PowerVerter 120V 1250W Utility/Work Truck
12VDC Inverter/Charger, 2-NEMA 5-15R GFCI
Highlights
12V DC or 120VAC input;
120VAC output; 2 GFCI
MODEL NUMBER: UT1250UL
protected outlets
1250 watts continuous, 1875
watts OverPower and 2500
watts
DoubleBoost inverter output
3 stage, 40A / 10A selectable
wet / gel / AGM cell battery
charger
Built-in Isobar® premium AC
surge protection and Auto
Transfer
Switching option for battery
backup / UPS operation
Description
Tripp Lite UT1250UL Utility Work Truck Inverter / Charger are the quiet alternative to gas generators with
no fumes, fuel or noise. It provides equipment with utility or generator supplied AC electricity filtered
Meets OSHA requirements
Package Includes
UT1250UL Inverter/Charger
and integrated charging system serves as an extended run UPS, a standalone power source or an
APSRM4 Remote
automotive inverter suitable for rugged work site applications. Supplies up to 1250 watts of continuous
Remote battery temperature
through premium ISOBAR surge protection. This DC-to-AC inverter with automatic line to battery transfer
120V AC power from any 12V DC battery or automotive DC source. OverPower inverter output feature
temporarily provides up to 150% of the continuous output for 1-60 minutes, and DoubleBoost inverter
output feature delivers up to 200% of continuous output for up to 10 seconds, providing the extra power
needed to start heavy-duty tools and motorized equipment. When AC cable is connected to a live wall
socket, commercial power passes through to connected equipment and the battery set is recharged via 3stage selectable 10/40Amp charging system. In UPS mode, the UT system responds to blackouts and
voltage fluctuations with a near instantaneous automatic transfer to battery derived AC output. A set of
high current DC input terminals is included for simple installation (user supplies batteries and cabling –
see owners manual for recommendations). Passes sine wave utility or generator power during battery
charging and UPS line power operation, plus efficient PWM sine wave AC output in inverter and UPS
backup modes. Reliable large transformer design, with frequency control, powers resistive electronic
loads or large inductive motors, compressors and other devices with high current needs on startup.
Included is the APSRM4 wired remote power switch with full status LED’s, which provides remote power
inverter on/off switching and continuous status information. The UT1250UL supports an unlimited amount
of runtime with user-supplied batteries.
NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at
200a should be positioned no more than 18" from the UT1250UL's battery in the positive line.
Features
1/4
sensor cable
Instruction manual with warranty
information
16.6 millisecond automatic transfer between line and battery power supports UPS protection for
equipment compatible with a one cycle transfer time
1250W continuous AC output in inverter mode, 2500W continuous AC output in AC mode
DoubleBoost output supports momentary startup loads of up to 200% of the continuous rating for up to
10 seconds - OverPower output supports duration overloads to 150% for 1-60 minutes under ideal
battery and temperature conditions
3-stage selectable 10/40 Amp battery charger with adjustable settings for wet/gel/AGM battery types
2 NEMA 5-15R GFCI protected outlets pass 120V line power or inverter output through to connected
equipment
3 position operating mode switch supports “AUTO” mode to enable automatic transfer between DC and
AC modes, CHARGE ONLY to maintain a full battery charge when AC is present without auto transfer
and SYSTEM OFF settings
Set of 6 front panel LED’s display continuous status
Set of 4 dip switches support wet/gel/AGM battery charging profiles, adjustable 135/145V high voltages
and selectable 75/85/95/105V AC low voltage auto transfer during brownouts
Set of 4 additional dip switches support 4 levels of charger limiting relative to output load size, a battery
equalization program and battery charger low/high settings
Resettable 10A charger AC input breaker and settable 12A AC output breaker and automatic 2-speed
cooling fan
Automatic overload and thermal (overheating) shutoff
Front panel remote control connector enables remote off/on switching with included APSRM4 remote
Load sensing control dial enables adjustable load threshold required to automatically turn the inverter
on and off in DC mode as load conditions change
Includes a battery temperature sensor with 20 foot cable to prolong battery life by adjusting the charge
level based on battery temperature
Specifications
OVERVIEW
UPC Code
037332124418
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
DC INPUT: Requires 12VDC input source capable of delivering 127A for the required Duration (when used at full
continuous capacity- DC requirements increase during Over-Power and Double-Boost operation). AC INPUT: 15A
120VAC recommended
Maximum Input Amps / Watts
DC INPUT: Full continuous load 127A at 12 VDC. AC INPUT 20 amps at 120 VAC with full inverter and charger load
12A max charge only)
Input Connection Type
DC INPUT: set of two (2) DC bolt-down terminals. AC INPUT: NEMA 5-15R GFCI input plug
2/4
Input Cord Length Details
DC INPUT: User supplies cabling. 6 gauge or larger (see manual) AC INPUT: attached 6ft. AC line cord with plug.
Voltage Compatibility (VAC)
120
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Output (Watts)
1250
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(2) 5-15R
Continuous Output Capacity (Watts)
1250
Peak Output Capacity (Watts)
2500
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output from line Source. Inverter Power (AC) Maintains
PWM sine wave output voltage of 120 VAC (+/- 5%)
Output Frequency Regulation
60 Hz (+/- 0.3Hz)
Overload Protection
Includes 10A input breaker dedicated to the charging system and 12A output breaker for AC output loads.
Outlet Details
BATTERY
Expandable Battery Runtime
Runtime is expandable with any number of user supplied wet or gel or AGM type batteries
Expandable Runtime
Yes
DC System Voltage (VDC)
12
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
10A / 40A (selectable)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of (6) LEDs offer continuous status information on load percentage ( 6 levels reported) and battery charge level
(7 levels reported) See manual for sequences
Switches
3 position on / off remote switch enables simple on / off power control plus "auto/ remote"
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
600
PHYSICAL
Cooling Method
Multi-speed fan
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface.(see manual for additional
mounting information)
Material of Construction
Polycarbonate
3/4
Receptacle Color
White
Shipping Dimensions (hwd / cm)
31.75 x 26.42 x 27.18
Shipping Dimensions (hwd / in.)
12.50 x 10.40 x 10.70
Shipping Weight (kg)
12.02
Shipping Weight (lbs.)
26.50
Unit Dimensions (hwd / cm)
17.78 x 22.23 x 22.86
Unit Dimensions (hwd / in.)
7 x 8.75 x 9
Unit Weight (kg)
10.52
Unit Weight (lbs.)
23.2
ENVIRONMENTAL
Relative Humidity
0-95% non-condensing
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
16.6 milliseconds (typical -compatible with many computers, servers and networking equipment -verify transfer time
compatibility loads for UPS applications)
Low Voltage Transfer to Battery
Power
In AC "auto" mode, inverter / charger switches to battery mode as line voltage drops to 75V (user adjustable to
85,95,105- see manual)
High Voltage Transfer to Battery
Power
In AC "auto" mode, inverter / charger switches to battery mode as line voltages increases to 135V (user adjustable to
145 -see manual)
SPECIAL FEATURES
Load Sensing
Load sense function enables automatic inverter shutoff and startup as connected equipment is powered off and on.
Front panel load sense potentiometer can be set to shutoff or turn on inverter power in response to loads of any
level.
STANDARDS & COMPLIANCE
Certifications
Tested to UL 458 (USA) and CSA (Canada)
WARRANTY
Product Warranty Period (U.S. &
Canada)
30-month limited warranty
(International)
1-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
很抱歉,暂时无法提供与“UT1250UL”相匹配的价格&库存,您可以联系我们找货
