APSX1250
APSX1250
    TRIPPLITE
    INVERTER 1250W 12VDC OR 230VAC
APSX1250 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1250W APS X Series 12VDC 230V Inverter/Charger with Auto Transfer Switching, 2 C13 Outlets MODEL NUMBER: APSX1250 Highlights ● Delivers clean 230V AC power from AC or DC power source ● 1250W continuous output power; 2500W peak power ● Auto-transfer switching option for UPS operation ● Protects against blackouts, surges and EMI/RFI line noise ● Rugged polycarbonate housing resists moisture and impact Package Includes Portable dual-outlet power source for power applications, such as power tools and computers, as a vehicle inverter, standalone AC power source or extended-run UPS. Ideal for RVs, fleet vehicles and emergency vehicles. Description The APSX1250 1250W APS X Series 12V DC 230V AC Inverter/Charger is a reliable power source for a wide variety of equipment ranging from power tools and pumps to portable lighting and computer equipment in heavy-load conditions. With no fumes, fuel or excess noise, it’s an excellent alternative to generator power. The DC-to-AC inverter features an automatic line-to-battery transfer switch and integrated charging system that allow it to work as a vehicle inverter, standalone AC power source or extended-run UPS. It delivers 1250W of continuous power, 1875W up to one hour, or 2500W of peak power up to 10 seconds during equipment startup or cycling. An automatic overload detector, cooling fan and resettable AC circuit breakers protect the unit from damage. Designed for easy installation in RVs, over-the-road trucks, fleet vehicles and conversion vans, the APSX1250 converts stored power from any 12V battery or automotive DC source to safe, stable, computer-grade AC power and sends it to two C13 outlets for unlimited runtime. When powered by an external 230V AC source, the unit keeps the user-supplied battery charged via a three-stage 7.5/30A selectable charging system while simultaneously delivering AC power to connected equipment. When used as a UPS, the APSX1250 responds to blackouts and brownouts with an automatic, instantaneous transfer to battery-derived AC output. LEDs on the unit indicate AC/DC operational modes, overload status, DC voltage level, shutdown status and system fault status. Features Reliable Power for Mobile, Emergency and Remote Sites ● Generates safe, stable, computer-grade 230V AC power from 12V battery bank ● Ideal for powering tools, saws, motors, portable lighting, small appliances and computer equipment in heavy-load conditions ● Designed for easy installation in RVs, over-the-road trucks, fleet vehicles and conversion vans ● Functions as a vehicle inverter, standalone AC power source or extended-run UPS ● Features dual C13 outlets ● Unlimited runtime with variety of user-supplied batteries 1/5 ● APSX1250 1250W APS X Series 12V DC 230V AC Inverter/Charger ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Meets Normal and Peak Power Demands ● 1250W of continuous power ● 1875W of reserve power up to 1 hr. ● 2500W of peak power up to 10 sec. to accommodate surge power demands during equipment startup and cycling ● Automatic overload detector, built-in cooling fan and resettable AC circuit breaker protect unit from damage Automatic Transfer Switching ● Transfer relay switches to inverter power during blackout in 10 ms ● 3-position switch enables Auto, Charge Only or System Off mode ● DIP switches configure high and low voltage auto-transfer 3-Stage 7.5/30A Selectable Battery Charger ● Serves as battery charger when external 230V AC power is supplied and powering connected equipment ● Protects battery from overcharging and overdischarging ● Low-battery protection prevents excessive battery depletion ● DIP switches configure wet/gel charging profiles Optional Remote Control Capability ● RJ45 communication port allows connection of optional remote control module, such as Tripp Lite’s APSRM4 Front-Panel LEDs ● Indicate AC/DC operational modes, overload status, DC voltage level, shutdown status and system fault status Rugged Polycarbonate Housing ● Resists moisture, vibration and impact ● Built-in mounting feet for installation on any rigid horizontal surface ● Detachable 2 m C13-to-C14 power cord connects to AC power source Specifications OVERVIEW UPC Code 037332121660 INPUT Nominal Input Voltage(s) Supported 