APSINT2012
APSINT2012
    TRIPPLITE
    INVERTER2000W230VACOUT
APSINT2012 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Position a 400A fuse link less than 18 in. from the battery in the positive line to protect against highcurrent draw that may occur during inverter failure. 2000W PowerVerter APS 12VDC 120V Inverter/Charger with Auto-Transfer Switching, Hardwired MODEL NUMBER: APS2012 Highlights ● Delivers clean 120V AC power from AC or DC power source ● 2000W continuous output power; 4000W peak power ● Auto-transfer switching option for UPS operation ● Protects against blackouts, surges and EMI/RFI line noise ● Rugged polycarbonate housing resists moisture and impact Package Includes Portable 2000W power source for power applications, such as power tools and computers, as a vehicle inverter, standalone AC power source or extended-run UPS. Ideal for RVs, fleet vehicles and emergency vehicles. Description The APS2012 2000W PowerVerter APS 12V DC 120V AC Inverter/Charger is a reliable power source for a wide variety of equipment ranging from power tools and pumps to portable lighting and computer equipment in heavy-load conditions. With no fumes, fuel or excess noise, it’s an excellent alternative to generator power. The DC-to-AC inverter features an automatic line-to-battery transfer switch and integrated charging system that allow it to work as a vehicle inverter, standalone AC power source or extended-run UPS. It delivers 2000W of continuous power, 3000W up to one hour, or 4000W of peak power up to 10 seconds during equipment startup or cycling. An automatic overload detector, cooling fan and resettable AC circuit breakers protect the unit from damage. Designed for easy installation in RVs, commercial and fleet vehicles, emergency vehicles and construction equipment, the APS2012 converts stored power from any 12V battery or automotive DC source to safe, stable, computer-grade AC power for unlimited runtime. When hardwired to an external 120V AC source, the unit keeps the user-supplied battery charged via a three-stage 25/100A selectable charging system while simultaneously delivering AC power to connected equipment. When used as a UPS, the APS2012 responds to blackouts and brownouts with an automatic, instantaneous transfer to battery-derived AC output. LEDs on the unit indicate load level, battery charge level, shutdown status and system fault status. Features Reliable Power for Mobile, Emergency and Remote Sites ● Generates safe, stable, computer-grade 120V AC power from 12V battery bank ● Ideal for powering tools, saws, motors, pumps, portable lighting, appliances and computer equipment in heavy-load conditions ● Designed for easy installation in RVs, commercial and fleet vehicles, emergency vehicles and construction equipment ● Functions as vehicle inverter, standalone AC power source or extended-run UPS 1/5 ● APS2012 2000W PowerVerter APS 12V DC 120V AC Inverter/Charger ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Unlimited runtime with variety of user-supplied batteries Meets Normal and Peak Power Demands ● 2000W of continuous power ● 3000W of reserve power up to 1 hr. ● 4000W of peak power up to 10 sec. to accommodate surge power demands during equipment startup and cycling ● Automatic overload detector, built-in cooling fan and resettable AC circuit breakers protect unit from damage Automatic Transfer Switching ● Transfer relay switches to inverter power during blackout in 16.6 ms ● 3-position switch enables Auto, Charge Only or System Off mode ● DIP switches configure high and low voltage auto-transfer 3-Stage 25/100A Battery Charger ● Serves as battery charger when external 120V AC power is supplied and powering connected equipment ● Protects battery from overcharging and overdischarging ● Low-battery protection prevents excessive battery depletion ● DIP switches configure wet/gel charging profiles Optional Remote Control Capability ● RJ45 communication port allows connection of optional remote control module, such as Tripp Lite’s APSRM4 Front-Panel LEDs ● Indicate load level, battery charge level, shutdown status and system fault status Rugged Polycarbonate Housing ● Resists moisture, vibration and impact ● Built-in mounting feet for installation on any rigid horizontal surface ● Internal grounding terminal connects unit to earth ground or vehicle grounding system Specifications OVERVIEW UPC Code 037332090270 INPUT Nominal Input Voltage(s) Supported 120V AC Maximum Input Amps / Watts DC INPUT: Full continuous load - 192A at 12V DC. AC INPUT: 38 amps at 120V AC with full inverter and charger load (21A max charger-only / combined input load to support charger and AC output is automatically controllable to 66%-33%-0% based on AC output l 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service DC INPUT: Requires 12V DC input source capable of delivering 192A for the required duration (when used at full continuous capacity - DC requirements increase during Over-Power and Double-Boost operation). Input Connection Type DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: Hardwire via built in junction box with cover plate. User supplies cabling. 4 gauge or larger (see manual). AC INPUT: user supplies hardwire input cabling. Voltage Compatibility (VAC) 120 Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles Hardwire Continuous Output Capacity (Watts) 2000 Peak Output Capacity (Watts) 4000 Output Voltage Regulation LINE POWER (AC): Maintains 120V nominal sine wave output from line power source. INVERTER POWER (AC): Maintains PWM sine wave output voltage of 120 V AC (+/-5%). Output Frequency Regulation 60 Hz (+/- 0.3 Hz) Overload Protection Includes 25A input breaker dedicated to the charging system and 20A output breaker for AC output loads BATTERY Expandable Runtime Yes Expandable Battery Runtime Runtime is expandable with any number of user supplied wet or gel type batteries Expandable Runtime Description Runtime is expandable with any number of user supplied wet or gel type batteries DC System Voltage (VDC) 12 Battery Pack Accessory (Optional)  98-121  sealed lead acid battery (optional) Battery Charge 25A / 100A (selectable) USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7 levels reported). See manual for sequences. Switches 3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant on/off control of the inverter system when used in conjunction with optional  APSRM4  accessory when used in inverter mode. In AC uninterruptible power mode, "auto/remote" setting enables automatic transfer from line power to battery power - to maintain continuous AC power to connected loads. SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 600 PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Material of Construction Polycarbonate Cooling Method Multi-speed fan Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 12.80 x 14.40 x 21.10 Shipping Dimensions (hwd / cm) 32.51 x 36.58 x 53.59 Shipping Weight (lbs.) 43.00 Shipping Weight (kg) 19.50 Unit Dimensions (hwd / in.) 7.250 x 8.500 x 16.250 Unit Dimensions (hwd / cm) 18.42 x 21.59 x 41.28 Unit Weight (lbs.) 40 Unit Weight (kg) 18.14 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) 16.6 milliseconds (typical - compatible with many computers, servers and networking equipment - verify transfer time compatibility of loads for UPS applications) Low Voltage Transfer to Battery Power In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 75V (user adjustable to 85, 95, 105V - see manual) High Voltage Transfer to Battery Power In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 135V (user adjustable to 145 - see manual) FEATURES & SPECIFICATIONS Load Sensing Optional load sense function enables automatic inverter shutoff and startup as connected equipment is powered off and on. Front panel load sense potentiometer can be set to shutoff or turn on inverter power in response to loads of any level, up to 150 watts. WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 1-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
APSINT2012 价格&库存
很抱歉,暂时无法提供与“APSINT2012”相匹配的价格&库存,您可以联系我们找货
