PV1800HF
PV1800HF
    TRIPPLITE
    INVERTER 1800W 12VDC 4OUTLET
PV1800HF 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1800W PowerVerter Automotive/Truck Inverter with 4 Outlets MODEL NUMBER: PV1800HF Highlights ● 12V DC input; 120V AC output; 4 outlets ● 1800 watts continuous output ● 3600 watts peak output (instantaneous) ● Powers an entire mobile office Package Includes Description Utilize your vehicle's battery to efficiently power office equipment on the road or power tools at a work site. Continuously supplies up to 1800 watts of 120V AC power to 4 AC outlets from any 12V battery or automotive DC source. Includes a set of nut-and-bolt style DC terminals for simple installation. Compact, lightweight metal case design is among the smallest, most rugged inverters available at this power level. NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at 250a should be positioned no more than 18" from the PV1800HF's battery in the positive line. Features ● Allows users to run AC appliances from a properly sized 12V battery or automotive DC system ● Converts 12V DC battery power to 120V AC power ● 1800 watts continuous output power; 3600 watts peak output power (instantaneous) ● 4 outlets ● Compact, lightweight design with grooved surface for efficient cooling, all-metal housing ● Diagnostic LEDs indicates low battery voltage level and load level ● Low battery alarm with auto-shutoff prevents deep battery discharge ● High-efficiency operation conserves batteries to prolong run time ● Cooling fan regulates internal temperature and prolongs unit service life Specifications OVERVIEW UPC Code 037332050069 INPUT Maximum Input Amps / Watts Full continuous load - 200A at 12VDC, No load - 2.7A at 12VDC, Shutdown 1/3 ● PV1800HF Inverter ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service Requires 12VDC input source capable of delivering 200A for the required duration (when used at full capacity). For automotive applications, professional hardwire installation with 250A battery system fusing is recommended. Input Connection Type Set of 2 DC bolt-down wiring terminals. User supplies cabling; minimum gauges for full load operation: 0 (16 ft max), 00 or 2/0 (20 ft max) Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (4) 5-15R Continuous Output Capacity (Watts) 1800 Peak Output Capacity (Watts) 3600 Output Voltage Regulation Maintains PWM sine wave output voltage of 115 VAC (+/- 8 VAC) Output Frequency Regulation 60 Hz (+/- 3 Hz) Overload Protection Automatic overload protection shuts down inverter system in the event of overloads. BATTERY DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Audible Alarm Dual-function alarm indicates overload conditions or low DC input voltage of 10.5V or less. PHYSICAL Material of Construction Aluminum, Steel Cooling Method Fan Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 4.50 x 16.80 x 6.60 Shipping Dimensions (hwd / cm) 11.43 x 42.67 x 16.76 Shipping Weight (lbs.) 9.40 Shipping Weight (kg) 4.26 Unit Dimensions (hwd / in.) 4.000 x 6.000 x 15.000 Unit Dimensions (hwd / cm) 10.16 x 15.24 x 38.1 Unit Weight (lbs.) 7.25 Unit Weight (kg) 3.29 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 0%-95% Non-Condensing FEATURES & SPECIFICATIONS TVSS Grounding Grounding lug grounds the inverter to vehicle or earth ground; user supplies cabling WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV1800HF 价格&库存
很抱歉,暂时无法提供与“PV1800HF”相匹配的价格&库存,您可以联系我们找货
