APSX2012SW
APSX2012SW
    TRIPPLITE
    INTLINVERTERCHARGER230V8A
APSX2012SW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2000W APS X Series 12VDC 230V Inverter/Charger with Pure Sine-Wave Output, Hardwired Highlights ● Delivers pure sine-wave 230V AC power from AC or DC source ● 2000W continuous output power; 4000W peak power ● Auto-transfer switching option for UPS operation ● Protects against blackouts, surges and EMI/RFI line noise ● Rugged steel housing resists moisture and impact MODEL NUMBER: APSX2012SW Package Includes Portable 2000W power source for power tools, computers, audio/video components and other sensitive electronics as a vehicle inverter, standalone AC power source or extended-run UPS. Ideal for mobile, emergency and remote sites. Description The APSX2012SW 2000W APS X Series 12V DC 230V AC Inverter/Charger is a reliable power source for a wide variety of power tools, computers, audio/video components and other sensitive electronics at mobile, emergency and remote sites. With no fumes, fuel or excess noise, it’s an excellent alternative to generator power. The DC-to-AC pure sine-wave inverter delivers network-grade power to sensitive electronics. Its automatic line-to-battery transfer switch and integrated charging system allow the unit to work as a vehicle inverter, standalone AC power source or extended-run UPS. It delivers 2000W of continuous power or 4000W of peak power during equipment startup or cycling. An automatic overload detector, cooling fan and resettable AC circuit breakers protect the unit from damage. Designed for easy installation in RVs, commercial and fleet vehicles and emergency vehicles, the APSX2012SW converts stored power from any 12V battery or automotive DC source to safe, stable, computer-grade AC power for unlimited runtime. When hardwired to an external 230V AC source, the unit keeps the user-supplied battery charged via a three-stage 6-60A selectable charging system while simultaneously delivering AC power to connected equipment. When used as a UPS, the APSX2012SW responds to blackouts and brownouts with an automatic, instantaneous transfer to battery-derived AC output. LEDs on the unit indicate battery voltage, charger and inverter status. Features Reliable Power for Mobile, Emergency and Remote Sites ● Generates 230V pure sine-wave power from 12V battery bank ● Ideal for powering variable-speed tools, computers, LEDs, fans, audio/video components and other sensitive electronics ● Designed for easy installation in RVs, commercial and fleet vehicles, emergency vehicles and construction equipment ● Functions as vehicle inverter, standalone AC power source or extended-run UPS ● Unlimited runtime with variety of user-supplied batteries 1/5 ● APSX2012SW 2000W APS 12V DC 230V AC Inverter/Charger ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Pure Sine-Wave Power for Normal and Peak Power Demands ● 2000W of continuous power ● 4000W of peak power to accommodate surge power demands during equipment startup and cycling ● Automatic overload detector, built-in cooling fan and resettable AC circuit breakers protect unit from damage ● High-current DC input terminals for simple hardwired installation Automatic Transfer Switching ● Transfer relay switches to inverter power during blackout in 10 ms ● 3-position switch enables Auto, Charge Only or System Off mode ● DIP switches configure high and low voltage auto-transfer 3-Stage 6-60A Selectable Battery Charger ● Serves as battery charger when external 230V AC power is supplied and powering connected equipment ● Protects battery from overcharging and overdischarging ● Low-battery protection prevents excessive battery depletion ● DIP switches configure wet/gel charging profiles External Ports ● Battery temperature port allows connection of optional remote battery temperature sensor, such as Tripp Lite’s APSSWTEMP ● RJ45 communication port allows connection of optional remote control module, such as Tripp Lite’s APSRMSW Front-Panel LEDs ● Indicate battery voltage, charger and inverter status Rugged Steel Housing ● Resists moisture, vibration and impact ● Built-in mounting feet for installation on any rigid horizontal surface Specifications OVERVIEW UPC Code 037332161345 INPUT Nominal Input Voltage(s) Supported 230V AC Maximum Input Amps / Watts DC INPUT: Full continuous load - 240A at 12VDC. AC INPUT: 17 amps at 230VAC with full inverter and charger load (8.7A max charger-only / combined input load to support charger and AC output is automatically controllable to 66%-33%-0% based on AC output loading using the charger limiting set points - see manual for setting instructions) Recommended Electrical Service DC INPUT: Requires 12VDC input source capable of delivering 240A for the required duration (when used at full continuous capacity - DC requirements increase during OverPower and DoubleBoost operation). For automotive applications, professional hardwire installation with 400A minimum battery system fusing is recommended. 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Connection Type DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: Hardwire via built in junction box with cover plate Voltage Compatibility (VAC) 230 Voltage Compatibility (VDC) 12 OUTPUT Frequency Compatibility 50 / 60 Hz Pure Sine Wave Output Yes Nominal Output Voltage(s) Supported 230V Output Receptacles Hardwire Continuous Output Capacity (Watts) 2000 Peak Output Capacity (Watts) 4000 Output Voltage Regulation LINE POWER (AC): Maintains 230V nominal sine wave output from line power source. INVERTER POWER (AC): Maintains sine wave output voltage of 230 VAC (+/-5%). Output Frequency Regulation 50 Hz (+/- 0.3 Hz) Overload Protection Includes 15A input breaker dedicated to the charging system and 15A output breaker for AC output loads BATTERY Expandable Battery Runtime Runtime is expandable with any number of user supplied wet or gel type batteries Expandable Runtime Yes Expandable Runtime Description Runtime is expandable with any number of user supplied wet or gel type batteries DC System Voltage (VDC) 12 Battery Pack Accessory (Optional)  98-121  sealed lead acid battery (optional), BP260 Battery Charge Selectable 6 / 60A VOLTAGE REGULATION Brownout Correction Brownout transfer point - 170V (+/- 3%) Severe Brownout Correction Brownout reset point - 180V (+/- 3%) USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Display inverter status, charger status as well as bettery voltage status Switches The inverter provides an RJ-45 port for optional APSRMSW retmote control. RJ-45 port operates with standard RS485 interface (APSRMSW sold separately) Audible Alarm Audible Status indicators (see manual) PHYSICAL Material of Construction Powder-Coated Steel Cooling Method Multi-speed fan 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Form Factors Supported Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional mounting information) Receptacle Color Gray Shipping Dimensions (hwd / in.) 26.10 x 11.60 x 12.10 Shipping Dimensions (hwd / cm) 66.29 x 29.46 x 30.73 Shipping Weight (lbs.) 55.90 Shipping Weight (kg) 25.36 Unit Dimensions (hwd / in.) 7.500 x 9.000 x 22.500 Unit Dimensions (hwd / cm) 18.41 x 22.22 x 55.24 Unit Weight (lbs.) 51.16 Unit Weight (kg) 23.21 ENVIRONMENTAL Relative Humidity 0%-95% Non-Condensing LINE / BATTERY TRANSFER Transfer Time (Line Power to Battery Mode) 10 milliseconds Low Voltage Transfer to Battery Power In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 144V (user adjustable to 163, 182, 201V - see manual) High Voltage Transfer to Battery Power In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 259V (user adjustable to 264 - see manual) FEATURES & SPECIFICATIONS Load Sensing 150W ~ 220W STANDARDS & COMPLIANCE Product Certifications IEC/EN 62040 Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
APSX2012SW 价格&库存
很抱歉,暂时无法提供与“APSX2012SW”相匹配的价格&库存,您可以联系我们找货
