PV1000HF
PV1000HF
    TRIPPLITE
    INVERTER 1000W 12VDC 4 OUTLET
PV1000HF 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1000W PowerVerter Compact Inverter for Trucks with 4 Outlets MODEL NUMBER: PV1000HF Highlights ● 12V DC input; 120V AC output; 4 outlets ● 1000 watts continuous output ● 2000 watts peak output (instantaneous) ● Powers an entire mobile office Package Includes Description Utilize your vehicle's battery to efficiently power office equipment on the road or power tools at a work site. Continuously supplies up to 1000 watts of 120V AC power to 4 AC outlets from any 12V battery. Includes a set of DC terminals for simple installation. Compact, lightweight metal case design is among the smallest, most rugged inverters available at this power level. NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at 175a should be positioned no more than 18" from the PV1000HF's battery in the positive line. Features ● Allows users to run AC appliances from any properly-sized 12V battery or automotive DC system ● Converts 12V DC battery power to 120V AC power ● 1000 watts continuous output power; 2000 watts peak output power (instantaneous) ● 4 outlets ● Compact, lightweight design with all-metal housing ● Remote control jack provides optional remote monitoring and control when used with optional remote module (APSRM4, sold separately) ● Low battery alarm with auto-shutoff prevents deep battery discharge ● High-efficiency operation conserves batteries to prolong run time ● Battery charge level LEDs indicate the approximate charge level (high/medium/low) of connected batteries ● Connected load level LEDs indicate the approximate wattage load level (high/medium/low) of connected equipment ● Operating mode switch controls inverter operation ● Battery Charge Conservation Dial conserves battery power by setting the load-level at which the inverter automatically shuts off ● Cooling fan regulates internal temperature and prolongs service life ● Mounting flanges provide safe, fixed installation ● Grounding lug connects to vehicle ground ● Grooved cooling surface provides additional surface area for more efficient cooling 1/3 ● PV1000HF Inverter ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332097187 INPUT Maximum Input Amps / Watts Full continuous load - 100A at 12V DC, No load - 1.5A at 12V DC, Shutdown / load sense mode - 100 micro amps Recommended Electrical Service Requires 12V DC input source capable of delivering 100A for the required duration (when used at full capacity). For automotive applications, hardwire installation with 175A battery system fusing is recommended. Input Connection Type Set of 2 DC bolt-down wiring terminals Input Cord Length Details User supplies cabling. Minimum gauges for full load operation: #4 wire (12 ft max), #2 wire (20 ft max), #0 wire (31 ft max). Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (4) 5-15R Continuous Output Capacity (Watts) 1000 Peak Output Capacity (Watts) 2000 Output Voltage Regulation Maintains PWM sine wave output voltage of 115 VAC (+/- 10% VAC) Output Frequency Regulation 60 Hz (+/- 5% Hz) Overload Protection Automatic overload protection shuts down inverter system in the event of overloads. Inverter and electrical system are further protected via four internal 40A automotive fuses BATTERY DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Set of 6 LEDs offer continuous status information on battery and connected load conditions Switches 3 position rocker switch enables on/off power control, plus "remote" setting which enables inverter to be remotely powered on or off when used in conjunction with  APSRM4  Remote Control Module (sold separately) Audible Alarm Dual function alarm indicates overload conditions or low DC input voltage of 10.5V or less PHYSICAL Material of Construction Aluminum, Steel 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Cooling Method Fan Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 4.40 x 7.80 x 18.40 Shipping Dimensions (hwd / cm) 11.18 x 19.81 x 46.74 Shipping Weight (lbs.) 7.10 Shipping Weight (kg) 3.22 Unit Dimensions (hwd / in.) 4.250 x 6.000 x 13.000 Unit Dimensions (hwd / cm) 10.8 x 15.24 x 33.02 Unit Weight (lbs.) 6 Unit Weight (kg) 2.72 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV1000HF 价格&库存
很抱歉,暂时无法提供与“PV1000HF”相匹配的价格&库存,您可以联系我们找货
