PV3000GFCI
PV3000GFCI
    TRIPPLITE
    HEAVY DUTY INV DC TO AC 4 OUTLET
PV3000GFCI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 3000W PowerVerter Plus Heavy-Duty Inverter with 4 GFCI Outlets MODEL NUMBER: PV3000GFCI Highlights ● 12V DC input; 120V AC output; 4 outlets GFCI protected (NEMA 5-15R) ● 3000 watts continuous output; 6000 watts peak output (instantaneous) ● Quiet electricity for TVs, DVD players, microwaves, power tools, coffee makers and game systems ● Includes "Battery Saver" low voltage alarm/shutdown ● Remote Control LED/Switch Module and Cable included ● Meets OSHA requirements Package Includes Description Utilize your vehicle's battery to efficiently power office equipment on the road or power tools at a work site. Continuously supplies up to 3000 watts of 120V AC power to 4 AC GFCI protected outlets from any 12V battery or automotive DC source. Includes a PV remote and 25-ft. (7.62 m) of cable. Heavy-duty, compact metal case design is among the smallest, most rugged inverters available at this power level. Conforms to OSHA 1926.404 (b) (1) (ii) NOTE: To protect against high current draw that may occur during inverter failure, two fuse links rated at 250a each should be positioned no more than 18" from the PV3000GFCI's battery in each positive line. Features ● Converts DC power into 3000 watts of continuous 120V AC power ● 15- and 20-amp outlets provide 120V AC power ● Includes "Battery Saver" low voltage alarm/shutdown ● Heavy-duty DC input terminals assure solid connection to battery. Dual connections provide high wattage to support heavy equipment loads. ● Operating mode switch controls inverter operation. ● Remote control jack provides optional remote monitoring and control (when used with FREE, included LED/switch module) ● Remote Control LED/Switch Module controls and monitors your inverter from virtually anywhere within your vehicle with use of included extra-long cable. Allows multiple mounting options, including behind or below a dashboard or compartment. Features daisy-chain capability ● Battery charge level LEDs indicate the approximate charge level (high/medium/low) of connected batteries ● Connected load level LEDs indicate the approximate wattage load level (high/medium/low) of connected equipment ● Sturdy extruded aluminum case stands up to the toughest work environments ● Battery conservation charge dial conserves battery power by setting the low-load level at which the inverter automatically shuts off ● Cooling fans provide cooler operation, lengthening inverter service life ● Circuit breakers guard the inverter against potentially damanging equipment overload ● Mounting flanges provide safe, fixed installation 1/3 ● PV3000GFCI Inverter ● Remote control LED/switch module (APSRM4) ● 25-ft. (7.62 m) remote cable ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Grooved cooling surface provides additional surface area for more efficient cooling ● Grounding lug connects to vehicle ground Specifications OVERVIEW UPC Code 037332146595 INPUT Recommended Electrical Service Requires 12VDC input source capable of delivering 286A for the required duration (when used at full capacity). For automotive applications, professional hardwire installation with 500A battery system fusing is recommended. Maximum Input Amps 286 Maximum Input Amps Details Full continuous load - 286A at 12VDC, No load - 2.6A at 12VDC, Shutdown / load sense mode - less than 500 milliamps Input Cord Length Details User supplies cabling. Minimum gauges for full load operation: 0 (10 ft max), 00 or 2/0 (13 ft max), Twin 00 using 4 conductors (26 ft) Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V Output Receptacles (4) 5-15R Continuous Output Capacity (Watts) 3000 Peak Output Capacity (Watts) 6000 Output Voltage Regulation Maintains PWM sine wave output voltage of 115 VAC (+/- 8 VAC) Output Frequency Regulation 60 Hz (+/- 3 Hz) Overload Protection Automatic overload protection shuts down inverter system in the event of overloads. Output is protected by 2 built-in 20A circuit breakers (each controlling power to 2 outlets). Inverter and electrical system are further protected via set of 6 40A automotive input fuses. BATTERY DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Switches 3 position rocker switch enables on/off power control, plus remote setting which enables inverter to be remotely powered on or off when used in conjunction with included  APSRM4  module. Audible Alarm Dual function alarm indicates overload conditions or low DC input voltage of 10.5V or less. 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Material of Construction Aluminum, Steel Cooling Method fan Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 11.10 x 4.20 x 16.00 Shipping Dimensions (hwd / cm) 28.19 x 10.67 x 40.64 Shipping Weight (lbs.) 16.50 Shipping Weight (kg) 7.48 Unit Weight (lbs.) 12.2 Unit Weight (kg) 5.53 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing Operating Temperature 32 to 104 F (0 to 40 C) FEATURES & SPECIFICATIONS TVSS Grounding Grounding lug grounds the inverter to vehicle or earth ground - user supplies cabling WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV3000GFCI
物料型号:PV3000GFCI
器件简介:该逆变器可利用车辆电池为办公设备或工作场所的电动工具提供高效电源。它可从任何12V电池或汽车直流电源连续提供高达3000瓦的120V交流电。
引脚分配:逆变器具有重型直流输入端子,确保与电池的牢固连接,双连接设计支持高瓦数设备负载。
参数特性: - 持续输出功率:3000瓦 - 峰值输出功率:6000瓦(瞬时) - 输入电压:12V直流 - 输出频率:60Hz - 输出插座:4个NEMA 5-15R GFCI保护插座
功能详解: - 转换直流电为120V交流电 - 包括“电池保护”低电压报警/关闭功能 - 远程控制LED/开关模块,允许在车辆内几乎任何位置控制和监控逆变器 - 电池电量LED指示器显示连接电池的大致电量 - 连接负载LED指示器显示连接设备的大致功率负载
应用信息:适用于电视、DVD播放器、微波炉、电动工具、咖啡机和游戏系统等设备的电力供应。
封装信息:重型、紧凑的金属机箱设计,是同类功率级别中最小、最坚固的逆变器之一。符合OSHA 1926.404 (b) (1) (ii)标准。
注意:为防止逆变器故障期间可能发生的高电流抽取,应在PV3000GFCI电池的每条正线路上放置两个额定为250A的保险丝链接,且位置不超过18英寸。
PV3000GFCI 价格&库存
很抱歉,暂时无法提供与“PV3000GFCI”相匹配的价格&库存,您可以联系我们找货
