1000 Eaton Boulevard
Cleveland, OH 44122
United States
PowerVerter APS Inverter/Charger - Reliable
Alternate Power Source
MODEL NUMBER: APS612
Highlights
12V DC input; 120V AC output;
2 outlets
600 watts continuous output
1200 watts peak output for an
extended period
3-stage, built-in battery charger
Fast load switching with
millisecond transfer time
Description
Tripp Lite's APS612 3-function DC-to-AC inverter with automatic line-to-battery transfer and integrated
charging system serves as an extended run UPS, a standalone power source or an automotive inverter.
Supplies up to 600 watts of continuous 120V AC power to 2 AC outlets from any 12V battery or
automotive DC source. When AC cable is connected to a live wall socket, commercial power passes
through to connected equipment and the battery set is recharged via 3 stage, 20 amp charging system. In
UPS mode, the APS system responds to blackouts and brownouts with an uninterrupted transfer to
battery-derived AC output. Includes a set of high current DC input terminals for simple installation (user
supplies batteries and cabling). Reliable transformer design, with efficient PWM sine wave output and
frequency control, powers resistive electronic loads or large inductive motors, compressors and other
items with high current needs on startup. Supports an unlimited amount of runtime with any number of
user-supplied batteries connected. Highly adaptable to a variety of applications and site conditions with
adjustable charger settings for wet/gel battery types and selectable line to battery power transfer voltages.
PowerVerter APS Inverters accommodate "peak surge" demands by delivering more output power than
their continuous rating. Compare the "Continuous" and "Peak Surge" wattage ratings, and you'll find
PowerVerter Plus Inverters supply up to double their output to easily handle equipment start up and motor
cycling requirements. A DoubleBoost feature provides up to 200% of the continuous output for up to 10
seconds, providing the extra power needed to cold start heavy-duty tools and equipment. An OverPower
feature delivers up to 150% of the continuous output for up to 1 hour.
Features
600 watts continuous output power; provides up to twice this rating for momentary startup of inductive
loads
2 outlets; 6 ft. AC power cord; DC input terminals for 12V battery connection
Converts 12V DC to 120V AC
Frequency control for operating stability
Coated internal circuit boards offer continuous operation in humid environments (0-95%, noncondensing)
Advanced 18 amp, 3-stage battery charger and selector switch for gel or wet cell batteries
6 diagnostic LEDs indicate AC present, on battery, overload & battery voltage level (high, medium &
low)
Functions as an extended run UPS system, standalone power source and automotive inverter
Battery runtime is dependent upon the size and number of user-supplied 12-volt batteries used
Includes AC input cord and auto-transfer to enable battery charging and automatic UPS support for
blackouts & brownouts
RJ45 port allows connection of APS/PowerVerter Remote Switch (manuf# APSRM4)
Switch allows user to select between off, auto-invert and charge-only settings
Configuration switches to allow the user to select the high and low voltage for the unit to automatically
transfer from AC power to battery backup
Resettable circuit breaker protects APS against system overload
Specifications
OVERVIEW
UPC Code
037332116277
1/3
Package Includes
APS612 Inverter/Charger
Instruction manual with warranty
information
Cleveland, OH 44122
United States
INPUT
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 56A at 12V DC. AC INPUT: 9.2 amps at 120VAC with full inverter and charger
load
Recommended Electrical Service
DC INPUT: Requires 12V DC input source capable of delivering 56A for the required duration (when used at full
continuous capacity). For automotive applications, professional hardwire installation with 100A minimum battery
system fusing is recommended.
Input Connection Type
DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: NEMA 5-15P input plug
Voltage Compatibility (VAC)
120
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(2) 5-15R
Continuous Output Capacity (Watts)
600
Output Nominal Voltage
AC OUTPUT: 120V AC nominal, DC CHARGER OUTPUT (DC): 12V DC nominal
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output. INVERTER POWER (AC): Maintains PWM sine
wave output voltage of 120 V AC (+/-5%). DC CHARGER OUTPUT (See battery recharge rate section)
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Includes 6A input breaker dedicated to the charging system and 6A output breaker for AC output loads
BATTERY
Expandable Runtime
Yes
Expandable Runtime Description
Runtime is expandable with any number of user supplied wet or gel type batteries
DC System Voltage (VDC)
15
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
Includes 20 amp DC charging system with selectable profiles for vented wet cell and sealed gel cell batteries (see
manual for detailed charger information)
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
3 position on/off/remote switch enables simple on/off power control plus "auto/remote" setting that enables distant
on/off control of the inverter system when used in conjunction with optional
很抱歉,暂时无法提供与“APS612”相匹配的价格&库存,您可以联系我们找货
