PV1000FC
PV1000FC
    TRIPPLITE
    INVERTER 1000W 12VDC 2OUTLET
PV1000FC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States PowerVerter Plus Inverter - Industrial-Strength Power for Heavy-Duty Applications MODEL NUMBER: PV1000FC Description Harness your vehicle's battery to efficiently power office equipment on the road or power tools at a work site. Continuously supplies up to 1000 watts of 120V AC power to 2 AC outlets from any 12V battery or automotive DC source. Frequency control locks AC output at 60Hz for operating stability of motor loads. Includes a set of high current DC input terminals for simple, permanent installation. Highly reliable large transformer design specializes in powering motors and other inductive loads with high-current startup needs. Features ● Allows users to run large, motorized AC appliances from any 12V battery or automotive DC system ● Converts 12V DC battery power to 120V AC power ● 1,000 watts continuous output power ● 2,000 watts peak output power to startup heavy motorized/inductive loads ● 2 outlets; DC input terminals for 12V battery connection ● Frequency control for operating stability ● High-efficiency operation conserves batteries to prolong run time ● Diagnostic LEDs indicate load level (high, medium, and low) and battery charge (high, medium, and low) ● DC fusing protects inverter against overload ● 3.5mm port for connecting remote switch (User supplies cable and switch) Highlights ● 12V DC input; 120V AC output; 2 outlet ● 1000 watts continuous output ● 2000 watts peak surge output ● High efficiency power conversion ● Automatic overload protection Package Includes ● PV1000FC inverter ● Instruction manual Specifications OVERVIEW UPC Code 037332042187 INPUT Maximum Input Amps / Watts Full continuous load - 100A at 12V DC, No load - 2.2A at 12V DC Recommended Electrical Service Requires 12V DC input source capable of delivering 100A for the required duration (when used at full capacity). For automotive applications, professional hardwire installation with 200A battery system fusing is recommended. Input Connection Type Set of 2 DC input terminals Input Cord Length Details User supplies cabling. 4 gauge or larger recommended. Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 60 Hz Pure Sine Wave Output No Nominal Output Voltage(s) Supported 120V 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Receptacles (2) 5-15R Continuous Output Capacity (Watts) 1000 Output Nominal Voltage 120V nominal Output Voltage Regulation Maintains PWM sine wave output voltage of 120 V AC (+/-5%) Output Frequency Regulation 60 Hz (+/- 0.3 Hz) Overload Protection Circuit breaker BATTERY DC System Voltage (VDC) 15 USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7 levels reported). See manual for sequences. Switches Lighted on/off power switch, plus 2 conductor 3.5 mm port for connecting remote switch - user supplies switch, 3.5mm plug and cable. PHYSICAL Material of Construction Polycarbonate Cooling Method Convection Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Shipping Dimensions (hwd / in.) 11.62 x 9.50 x 9.50 Shipping Dimensions (hwd / cm) 29.53 x 24.13 x 24.13 Shipping Weight (lbs.) 22.00 Shipping Weight (kg) 9.98 Unit Dimensions (hwd / in.) 10.000 x 7.000 x 7.000 Unit Dimensions (hwd / cm) 17.8 x 22.23 x 19.7 Unit Weight (lbs.) 20.4 Unit Weight (kg) 9.25 ENVIRONMENTAL Relative Humidity 0-95% non-condensing WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PV1000FC 价格&库存
很抱歉,暂时无法提供与“PV1000FC”相匹配的价格&库存,您可以联系我们找货