230V AC Maximum Input Amps / Watts DC INPUT: Full continuous load - 125A at 12VDC. AC INPUT: 9.3A at 230VAC with full inverter and charger load (3.3A max charger-only / combined input load to support charger and AC output is automatically controllable to 66%33%-0% based on AC output loading using the charger limiting set points - see manual for setting instructions) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service DC INPUT: Requires 12VDC input source capable of delivering 125A for the required duration (when used at full continuous capacity - DC requirements increase during OverPower and DoubleBoost operation). For automotive applications, professional hardwire installation with 225A minimum battery system fusing is recommended. AC INPUT: 230VAC Input Connection Type DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: IEC-320 C14 inlet connection Voltage Compatibility (VAC) 230 Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 50 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 230V Output Receptacles (2) Universal outlets Continuous Output Capacity (Watts) 1250 Peak Output Capacity (Watts) 2500 Output Voltage Regulation LINE POWER (AC): Maintains 230V nominal sine wave output from line power source. INVERTER POWER (AC): Maintains PWM sine wave output voltage of 230 VAC (+/-5%). Output Frequency Regulation 50 Hz (+/- 0.3 Hz) Overload Protection Includes 5A input breaker dedicated to the charging system and 6A output breaker for AC output loads BATTERY Expandable Runtime Yes Expandable Battery Runtime Runtime is expandable with any number of user supplied wet or gel type batteries Expandable Runtime Description Runtime is expandable with any number of user supplied wet or gel type batteries DC System Voltage (VDC) 12 Battery Pack Accessory (Optional)  98-121  sealed lead acid battery (optional) Battery Charge Selectable 7.5 / 30A with 1/2 cycle transfer time USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7 levels reported). See manual for sequences. Switches 3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant on/off control of the inverter system when used in conjunction with optional  APSRM4  accessory when used in inverter mode. In AC uninterruptible power mode, auto/remote setting enables automatic transfer from line power to battery power - to maintain continuous AC power to connected loads. SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 1020 PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Material of Construction Polycarbonate Cooling Method Multi-speed fan Form Factors Supported Mounting slots enable permanent placement of APSX1250 on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 12.50 x 11.00 x 10.75 Shipping Dimensions (hwd / cm) 31.75 x 27.94 x 27.30 Shipping Weight (lbs.) 26.00 Shipping Weight (kg) 11.79 Unit Dimensions (hwd / in.) 7.000 x 8.750 x 9.000 Unit Dimensions (hwd / cm) 17.78 x 22.23 x 22.86 Unit Weight (lbs.) 24 Unit Weight (kg) 10.89 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) 10 milliseconds (typical - compatible with many computers, servers and networking equipment - verify transfer time compatibility of loads for UPS applications) Low Voltage Transfer to Battery Power In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 144V (user adjustable to 163, 182, 201V - see manual) High Voltage Transfer to Battery Power In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 272V STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 1-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
APSX1250
### 物料型号 - 型号:APSX1250
### 器件简介 - 简介:APSX1250是一款1250W的APS X系列12V直流电(DC)至230V交流电(AC)逆变器/充电器,具有自动切换功能和两个C13插座。它适用于多种设备,从电动工具和泵到便携式照明和计算机设备,在重负载条件下都能提供可靠的电力。无烟雾、无燃料和低噪音,是发电机电源的优质替代品。
### 引脚分配 - 输入: - DC输入:一组2个DC螺栓式端子。 - AC输入:IEC-320 C14入口连接。 - 输出:两个通用插座。
### 参数特性 - 连续输出功率:1250W - 峰值输出功率:2500W - 输出电压:230V - 频率兼容性:50Hz - 输出电压调节:AC电源(AC):维持230V名义正弦波输出。逆变器电源(AC):维持PWM正弦波输出电压230VAC(+/-5%)。 - 过载保护:包括5A输入断路器专用于充电系统和6A输出断路器用于AC输出负载。
### 功能详解 - 自动线路到电池切换:在停电时10毫秒内切换到逆变器电源。 - 3位置开关:允许自动、仅充电或系统关闭模式。 - 3阶段7.5/30A可选电池充电器:在外部230V AC电源供电时作为电池充电器,同时为连接的设备供电。 - 可选远程控制功能:RJ45通信端口允许连接可选的远程控制模块。
### 应用信息 - 应用:适用于房车、长途卡车、车队车辆和转换货车,可将存储的电力从任何12V电池或汽车DC源转换为安全、稳定的计算机级AC电源,并将其发送到两个C13插座,实现无限运行时间。
### 封装信息 - 材料:聚碳酸酯 - 冷却方法:多速风扇 - 物理尺寸:支持安装槽,使APSX1250可以永久安装在任何水平表面上。
APSX1250 价格&库存
很抱歉,暂时无法提供与“APSX1250”相匹配的价格&库存,您可以联系我们找货
