PV375USB
PV375USB
    TRIPPLITE
    INVERTER12VDC375W2OUT
PV375USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 375W PowerVerter Ultra-Compact Car Inverter with 2 AC Outlets, 2 USB Charging Ports and Battery Cables MODEL NUMBER: PV375USB Highlights ● 2 NEMA 5-15R outlets and 2.1A and 1.0A USB charging ports ● Converts car battery power into standard AC household power ● Plugs into your vehicle’s 12V DC cigarette lighter outlet ● Tough metal housing designed to last a long time ● Included battery cables allow direct connection to car battery Package Includes Charge and/or power multiple electronic devices—including smartphones, laptops, tablets, GPS units, DVD players, MP3 players, camping equipment and mobile office equipment—on the go in your car, truck, boat or RV. Description The PV375USB PowerVerter® Ultra-Compact Car Inverter provides 375 watts of portable power for charging and operating multiple devices in your vehicle. It converts 12V DC power into standard household 110V AC power to run a wide variety of electronics, such as smartphones, laptops, tablets, GPS units, game systems, portable TVs, DVD players and MP3 players, as well as low-power lights, camping accessories, battery rechargers for small battery-operated power tools, and mobile office equipment. This power inverter features dual NEMA 5-15R outlets, a 2.1A USB charging port and a 1.0A USB charging port. Just plug the 12V DC input jack with convenient three-foot cord into the 12V outlet in your vehicle, and the PV375USB is ready to operate. Included three-foot battery cables with alligator clips also allow direct connection to your car battery’s DC terminals. To prevent you from running down your battery, the PV375USB turns off automatically when the input voltage falls to 10V. Likewise, the unit will also shut down if it gets too hot (for instance, because the connected devices exceed 375 watts). A built-in ventilation fan keeps the interior cool during extended use. The durable metal housing is engineered to withstand the rigors of road trips, campouts, business trips and family vacations. No maintenance is required. Features Powers and Charges Up to 4 Devices ● Converts 12V DC battery power to standard 110V AC power ● Runs smartphones, laptops, tablets, GPS units, game systems, portable TVs, DVD players, MP3 players and other electronics ● Features 2 NEMA 5-15R outlets and 2.1A and 1.0A USB charging ports ● Outputs 375 watts (continuous); 750 watts (peak) Easy to Use ● DC jack plugs into 12V DC cigarette lighter accessory outlet in your car, truck, boat or RV ● Flexible 3 ft. cord allows devices to run in the back seat 1/3 ● PV375USB 375W PowerVerter Ultra-Compact Car Inverter ● Red/black battery cables, 3 ft. ● CLA adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Included 3 ft. battery cables allow direct connection to car battery terminals Premium Construction ● Durable metal housing built to withstand rigors of travel ● Built-in ventilation fan keeps the interior cool during extended use ● Automatic low-voltage shutoff prevents deep vehicle battery discharge at 10V ● No maintenance required Specifications OVERVIEW UPC Code 037332199867 INPUT Input Connection Type 12VDC cigarette lighter input plug connection or battery cables Voltage Compatibility (VDC) 12 Input Cord Length (ft.) 3 Input Cord Length (m) 0.91 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (2) 5-15R Continuous Output Capacity (Watts) 375 Peak Output Capacity (Watts) 750 Output Frequency Regulation 60 Hz (+/- 3 Hz) Overload Protection 40A fuse BATTERY DC System Voltage (VDC) 12 CHARGING Charging Ports / Amps (1) 1A; (1) 2.1A PHYSICAL Material of Construction Metal Shipping Dimensions (hwd / in.) 2.80 x 7.10 x 9.20 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 7.11 x 18.03 x 23.37 Shipping Weight (lbs.) 2.40 Shipping Weight (kg) 1.09 Unit Dimensions (hwd / in.) 2.362 x 4.173 x 5.961 Unit Dimensions (hwd / cm) 15/14 x 10.59 x 5.99 Unit Weight (lbs.) 1.217 Unit Weight (kg) 0.55 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV375USB
物料型号:MODEL NUMBER: PV375USB
器件简介:PV375USB PowerVerter® Ultra-Compact Car Inverter 是一款375瓦的车载逆变器,能够将12V直流电转换为标准的110V交流电,以在车辆中为多种电子设备充电和供电。
引脚分配:该设备具有以下接口: - 2个NEMA 5-15R交流电源插座 - 1个2.1A的USB充电端口 - 1个1.0A的USB充电端口
参数特性: - 输入电压兼容性:12V直流电 - 输出频率兼容性:60Hz - 连续输出能力:375瓦 - 峰值输出能力:750瓦 - 过载保护:40A保险丝 - USB充电端口/电流:1个1A端口和1个2.1A端口
功能详解: - 能够同时为多达4个设备供电和充电 - 具有两个NEMA 5-15R插座和两个USB充电端口 - 将车载电池的12V直流电转换为标准的110V交流电 - 通过车辆的12V直流电点烟器插座或电池电缆连接 - 坚固的金属外壳设计,能够承受旅行中的严苛条件 - 内置通风风扇在长时间使用时保持内部冷却 - 当输入电压降至10V时自动关闭,以防止耗尽车载电池 - 如果设备过热(例如,连接的设备超过375瓦),设备也会关闭
应用信息:该车载逆变器适用于在车辆、卡车、船只或房车中为智能手机、笔记本电脑、平板电脑、GPS设备、游戏系统、便携式电视、DVD播放器、MP3播放器以及其他电子设备供电和充电。
封装信息:耐用的金属外壳,尺寸为2.80x7.10x9.20英寸(7.11x18.03x23.37厘米),重量为2.40磅(1.09千克)。
包装包括PV375USB车载逆变器、红/黑电池电缆(3英尺)、CLA适配器和用户手册。
产品符合RoHS标准,并提供一年有限保修。
PV375USB 价格&库存
很抱歉,暂时无法提供与“PV375USB”相匹配的价格&库存,您可以联系我们找货
PV375USB
  • 1+974.731511+126.26182
