PV375
PV375
    TRIPPLITE
    INVERTER 375W 12VDC 2OUT CIGPLUG
PV375 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 375W PowerVerter Ultra-Compact Car Inverter with 2 Outlets MODEL NUMBER: PV375 Highlights ● 12V DC input; 120V AC output; 2 outlets ● 375 watts continuous output ● 600 watts peak output (instantaneous) ● Convenient cigarette lighter plug Package Includes Description Utilize your vehicle's battery to efficiently power office equipment on the road. Continuously supplies up to 375 watts of 120V AC power to 2 AC outlets from any 12V battery or automotive DC source. Convenient cigarette lighter DC input jack with 3-ft. (0.91 m) cable provides 1-step installation. Portable and compact, the inverter's design is among the most rugged available thanks to its lightweight metal casing. Features ● Allows users to run AC devices from any 12V cigarette lighter socket ● Converts 12V DC battery power to 120V AC power ● 375 watts continuous output power; 600 watts peak output power (instantaneous) ● 2 outlets ● 3-ft. (0.91 m) cord with cigarette lighter plug ● Ultra compact, lightweight design with all-metal housing ● Low battery alarm with auto-shutoff preserves vehicle battery ● Overload alarm with auto-shutoff prevents wattage overload ● Replaceable 40amp fuse protects inverter from overload ● Lighted power switch Specifications OVERVIEW UPC Code 037332119841 INPUT Maximum Input Amps / Watts Full continuous load - 40A at 12V DC, No load - 0.65A at 12V DC 1/3 ● PV375 Inverter ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Connection Type 12V DC cigarette lighter input plug connection Input Cord Length Details 3 ft. hardwire input cable, 16 gauge, 2 wire Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (2) 5-15R Continuous Output Capacity (Watts) 375 Peak Output Capacity (Watts) 600 Output Voltage Regulation Maintains PWM sine wave output voltage of 115 V AC (+/- 8 VAC) Output Frequency Regulation 60 Hz (+/- 3 Hz) Overload Protection 40A automotive input fuse BATTERY DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Switches Lighted on/off power switch Audible Alarm Dual function alarm indicates overload conditions or low DC input voltage of 10.5V or less. PHYSICAL Material of Construction Aluminum, Steel Cooling Method Fan Shipping Dimensions (hwd / in.) 2.50 x 5.80 x 7.70 Shipping Dimensions (hwd / cm) 6.35 x 14.73 x 19.56 Shipping Weight (lbs.) 2.18 Shipping Weight (kg) 0.99 Unit Dimensions (hwd / in.) 2.000 x 4.250 x 7.000 Unit Dimensions (hwd / cm) 5.08 x 10.8 x 17.78 Unit Weight (lbs.) 2.3 Unit Weight (kg) 1.04 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV375
物料型号: - 型号编号:PV375
器件简介: - Tripp Lite PV375是一款375瓦的车载逆变器,能够将12V直流电转换为120V交流电,具有两个AC插座输出。
引脚分配: - 输入:12V直流电,通过一个3英尺(约0.91米)长的点烟器插头连接。 - 输出:两个5-15R的AC插座。
参数特性: - 连续输出功率:375瓦 - 峰值输出功率:600瓦(瞬时) - 输入电流:全负载时40A,无负载时0.65A - 兼容性电压:12V直流电 - 输出频率:60Hz - 输出电压:120V - 过载保护:40A汽车输入保险丝
功能详解: - 允许用户从任何12V点烟器插座运行交流设备。 - 将12V直流电池电源转换为120V交流电源。 - 超紧凑、轻量级设计,全金属外壳。 - 低电报警与自动关闭功能,保护车辆电池。 - 过载报警与自动关闭功能,防止功率过载。 - 可更换的40安培保险丝,保护逆变器免受过载。 - 带灯的电源开关。
应用信息: - 利用车辆电池在路上高效地为办公设备供电。 - 从任何12V电池或汽车直流电源连续提供高达375瓦的120V交流电至2个AC插座。
封装信息: - 材料:铝、钢 - 冷却方式:风扇 - 发货尺寸(高宽深/英寸):2.50x5.80x7.70 - 发货尺寸(高宽深/厘米):6.35x14.73x19.56 - 发货重量(磅):2.18 - 发货重量(千克):0.99 - 单元尺寸(高宽深/英寸):2.000x4.250x7.000 - 单元尺寸(高宽深/厘米):5.08x10.8x17.78 - 单元重量(磅):2.3 - 单元重量(千克):1.04
PV375 价格&库存
很抱歉,暂时无法提供与“PV375”相匹配的价格&库存,您可以联系我们找货
PV375
  • 1+841.727621+108.89032
  • 5+772.850165+99.97997
  • 10+744.9659510+96.37272
  • 25+709.6379825+91.80251
  • 50+684.0382950+88.49080
  • 100+659.35273100+85.29734
库存:8
