accessory 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Material of Construction Polycarbonate Cooling Method Fan Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 12.90 x 14.70 x 19.00 Shipping Dimensions (hwd / cm) 32.77 x 37.34 x 48.26 Shipping Weight (lbs.) 44.00 Shipping Weight (kg) 19.96 Unit Dimensions (hwd / in.) 7.250 x 8.500 x 16.250 Unit Dimensions (hwd / cm) 18.42 x 21.59 x 41.28 Unit Weight (lbs.) 39.0 Unit Weight (kg) 17.69 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing FEATURES & SPECIFICATIONS Load Sensing Optional load sense function enables automatic inverter shutoff and startup as connected equipment is powered off and on. Front panel load sense potentiometer can be set to shutoff or turn on inverter power in response to loads of any level STANDARDS & COMPLIANCE Product Certifications UL 458 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV2000FC 价格&库存
很抱歉,暂时无法提供与“PV2000FC”相匹配的价格&库存,您可以联系我们找货
