PV2400FC
PV2400FC
    TRIPPLITE
    INVERTER 2400W 24VDC 2OUTLET
PV2400FC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2400W PowerVerter Plus Industrial-Strength Inverter with 2 Outlets MODEL NUMBER: PV2400FC Highlights ● Designed for heavy duty and motor loads ● 24V DC input; 120V AC output; 2 outlets ● 2400W continuous output ● Peak surge output: OverPower (up to 1 hour)—3600W; DoubleBoost (up to 10 seconds)—4800W ● High-efficiency power conversion ● Automatic overload protection Package Includes Description Continuously supplies up to 2400W of 120V AC power to 2 AC outlets from any 24V battery or automotive DC source. Frequency control locks AC output at 60Hz for operating stability of motor loads. Includes a set of high current DC input terminals for simple, permanent installation. Highly reliable large transformer design specializes in powering motors and other inductive loads with high-current startup needs. NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at 250a should be positioned no more than 18" from the PV2400FC's battery in the positive line. Features ● Converts 24V DC battery power to 120V AC power ● 2400W continuous output power ● Peak surge output: OverPower (up to 1 hour), 3600 watts; Double-Boost (up to 10 seconds), 4800W ● Set of 2 bolt-down DC wiring terminals for 24V battery connection; 2 x NEMA 5-15/20R outlets ● Frequency control for operating stability ● High-efficiency operation conserves batteries to prolong run time ● Diagnostic LEDs indicate load level (high, medium, and low) and battery charge (high, medium, and low) ● DC fusing protects inverter against overload ● High-impact polycarbonate housing ● RJ45 port allows connection of APS/PowerVerter Remote Switch (APSRM4) Specifications OVERVIEW UPC Code 037332042200 INPUT 1/3 ● PV2400FC Inverter ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps / Watts Full continuous load - 120A at 24V DC; No load - 2.2A at 24V DC Recommended Electrical Service Requires 24V DC input source capable of delivering 120A for the required duration (when used at full capacity). For automotive applications, professional hardwire installation with 250A battery system fusing is recommended Input Connection Type Set of 2 bolt-down DC wiring terminals Input Cord Length Details User supplies cabling; 2/0 gauge or larger recommended Voltage Compatibility (VDC) 24 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (2) 5-15R Continuous Output Capacity (Watts) 2400 Peak Output Capacity (Watts) 4800 Output Voltage Regulation Maintains PWM sine wave output voltage of 120 VAC (+/-5%) Output Frequency Regulation 60 Hz (+/- 0.3 Hz) Overload Protection Circuit breaker BATTERY DC System Voltage (VDC) 24 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Set of 6 LEDs provides continuous status information on load percentage (6 levels reported) and battery charge level (7 levels reported). See manual for sequences Switches 3-position on/off/remote switch enables simple on/off power control plus "remote" setting that enables distant on/off control of the inverter system when used in conjunction with optional  APSRM4  accessory PHYSICAL Material of Construction Polycarbonate Cooling Method Fan Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 12.90 x 14.40 x 21.30 Shipping Dimensions (hwd / cm) 32.77 x 36.58 x 54.10 Shipping Weight (lbs.) 38.60 Shipping Weight (kg) 17.51 Unit Dimensions (hwd / in.) 7.250 x 8.500 x 16.250 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / cm) 18.42 x 21.59 x 41.28 Unit Weight (lbs.) 39 Unit Weight (kg) 17.69 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV2400FC 价格&库存
很抱歉,暂时无法提供与“PV2400FC”相匹配的价格&库存,您可以联系我们找货
