PVINT375
PVINT375
    TRIPPLITE
    INTL INVERTER DC TO AC 1 OUTLET
PVINT375 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 375W INT Series Ultra-Compact Car Inverter with 1 Universal 230V 50Hz Outlet MODEL NUMBER: PVINT375 Highlights ● 12V DC input; 230V AC output; 1 universal global outlet ● 375 watts continuous output ● Convenient cigarette lighter plug Package Includes Description Power electrical appliances in your car with Tripp Lite's INT Series PVINT375 DC-to-AC power inverter. Converts 12 volt DC power from your automotive cigarette lighter jack to modified sine wave AC power compatible with 220-240 volt/50Hz equipment. 375 watt continuous/600 watt instantaneous peak surge power handling capability powers laptop computers, battery chargers, TV/VCRs, gaming systems and small power tools. Universal outlet accepts French, German and UK style connectors, plus a variety of international plug sets. Rugged, all-metal case design withstands abuse in a compact format weighing approximately 1 kg. Built-in low-battery alarm and auto-shutoff prevents deep battery discharge. Includes lighted power switch, user replaceable fuse, built-in cooling fan and 1 meter DC input cable. Features ● Converts 12 volt DC to modified sine wave AC power compatible with 220-240 volt/50Hz equipment ● 1 meter input DC cable connects to any 12 volt automotive cigarette lighter jack ● 375 watt continuous/600 watt instantaneous peak surge power handling capability supports a variety of electronic loads ● Universal outlet accepts French, German and UK style AC input connectors, plus a variety of other international plug sets ● Rugged all-metal case ● Ultra compact, high-frequency inverter design weighs approximately 1 kg ● Low input voltage alarm alerts users to low vehicle battery conditions starting at 10.5V ● Automatic low voltage shutoff prevents deep battery discharge starting at 10V ● Lighted power switch offers visual notification of power status ● Overload protection via user-replaceable automotive fusing ● Built-in cooling fan prevents overheating, during extended usage periods ● Attractive full color retail packaging Specifications 1/3 ● PVINT375 DC-to-AC inverter system ● User manual ● Warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332119285 INPUT Maximum Input Amps / Watts Full continuous load - 25A at 12VDC, No load - 0.24A at 12VDC Input Connection Type 12VDC cigarette lighter input plug connection Input Cord Length Details 1 meter hardwire input cable, 2 mm, 2 wire Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 50 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 230V Output Receptacles (1) Universal outlets Continuous Output Capacity (Watts) 375 Peak Output Capacity (Watts) 600 Output Voltage Regulation Maintains PWM sine wave output voltage of 230VAC (+/- 10 %) Output Frequency Regulation 50 Hz (+/- 5 %) Overload Protection Via 40A automotive input fuse BATTERY DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Switches Lighted on/off power switch Audible Alarm Dual function alarm indicates overload conditions or low DC input voltage of 10.5V or less. PHYSICAL Material of Construction Aluminum, Steel Cooling Method Fan Shipping Dimensions (hwd / in.) 7.20 x 2.50 x 8.70 Shipping Dimensions (hwd / cm) 18.29 x 6.35 x 22.10 Shipping Weight (lbs.) 2.50 Shipping Weight (kg) 1.13 Unit Dimensions (hwd / in.) 2.000 x 4.250 x 7.750 Unit Dimensions (hwd / cm) 5.08 x 10.8 x 19.69 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (lbs.) 2 Unit Weight (kg) 0.91 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PVINT375 价格&库存
很抱歉,暂时无法提供与“PVINT375”相匹配的价格&库存,您可以联系我们找货
