1000 Eaton Boulevard
Cleveland, OH 44122
United States
3000W APS X Series 24VDC 230V
Inverter/Charger with Pure Sine-Wave Output,
Hardwired
Highlights
Delivers pure sine-wave 230V
AC power from AC or DC
source
3000W continuous output
power; 6000W peak power
Auto-transfer switching option
for UPS operation
Protects against blackouts,
surges and EMI/RFI line noise
Rugged steel housing resists
moisture and impact
MODEL NUMBER: APSX3024SW
Package Includes
Portable 3000W power source for tools, saws, pumps, portable lighting, appliances and computer
equipment as a vehicle inverter, standalone AC power source or extended-run UPS. Ideal for mobile,
emergency and remote sites.
Description
The APSX3024SW 3000W APS X Series 24V DC 230V AC Inverter/Charger is a reliable power source for
a wide variety of power tools, computers, audio/video components and other sensitive electronics at
mobile, emergency and remote sites. With no fumes, fuel or excess noise, it’s an excellent alternative to
generator power.
The DC-to-AC pure sine-wave inverter delivers network-grade power to sensitive electronics. Its automatic
line-to-battery transfer switch and integrated charging system allow the unit to work as a vehicle inverter,
standalone AC power source or extended-run UPS. It delivers 3000W of continuous power, 4500W up to
one minute or 6000W of peak power up to 10 seconds during equipment startup or cycling. An automatic
overload detector, cooling fan and resettable AC circuit breakers protect the unit from damage.
Designed for easy installation in RVs, commercial and fleet vehicles and emergency vehicles, the
APSX3024SW converts stored power from any 24V battery or automotive DC source to safe, stable,
computer-grade AC power for unlimited runtime. When hardwired to an external 230V AC source, the unit
keeps the user-supplied battery charged via a three-stage 23/90A selectable charging system while
simultaneously delivering AC power to connected equipment.
When used as a UPS, the APSX3024SW responds to blackouts and brownouts with an automatic,
instantaneous transfer to battery-derived AC output. LEDs on the unit indicate load percentage and
battery charge level.
Features
Reliable Power for Mobile, Emergency and Remote Sites
● Generates 230V pure sine-wave power from 24V battery bank
Ideal for powering variable-speed tools, computers, LEDs, fans, audio/video components and other
Designed for easy installation in RVs, commercial and fleet vehicles, emergency vehicles and
construction equipment
Functions as vehicle inverter, standalone AC power source or extended-run UPS
Unlimited runtime with variety of user-supplied batteries
1/5
Inverter/Charger
Owner’s manual
Cleveland, OH 44122
United States
Pure Sine-Wave Power for Normal and Peak Power Demands
● 3000W of continuous power
4500W of reserve power up to 1 min.
6000W of peak power up to 10 sec. to accommodate surge power demands during equipment startup
and cycling
Automatic overload detector, built-in cooling fan and resettable AC circuit breakers protect unit from
damage
High-current DC input terminals for simple hardwired installation
Automatic Voltage Regulation
● Corrects brownouts and overvoltages without using battery power during battery charging and UPS
standby modes
Automatic Transfer Switching
● Transfer relay switches to inverter power during blackout in 20 ms
3-position switch enables Auto, Charge Only or System Off mode
3-Stage 23/90A Selectable Battery Charger
● Serves as battery charger when external 230V AC power is supplied and powering connected
equipment
Protects battery from overcharging and overdischarging
Low-battery protection prevents excessive battery depletion
DIP switches configure wet/gel charging profiles
External Ports
● Battery temperature port allows connection of optional battery temperature sensor
RJ45 communication port allows connection of optional remote control module, such as Tripp Lite’s
APSRM4
Front-Panel LEDs
● Indicate load percentage and battery charge level
Rugged Steel Housing
● Resists moisture, vibration, impact and high-humidity environments
Built-in mounting feet for installation on any rigid horizontal surface
Specifications
OVERVIEW
UPC Code
037332141071
INPUT
Nominal Input Voltage(s) Supported
230V AC
Recommended Electrical Service
DC INPUT: Requires 24VDC input source capable of delivering 145A for the required duration (when used at full
continuous capacity - DC requirements increase during OverPower and DoubleBoost operation).
2/5
Cleveland, OH 44122
United States
Maximum Input Amps
28
Input Connection Type
DC INPUT: Set of DC bolt-down terminals. AC INPUT: Hardwire via built in terminal strip with cover plate
Voltage Compatibility (VAC)
230
Voltage Compatibility (VDC)
24
OUTPUT
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
50 or 60 Hz (user-selectable)
Pure Sine Wave Output
Yes
Nominal Output Voltage(s)
Supported
230V
Output Receptacles
Hardwire
Continuous Output Capacity (Watts)
3000
Peak Output Capacity (Watts)
6000
Output Voltage Regulation
LINE POWER (AC): Maintains 230V nominal sine wave output from line power source. INVERTER POWER (AC):
Maintains sine wave output voltage of 230 VAC (+/-5%).
Output Frequency Regulation
50/60 Hz (+/- 0.3 Hz)
BATTERY
Expandable Runtime
Yes
Expandable Battery Runtime
Runtime is expandable with any number of user supplied wet or gel type batteries
Expandable Runtime Description
DC System Voltage (VDC)
24
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
Selectable 23 / 90A
VOLTAGE REGULATION
Voltage Regulation Description
Includes automatic voltage regulation to correct brownouts and overvoltages back to usable levels
Overvoltage Correction
Overvoltages are automatically reduced by 10%
Brownout Correction
Brownouts are automatically boosted by 10% and 20%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant
on/off control of the inverter system when used in conjunction with optional APSRM4 accessory when used in inverter mode. In AC uninterruptible power
mode, "auto/remote" setting enables automatic transfer from line power to battery power - to maintain continuous AC
power to connected loads.
3/5
Cleveland, OH 44122
United States
PHYSICAL
Material of Construction
Metal
Cooling Method
Fan
Shipping Dimensions (hwd / in.)
20.08 x 18.43 x 22.52
Shipping Dimensions (hwd / cm)
51.00 x 46.81 x 57.20
Shipping Weight (lbs.)
87.00
Shipping Weight (kg)
39.46
Unit Dimensions (hwd / in.)
10.080 x 8.900 x 12.400
Unit Dimensions (hwd / cm)
25.60 x22.606 x 31.496
Unit Weight (lbs.)
64.8
Unit Weight (kg)
29.39
ENVIRONMENTAL
Relative Humidity
0%-95% Non-Condensing
Operating Temperature
32 to 104 F (0 to 40 C)
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
Dip-switch selectable 20 millisecond (full cycle) / 10 millisecond (half-cycle) transfer times which are compatible with
many computers, servers and networking equipment - verify transfer time compatibility of loads for UPS applications
Low Voltage Transfer to Battery
Power
In 230V AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 170V AC (user
adjustable to 180V).
High Voltage Transfer to Battery
Power
In 230V AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 260V (user
adjustable to 270 - see manual).
FEATURES & SPECIFICATIONS
Grounding
Main grounding lug connects inverter/charger to earth or vehicle chassis ground
STANDARDS & COMPLIANCE
Product Certifications
UL 1741
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
2-year limited warranty
(International)
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
4/5
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
